[Mapbender-commits] r10127 - in trunk/mapbender/http: classes img php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 17 01:57:42 PDT 2019
Author: armin11
Date: 2019-05-17 01:57:42 -0700 (Fri, 17 May 2019)
New Revision: 10127
Added:
   trunk/mapbender/http/img/icn_ok.png
   trunk/mapbender/http/img/icn_warn.png
   trunk/mapbender/http/classes/class_metadata.php
   trunk/mapbender/http/php/mod_callMetadata.php
Allow protocol as parameter for mod_callMetadata.php
Modified: trunk/mapbender/http/classes/class_metadata.php
--- trunk/mapbender/http/classes/class_metadata.php	2019-05-17 08:21:46 UTC (rev 10126)
+++ trunk/mapbender/http/classes/class_metadata.php	2019-05-17 08:57:42 UTC (rev 10127)
@@ -2114,6 +2114,12 @@
 		array_push($v, $id);
 		$res = db_prep_query($sql,$v,$t);
 		$row = db_fetch_array($res);
+		/*if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
+			$mapbenderUrl = MAPBENDER_PATH;
+		} else {
+			$mapbenderUrl = "http://www.geoportal.rlp.de/mapbender";
+//TODO: use MAPBENDER_PATH!
 		if ((isset($row[$type.'_proxylog']) & $row[$type.'_proxylog'] != 0) or strtoupper($row['accessconstraints']) != "NONE" or strtoupper($row['fees']) != "NONE" or isset($row['termsofuse_id']) ) {
 		//service has some constraints defined!
 		//give symbol and true
@@ -2121,7 +2127,7 @@
 			if (isset($row['termsofuse_id']) & $row['symbollink'] != "") {
  				$symbolLink = $row['symbollink'];
 			} else {
-				$symbolLink = $this->protocol."://".$this->hostName."/portal/fileadmin/design/icn_warn.png";
+				$symbolLink = $this->protocol."://".$this->hostName."/mapbender/img/icn_warn.png";
 			$hasConstraints = true;
 			#$disclaimerLink = $_SERVER['HTTP_HOST']."/mapbender/php/mod_getServiceDisclaimer.php?type=".$type."&id=".$id;
@@ -2130,7 +2136,7 @@
 		} else {
 		//give symbol and false
 		//green symbol
-			$symbolLink = $this->protocol."://".$this->hostName."/portal/fileadmin/design/icn_ok.png";
+			$symbolLink = $this->protocol."://".$this->hostName."/mapbender/img/icn_ok.png";
        			#$disclaimerLink = "";
 			$hasConstraints = false;
 			#$symbolMouseOver = "Frei zugänglich"; //TODO internationalize it
Added: trunk/mapbender/http/img/icn_ok.png
(Binary files differ)
Index: trunk/mapbender/http/img/icn_ok.png
--- trunk/mapbender/http/img/icn_ok.png	2019-05-17 08:21:46 UTC (rev 10126)
+++ trunk/mapbender/http/img/icn_ok.png	2019-05-17 08:57:42 UTC (rev 10127)
Property changes on: trunk/mapbender/http/img/icn_ok.png
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Added: trunk/mapbender/http/img/icn_warn.png
Index: trunk/mapbender/http/img/icn_warn.png
--- trunk/mapbender/http/img/icn_warn.png	2019-05-17 08:21:46 UTC (rev 10126)
+++ trunk/mapbender/http/img/icn_warn.png	2019-05-17 08:57:42 UTC (rev 10127)
Property changes on: trunk/mapbender/http/img/icn_warn.png
## -0,0 +1 ##
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2019-05-17 08:21:46 UTC (rev 10126)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2019-05-17 08:57:42 UTC (rev 10127)
@@ -265,6 +265,26 @@
 	$searchTypeBbox = $testMatch; //TODO activate this
 	$testMatch = NULL;
+//possibility to force https
+if (isset($_REQUEST["protocol"]) & $_REQUEST["protocol"] != "") {
+	//validate to inside / outside - TODO implement other ones than intersects which is default
+	$testMatch = $_REQUEST["protocol"];
+ 	if (!($testMatch == 'http' or $testMatch == 'https')){
+		//echo 'searchTypeBbox: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>protocol</b> is not valid (http, https).<br/>';
+		die();
+	switch ($testMatch) {
+		case "https":
+			$https = true;
+			break;
+		case "http":
+			$https = false;
+			break;
+	$searchTypeBbox = $testMatch; //TODO activate this
+	$testMatch = NULL;
 if (isset($_REQUEST["accessRestrictions"]) & $_REQUEST["accessRestrictions"] != "") {
 	//validate to ?
 	#TODO implement me //$accessRestrictions = $_REQUEST["accessRestrictions"];
More information about the Mapbender_commits mailing list
