[Mapbender-commits] r10125 - in trunk/mapbender: conf http/extensions/mobilemap2/scripts/netgis http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 16 07:16:38 PDT 2019
Author: armin11
Date: 2019-05-16 07:16:38 -0700 (Thu, 16 May 2019)
New Revision: 10125
Added:
   trunk/mapbender/conf/mobilemap2.conf-dist
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
   trunk/mapbender/http/php/mod_exportWmc2Json.php
Alter conf handling for mobilemap2 client - some further things have to be done !
Added: trunk/mapbender/conf/mobilemap2.conf-dist
--- trunk/mapbender/conf/mobilemap2.conf-dist	                        (rev 0)
+++ trunk/mapbender/conf/mobilemap2.conf-dist	2019-05-16 14:16:38 UTC (rev 10125)
@@ -0,0 +1,5 @@
+<?php
+//configuration for mapbender mobilemap2
+$backgroundWms = array(913,914,915);
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js	2019-05-16 09:54:35 UTC (rev 10124)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js	2019-05-16 14:16:38 UTC (rev 10125)
@@ -45,22 +45,32 @@
 	/** Service URLs (avoid proxies by setting to null or empty string). */
 	//URL_WMC_PROXY:			"./scripts/proxy.php", //TODO: empty proxy to invoke from js client on same machine!!!
 	URL_WMC_PROXY:			"",
-	URL_WMC_REQUEST:		"http://www.geoportal.rlp.de/mapbender/php/mod_exportWmc2Json.php",
+	//URL_WMC_REQUEST:		"http://www.geoportal.rlp.de/mapbender/php/mod_exportWmc2Json.php",
+	//URL_WMC_REQUEST:		"http://localhost/mapbender/php/mod_exportWmc2Json.php",
+	URL_WMC_REQUEST:		"../../php/mod_exportWmc2Json.php",
+	//name of serverside conf file for mobilemap - will be used as parameter for mod_exportWmc2Json.php!
+	CONF_FILE_NAME:			"mobilemap2",
 	//URL_LAYERS_PROXY:		"./scripts/proxy.php",
 	URL_LAYERS_PROXY:		"",
-	URL_LAYERS_REQUEST:		"http://www.geoportal.rlp.de/mapbender/extensions/mobilemap/mod_mapbender/search_proxy.php",
+	//URL_LAYERS_REQUEST:		"http://www.geoportal.rlp.de/mapbender/extensions/mobilemap/mod_mapbender/search_proxy.php",
+	//URL_LAYERS_REQUEST:		"http://localhost/mapbender/extensions/mobilemap/mod_mapbender/search_proxy.php",
+	URL_LAYERS_REQUEST:		"../mobilemap/mod_mapbender/search_proxy.php",
-	URL_SEARCH_PROXY:		"./scripts/proxy.php",
-	URL_SEARCH_REQUEST:		"http://www.geoportal.rlp.de/mapbender/geoportal/gaz_geom_mobile.php",
-	//URL_BACKGROUND_HYBRID:	        "http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/topplusbkg@UTM32",
-	URL_BACKGROUND_HYBRID:	"http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/test@UTM32",
+	//URL_SEARCH_PROXY:		"./scripts/proxy.php",
+	URL_SEARCH_PROXY:		"",
+	//URL_SEARCH_REQUEST:		"http://www.geoportal.rlp.de/mapbender/geoportal/gaz_geom_mobile.php",
+	URL_SEARCH_REQUEST:		"../../geoportal/gaz_geom_mobile.php",
+	//URL_BACKGROUND_HYBRID:	"http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/topplusbkg@UTM32",
+	URL_BACKGROUND_HYBRID:		"http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/test@UTM32",
 	URL_BACKGROUND_AERIAL:	        "http://geo4.service24.rlp.de/wms/dop_basis.fcgi",
 	URL_FEATURE_INFO_PROXY:	"./scripts/proxy.php",
-	URL_HEIGHT_PROXY:		"./scripts/proxy.php",
-	URL_HEIGHT_REQUEST:		"http://www.geoportal.rlp.de/mapbender/extensions/mobilemap/query/rasterqueryWms.php?&lang=de" //"http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/dhm_query/dhm.map&" + "SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=mydhm&QUERY_LAYERS=mydhm"
+	//URL_HEIGHT_PROXY:		"./scripts/proxy.php",
+	URL_HEIGHT_PROXY:		"",
+	//URL_HEIGHT_REQUEST:		"http://www.geoportal.rlp.de/mapbender/extensions/mobilemap/query/rasterqueryWms.php?&lang=de" //"http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/dhm_query/dhm.map&" + "SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=mydhm&QUERY_LAYERS=mydhm"
+	URL_HEIGHT_REQUEST:		"../../extensions/mobilemap/query/rasterqueryWms.php?&lang=de"
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js	2019-05-16 09:54:35 UTC (rev 10124)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js	2019-05-16 14:16:38 UTC (rev 10125)
@@ -62,7 +62,7 @@
 			netgis.events.call( netgis.events.LAYERS_LOADING, { loading: true } );
-			var url = netgis.config.URL_WMC_REQUEST + "?wmc_id=" + id + "&epsg=" + netgis.config.MAP_PROJECTION.split( ":" )[ 1 ] + "&withHierarchy=1";
+			var url = netgis.config.URL_WMC_REQUEST + "?confFileName=" + netgis.config.CONF_FILE_NAME + "&wmc_id=" + id + "&epsg=" + netgis.config.MAP_PROJECTION.split( ":" )[ 1 ] + "&withHierarchy=1";
 			if ( netgis.config.URL_WMC_PROXY && netgis.config.URL_WMC_PROXY.length > 0 )
@@ -369,4 +369,4 @@
 		return iface;
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_exportWmc2Json.php
--- trunk/mapbender/http/php/mod_exportWmc2Json.php	2019-05-16 09:54:35 UTC (rev 10124)
+++ trunk/mapbender/http/php/mod_exportWmc2Json.php	2019-05-16 14:16:38 UTC (rev 10125)
@@ -15,7 +15,6 @@
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
-require_once(dirname(__FILE__) . "/../../conf/mobilemap.conf");
 $user = new User();
 $admin = new administration();
 $userId = $user->id;
@@ -24,6 +23,29 @@
 $withHierarchy = false;
 $overlayPath = MAPBENDER_PATH."/php/mod_GetPublishedData.php?outputFormat=kml&wmc_id=";
+//check for given mobilemap conf file as get parameter
+if (isset($_REQUEST["confFileName"]) & $_REQUEST["confFileName"] != "") {
+	//validate to csv integer list
+	$testMatch = $_REQUEST["confFileName"];
+	$pattern = '/^mobilemap[0-9]$/';
+	if (!preg_match($pattern,$testMatch)){
+		echo 'Parameter <b>confFileName</b> is not valid - mobilemap{int}!.<br/>';
+		die();
+	$confFileName = $testMatch;
+	$testMatch = NULL;
+	//check if file exists:
+	if (file_exists(dirname(__FILE__) . "/../../conf/".$confFileName.".conf")) {
+		require_once(dirname(__FILE__) . "/../../conf/".$confFileName.".conf");
+	} else {
+		echo 'Requested mobilemap conf file <b>confFileName</b> does not exist - please create one in mapbender/conf/ directory!<br/>';
+		die();
+} else {
+	echo "Mandatory parameter <b>confFileName</b> is not set or empty!";
+	die();
 //check for parameter wmc_id
 if(!isset($_GET["wmc_id"])){
 	echo 'Error: wmc_id not requested<br>';
@@ -117,27 +139,27 @@
 //define background layer
 //define list of typical background layer ids
 //use wms id because the layers can be pulled dynamically
-//background wms list
-if (!isset($backgroundWms)) {
-	$backgroundWms = array(1819,1382,1635);
+//example from conf file:
 //$backgroundWms = array(1906,1382,1819);
 $backgroundLayer = array();
-//get list of layers for this wms
-$v = array();
-$t = array();
-$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id in ( ";
-for($i=0; $i<count($backgroundWms);$i++){
-	if($i > 0){$sql .= ",";}
-	$sql .= "$".($i + 1);
-	array_push($v,$backgroundWms[$i]);
-	array_push($t,'i');
+if (isset($backgroundWms) && is_array($backgroundWms)) {
+	//get list of layers for this wms
+	$v = array();
+	$t = array();
+	$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id in ( ";
+	for($i=0; $i<count($backgroundWms);$i++){
+		if($i > 0){$sql .= ",";}
+		$sql .= "$".($i + 1);
+		array_push($v,$backgroundWms[$i]);
+		array_push($t,'i');
+	$sql .= ")";
+	$res = db_prep_query($sql,$v,$t);
+	while($row = db_fetch_assoc($res)){
+		$backgroundLayer[] = $row['layer_id'];
-$sql .= ")";
-$res = db_prep_query($sql,$v,$t);
-while($row = db_fetch_assoc($res)){
-	$backgroundLayer[] = $row['layer_id'];
 //not needed if searchInterface is used!!
 function getLayerNameGetMapUrlById() {
@@ -257,7 +279,7 @@
 		} else {
-		    $e = new mb_exception("php/mod_exportWmc2Json.php: no wmc found in session!");
+		    $e = new mb_exception("php/mod_exportWmc2JsonV2.php: no wmc found in session!");
@@ -268,7 +290,7 @@
 	$wmcEPSG = preg_replace("/EPSG:/","", $row['srs']);
 	//overwrite wmc information with external given if own bbox is requested
 	if (isset($mb_myBBOXEpsg) && isset($mb_myBBOX)) {
-		$e = new mb_notice("user given extent information found");
+		$e = new mb_notice("php/mod_exportWmc2JsonV2.php: user given extent information found");
 		//transform user defined bbox into bbox for mobile client
 		$wmcEPSG = $mb_myBBOXEpsg;
 		$bbox = explode(',',$mb_myBBOX);
@@ -294,7 +316,7 @@
 	//build object
 	//build background part
-	$wmcObject->backGroundLayer[0]->serviceType = "WMTS";
+	/*$wmcObject->backGroundLayer[0]->serviceType = "WMTS";
 	$wmcObject->backGroundLayer[0]->name = "Hybrid";
 	$wmcObject->backGroundLayer[0]->url = "http://www.gdi-rp-dienste2.rlp.de/mapcache/wmts/";
 	$wmcObject->backGroundLayer[0]->layer = "test";
@@ -306,7 +328,7 @@
 	$wmcObject->backGroundLayer[1]->name = "Luftbild";
 	$wmcObject->backGroundLayer[1]->url = "http://geo4.service24.rlp.de/wms/dop40_geo4.fcgi?";
 	$wmcObject->backGroundLayer[1]->layers = "dop";
-	$wmcObject->backGroundLayer[1]->format = "image/jpeg";
+	$wmcObject->backGroundLayer[1]->format = "image/jpeg";*/
 	if (isset($initBackGroundLayer)) {
 		$wmcObject->backGroundLayer = array();
More information about the Mapbender_commits mailing list
