[Mapbender-commits] r10321 - trunk/mapbender/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 6 21:26:57 PST 2019
Author: armin11
Date: 2019-11-06 21:26:57 -0800 (Wed, 06 Nov 2019)
New Revision: 10321
Added:
   trunk/mapbender/tools/mod_exportISOMetadata.php
Metadata generator will be only available from cli - not via http - for security reasons!
Added: trunk/mapbender/tools/mod_exportISOMetadata.php
--- trunk/mapbender/tools/mod_exportISOMetadata.php	                        (rev 0)
+++ trunk/mapbender/tools/mod_exportISOMetadata.php	2019-11-07 05:26:57 UTC (rev 10321)
@@ -0,0 +1,238 @@
+<?php
+#http://www.geoportal.rlp.de/mapbender/php/mod_exportISOMetadata.php?
+# $Id: mod_exportISOMetadata.php 235
+# http://www.mapbender.org/index.php/Inspire_Metadata_Editor
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//altered to tools folder - 2019-11-06
+//require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+//require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+require_once(dirname(__FILE__) . "/../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../http/classes/class_connector.php");
+if (file_exists(dirname(__FILE__)."/../conf/exportIsoMetadata.json")) {
+     $configObject = json_decode(file_get_contents("../conf/exportIsoMetadata.json"));
+//alter METADATA_DIR from mapbender.conf to right relative path
+$metadataDir = str_replace("../../", "../", METADATA_DIR);
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+//define the view or table where to read out the layer ids for which metadatafiles should be generated
+$wmsView = "search_wms_view";
+//$wmsView = "wms_search_table";
+if (isset($configObject->metadataGenerationUri) && $configObject->metadataGenerationUri != "") {
+    $baseUri = $configObject->metadataGenerationUri;
+} else {
+    $baseUri = "http://localhost/mapbender";
+$sql = "update mb_metadata set export2csw = false where position('GetRecordById' in data) <> 0 and position('GetRecordById' in data) is not null";
+if (isset($configObject->excludeFromCswExportRule) && count($configObject->excludeFromCswExportRule) > 0) {
+    $sql .= " AND metadata_id NOT IN (".implode(",", $configObject->excludeFromCswExportRule).")";
+$res = db_query($sql);
+$sql = "SELECT layer_id ";
+$sql .= "FROM ".$wmsView." WHERE export2csw = true";
+//$sql .= "FROM layer WHERE layer_id IN (20203,20202)";
+$v = array();
+$t = array();
+$res = db_prep_query($sql,$v,$t);
+$generatorScript = '/php/mod_layerISOMetadata.php?';
+$generatorScriptMetadata = '/php/mod_dataISOMetadata.php?';
+$generatorScriptDlsOption = '/php/mod_getDownloadOptions.php?';
+$generatorScriptDls = '/php/mod_inspireAtomFeedISOMetadata.php?';
+$generatorScriptDlsWfs2 = '/php/mod_featuretypeISOMetadata.php?'; //SERVICE=WFS&outputFormat=iso19139&Id=2699'
+$generatorBaseUrl = $baseUri.$generatorScript;
+$generatorBaseUrlMetadata = $baseUri.$generatorScriptMetadata;
+$generatorBaseUrlDlsOption = $baseUri.$generatorScriptDlsOption;
+$generatorBaseUrlDls = $baseUri.$generatorScriptDls;
+$generatorBaseUrlDlsWfs2 = $baseUri.$generatorScriptDlsWfs2;
+$countLayer = 0;
+$countMetadataURL = 0;
+$countDls = 0;
+logMessages(date('Y-m-d - H:i:s', time()));
+//remove files from $metadataDir!
+if ($handle = opendir($metadataDir)) {
+	logMessages( "Delete files from temporary metadata folder:");
+    	// This is the correct way to loop over the directory.
+    	while (false !== ($file = readdir($handle))) {
+		//check if file name begin with "mapbender";
+		$pos = strpos($file, "mapbender");
+		if ($pos !== false) {
+			//delete file with unlink
+			unlink($metadataDir."/".$file);
+			logMessages($metadataDir."/".$file." has been deleted!");
+		} else {
+        		logMessages("$file will not be deleted!");
+   	closedir($handle);
+logMessages("Begin to create new metadata: ".date('Y-m-d - H:i:s', time()));
+while($row = db_fetch_array($res)){
+	$generatorUrl = $generatorBaseUrl."SERVICE=WMS&outputFormat=iso19139&id=".$row['layer_id'];
+	logMessages("URL requested : ".$generatorUrl);
+	$generatorInterfaceObject = new connector($generatorUrl);
+	$ISOFile = $generatorInterfaceObject->file;
+	$layerId = $row['layer_id'];
+	logMessages("File for layer ".$layerId." will be generated");
+	//generate temporary files under tmp
+	if($h = fopen($metadataDir."/mapbenderServiceMetadata_".$layerId."_iso19139.xml","w")){
+		if(!fwrite($h,$ISOFile)){
+			$e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".$metadataDir."/mapbenderLayerMetadata_".$row['layer_id']."_iso19139.xml");
+	logMessages("Service metadata file for layer ".$layerId." written to ".$metadataDir);
+	fclose($h);
+	//get all connected metadata for this layer and save it too
+	$sql = <<<SQL
+SELECT metadata_id, uuid, link, linktype, md_format, origin, export2csw FROM mb_metadata
+INNER JOIN (SELECT * from ows_relation_metadata
+WHERE fkey_layer_id = $layerId ) as relation ON
+mb_metadata.metadata_id = relation.fkey_metadata_id
+SQL;
+	$res_metadata = db_query($sql);
+	while ($row_metadata = db_fetch_array($res_metadata)) {
+		//export only metadata which should be exported to the external csw interface
+		if ($row_metadata["export2csw"] == "t") {
+			$generatorUrlMetadata = $generatorBaseUrlMetadata."outputFormat=iso19139&id=".$row_metadata['uuid'];
+			logMessages("URL requested: ".$generatorUrlMetadata);
+			$generatorInterfaceObject = new connector($generatorUrlMetadata);
+			logMessages("Metadata uuid: ".$row_metadata['uuid']);
+			if($h = fopen($metadataDir."/mapbenderDataMetadata_".$layerId."_".$row_metadata['uuid']."_iso19139.xml","w")){
+					$e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".$metadataDir."/metadata/mapbenderMetadata_".$layerId."_".$row_metadata['uuid']."_iso19139.xml");
+				logMessages("Data metadate file for layer ".$row['layer_id']." and metadata ".$row_metadata['uuid']." written to ".$metadataDir);
+				fclose($h);
+				$countMetadataURL++;
+		//generate the downloadservice metadata files thru walking over the coupled dls for this metadata uuid!
+		//e.g. http://www.geoportal.rlp.de/mapbender/php/mod_inspireAtomFeedISOMetadata.php?Id=1487b57f-f087-d84a-3de3-e341312ecd6e&outputFormat=iso19139&generateFrom=wfs&wfsid=271
+		//get download options for specific metadata
+		$downloadOptionsConnector = new connector($generatorBaseUrlDlsOption."id=".$row_metadata["uuid"]);
+		$downloadOptions = json_decode($downloadOptionsConnector->file);
+		if ($downloadOptions != null) {
+			logMessages("Coupled DLS:");
+			foreach ($downloadOptions->{$row_metadata["uuid"]}->option as $option) {
+				unset($dlsOption);
+				switch ($option->type) {
+					case "wmslayergetmap":
+						$generatorDlsUrl =  $generatorBaseUrlDls."Id=".$row_metadata["uuid"]."&outputFormat=iso19139&generateFrom=wmslayer&layerid=".$option->resourceId;
+						$dlsOption = $option->type;
+						$dlsOptionId = $option->resourceId;
+						break;
+					case "wmslayerdataurl":
+						$generatorDlsUrl = $generatorBaseUrlDls."Id=".$row_metadata["uuid"]."&outputFormat=iso19139&generateFrom=dataurl&layerid=".$option->resourceId;
+						break;
+					case "wfsrequest":
+						$generatorDlsUrl = $generatorBaseUrlDls."Id=".$row_metadata["uuid"]."&outputFormat=iso19139&generateFrom=wfs&wfsid=".$option->serviceId;
+						$dlsOptionId = $option->serviceId;
+						break;
+					case "downloadlink":
+						$generatorDlsUrl = $generatorBaseUrlDls."Id=".$row_metadata["uuid"]."&outputFormat=iso19139&generateFrom=metadata";
+						//generate downloadservice uuid from metadata_uuid and hash of link
+						$mdPart = explode('-',$row_metadata["uuid"]);
+						$linkPart = md5($option->link);
+						$dlsOptionId = $mdPart[0]."-".$mdPart[1]."-".$mdPart[2]."-".substr($linkPart, -12, 4)."-".substr($linkPart, -8, 8);
+						break;
+				logMessages($generatorDlsUrl);
+				//load the xml and store it to filesystem
+				if (isset($dlsOption) && $dlsOption != '') {
+					$generatorInterfaceObject = new connector($generatorDlsUrl);
+					if($h = fopen($metadataDir."/mapbenderDlsMetadata_".$row_metadata["uuid"]."_".$dlsOption."_".$dlsOptionId."_iso19139.xml","w")){
+							$e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".$metadataDir."/mapbenderDlsMetadata_".$row_metadata["uuid"]."_".$dlsOption."_".$dlsOptionId."_iso19139.xml");
+						fclose($h);
+						$countDls++;
+				//test if download option via wfsrequest is based on WFS > 2.0 - first also generate metadata for wfs 1.1.0
+				if ($option->type == "wfsrequest") {
+					//select featuretypeid, wfs_version, ...
+					$sqlWfs2 = <<<SQL
+					SELECT wfs_version, fkey_wfs_id, featuretype_id FROM (SELECT fkey_wfs_id, featuretype_id FROM wfs_featuretype WHERE featuretype_id
+					IN (select fkey_featuretype_id from mb_metadata LEFT JOIN ows_relation_metadata ON metadata_id = fkey_metadata_id where
+					 fkey_featuretype_id IS NOT NULL)) ft LEFT JOIN wfs ON
+					ft.fkey_wfs_id = wfs_id WHERE wfs_version = '2.0.0' OR wfs_version = '2.0.2' ;
+SQL;
+					$v = array();
+					$t = array();
+					$res_wfs2 = db_prep_query($sqlWfs2,$v,$t);
+					while ($row_wfs2 = db_fetch_array($res_wfs2)) {
+						$generatorDlsUrlWfs2 = $generatorBaseUrlDlsWfs2."SERVICE=WFS&outputFormat=iso19139&Id=".$row_wfs2['featuretype_id'];
+						$generatorInterfaceObject = new connector($generatorDlsUrlWfs2);
+						if($h = fopen($metadataDir."/mapbenderDlsWfs2Metadata_".$row_metadata["uuid"]."_".$row_wfs2['featuretype_id']."_iso19139.xml","w")){
+								$e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".$metadataDir."/mapbenderDlsWfs2Metadata_".$row_metadata["uuid"]."_".$row_wfs2['featuretype_id']."_iso19139.xml");
+							fclose($h);
+							$countDls++;
+	$countLayer++;
+logMessages("Number of generated View Service Metadata Records (one for each layer): ".$countLayer);
+logMessages("Number of generated Data Metadata Records (multiple for each layer): ".$countMetadataURL);
+logMessages("Number of generated Download Service Metadata Records (multiple for each metadataset): ".$countDls);
+function logMessages($message) {
+    if (php_sapi_name() === 'cli' OR defined('STDIN')) {
+        echo __FILE__.": ".$message."\n";
+    } else {
+        $e = new mb_exception(__FILE__.": ".$message);
More information about the Mapbender_commits mailing list
