[Mapbender-commits] r10315 - trunk/mapbender/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Nov 5 04:42:09 PST 2019
Author: armin11
Date: 2019-11-05 04:42:08 -0800 (Tue, 05 Nov 2019)
New Revision: 10315
   trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php
Fix metadata qualification - alter dateStamp to one day after old dateStamp -  otherwise they would not be harvested, if no other things changed!
Modified: trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php
--- trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php	2019-11-04 08:34:31 UTC (rev 10314)
+++ trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php	2019-11-05 12:42:08 UTC (rev 10315)
@@ -13,12 +13,10 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__) . "/../core/globalSettings.php");
 require_once(dirname(__FILE__) . "/../http/classes/class_iso19139.php");
 require_once(dirname(__FILE__) . "/../http/classes/class_Uuid.php");
 $startTimeForAll = microtime(true);
 $metadataClass = new Iso19139();
 $injectRegistryUuid = false;
@@ -49,7 +47,7 @@
                 $metadataXml = fread($h, filesize($metadataDir."/".$file));
 		$metadataObject = $metadataClass->createMapbenderMetadataFromXML($metadataXml);
 		logMessages("fileIdentifier: ".$metadataObject->fileIdentifier);
-		logMessages("type: ".$metadataObject->hierarchyLevel);
+		//logMessages("type: ".$metadataObject->hierarchyLevel);
 		if (in_array('inspireidentifiziert', $metadataObject->keywords) && !in_array('Regional', $metadataObject->keywords) && $metadataObject->hierarchyLevel == 'dataset') {
 		    //echo $metadataObject->title."<br>";
                     //echo $metadataDir."/".$file." has keyword inspireidentifiziert!<br>";
@@ -62,7 +60,7 @@
 		    $keywordsArray[$newKeywordsIndex]->thesaurusPubDate = "2019-05-22";
                     $e = new mb_exception("test3");*/
-logMessages("Actual keywords: ".json_encode($metadataObject->keywords));
+		//logMessages("Actual keywords: ".json_encode($metadataObject->keywords));
                 if ($injectRegistryUuid && !in_array($uuid, $metadataObject->keywords)) {  //add mapbender registry keyword
 		    $newKeywordsIndex++;
 		    $keywordsArray[$newKeywordsIndex]->keyword = $uuid;
@@ -101,16 +99,9 @@
     logMessages("time to alter all xml: ".$timeToBuildAll);
-//function to inject keywords into metadata xml
-//keywords to add -
-//keywordsArray[0]->keyword = "test";
-//keywordsArray[0]->thesaurusTitle = "testThesaurus";
-//keywordsArray[0]->thesaurusPubDate = "2019-05-22";
 function addKeywords($metadataXml, $keywordsArray) {
-	//parse XML part
-	//echo $metadataXml;
-	//die();
+    //logMessages("function addKeywords");
+    //parse XML part
 	//do parsing with dom, cause we want to alter the xml which have been parsed afterwards
 	$metadataDomObject = new DOMDocument();
 	libxml_use_internal_errors(true);
@@ -118,13 +109,13 @@
 		$metadataDomObject->loadXML($metadataXml);
 		if ($metadataDomObject === false) {
 			foreach(libxml_get_errors() as $error) {
-        			logMessages("php/mod_qualifyPersistedMetadataXml.php:".$error->message);
+        			logMessages("php/mod_qualifyPersistedMetadataXml.php: ".$error->message);
 			throw new Exception("php/mod_qualifyPersistedMetadataXml.php:".'Cannot parse metadata with dom!');
 	catch (Exception $e) {
-    		logMessages("php/mod_qualifyPersistedMetadataXml.php:".$e->getMessage());
+    		logMessages("php/mod_qualifyPersistedMetadataXml.php: ".$e->getMessage());
 	if ($metadataDomObject !== false) {
 		//importing namespaces
@@ -139,18 +130,13 @@
 		$xpath->registerNamespace("gts", "http://www.isotc211.org/2005/gts");
 		//$xpath->registerNamespace("srv", "http://www.isotc211.org/2005/srv");
 		$xpath->registerNamespace("xlink", "http://www.w3.org/1999/xlink");
 		//inspire specific keywords
 		//https://webgate.ec.europa.eu/fpfis/wikis/display/InspireMIG/Spatial+scope+code+list
 		//problem: gmx namespace does not exists !!!!! - have to be declared before!!!!!!
 		/*$keywordXMLSnippet = '<?xml version="1.0" encoding="UTF-8"?><gmd:descriptiveKeywords xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink"><gmd:MD_Keywords><gmd:keyword><gmx:Anchor xlink:href="http://inspire.ec.europa.eu/metadata-codelist/SpatialScope/national">Regional</gmx:Anchor></gmd:keyword><gmd:thesaurusName><gmd:CI_Citation><gmd:title><gmx:Anchor xlink:href="http://inspire.ec.europa.eu/metadata-codelist/SpatialScope">Spatial scope</gmx:Anchor></gmd:title><gmd:date><gmd:CI_Date><gmd:date><gco:Date>2019-05-22</gco:Date></gmd:date><gmd:dateType><gmd:CI_DateTypeCode codeList="http://standards.iso.org/iso/19139/resources/gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">publication</gmd:CI_DateTypeCode></gmd:dateType></gmd:CI_Date></gmd:date></gmd:CI_Citation></gmd:thesaurusName></gmd:MD_Keywords
 ></gmd:descriptiveKeywords>';*/
 		$descriptiveKeywordsNodeList = $xpath->query('//gmd:MD_Metadata/gmd:identificationInfo//gmd:descriptiveKeywords');
 		//data and service identification!
-		$arrayDescriptiveKeywordsNodeList = (array)$descriptiveKeywordsNodeList;
+		//$arrayDescriptiveKeywordsNodeList = (array)$descriptiveKeywordsNodeList;
 		foreach ($keywordsArray as $keyword) {
 			$keywordXMLSnippet ='<?xml version="1.0" encoding="UTF-8"?><gmd:descriptiveKeywords xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink">
     <gmd:MD_Keywords>
@@ -177,11 +163,9 @@
     </gmd:MD_Keywords>
 			//count old resourceConstraints elements
 			//TODO - if this is empty - create a new entry
 			//if (!empty($arrayResourceConstraintsNodeList)) {
-logMessages("Count of existing descriptiveKeywordsNodeList: ".count($descriptiveKeywordsNodeList));
-//$e = new mb_exception("count array descriptiveKeywordsNodeList: ".count($arrayDescriptiveKeywordsNodeList));
+//logMessages("Count of existing descriptiveKeywordsNodeList: ".count($descriptiveKeywordsNodeList));
 			if (count($descriptiveKeywordsNodeList) > 0) {
 				//$e = new mb_exception("list is not empty!");
 				//load xml from constraint generator
@@ -189,8 +173,6 @@
 				$keywordDomObject->loadXML($keywordXMLSnippet);
 				$xpathKeyword = new DOMXpath($keywordDomObject);
 				$keywordNodeList = $xpathKeyword->query('/gmd:descriptiveKeywords');
-//$e = new mb_exception("new keyword length: ".$keywordNodeList->length);
-//$e = new mb_exception("old keyword length: ".$descriptiveKeywordsNodeList->length);
 				//insert new keyword before first old constraints node
 				//for ($i = ($keywordNodeList->length)-1; $i >= 0; $i--) {
 					$descriptiveKeywordsNodeList->item(0)->parentNode->insertBefore($metadataDomObject->importNode($keywordNodeList->item(0), true), $descriptiveKeywordsNodeList->item(0));
@@ -200,20 +182,28 @@
     						$temp = $resourceConstraintsNodeList->item($i); //avoid calling a function twice
     						$temp->parentNode->removeChild($temp);
+			}//end for descriptiveKeywordsNodeList
 		} //end - foreach keyword in array
-		//test http://localhost/mb_trunk/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=0da11651-aa61-d75a-446c-ea4ea073bc48
+		//if keyword was injected - the metadata dateStamp has to be altered - fictive 1 day will be added to mark the difference!
+		$dateNodeList = $xpath->query('//gmd:MD_Metadata/gmd:dateStamp/gco:Date');
+                $dateStamp = $dateNodeList->item(0)->nodeValue;
+		$date = new DateTime($dateStamp);
+	        //add one day
+		$date->add(new DateInterval('P1D'));
+		$dateNew = date_format($date, 'Y-m-d');
+                $fragment = $metadataDomObject->createElementNS('http://www.isotc211.org/2005/gco', 'gco:Date', $dateNew);
+		$dateNodeList->item(0)->parentNode->replaceChild($fragment, $dateNodeList->item(0));
+	} //end for parsing xml successfully
 	return $metadataDomObject->saveXML();
 function logMessages($message) {
     if (php_sapi_name() === 'cli' OR defined('STDIN')) {
-        echo __FILE__.$message."\n";
+        echo __FILE__.": ".$message."\n";
     } else {
-        $e = new mb_exception(__FILE__.$message);
+        $e = new mb_exception(__FILE__.": ".$message);
More information about the Mapbender_commits mailing list
