[Mapbender-commits] r10340 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Tue Nov 19 02:26:48 PST 2019
Author: armin11
Date: 2019-11-19 02:26:48 -0800 (Tue, 19 Nov 2019)
New Revision: 10340
trunk/mapbender/http/plugins/mod_metadataCarousel.php
Fix click events - deactivate them on <li> - user div instead
Modified: trunk/mapbender/http/plugins/mod_metadataCarousel.php
--- trunk/mapbender/http/plugins/mod_metadataCarousel.php 2019-11-19 09:54:12 UTC (rev 10339)
+++ trunk/mapbender/http/plugins/mod_metadataCarousel.php 2019-11-19 10:26:48 UTC (rev 10340)
@@ -121,13 +121,13 @@
//increase global var currentPage
currentPage = parseInt(currentPage) + parseInt(1);
//unbind all old click events
- $('.slides li img').unbind('click');
+ $('.slide_div').unbind('click');
//reinitialize click event
- $('.slides li img').click(function(){
+ $('.slide_div').click(function(){
var $this = $(this);
- resourceId = $this.attr("resourceId");
+ resourceId = $this.attr("resourceid");
resourceTitle = $this.attr("title");
- alert(options.loadMessage + ": " + resourceId);
+ alert(options.loadMessage + ": " + resourceTitle);
that.executeJavaScript({method:"loadWmc", parameters:{id:resourceId}});
@@ -155,13 +155,14 @@
slideshow: false,
//isFirefox: true,
start: function(slider){
- $('.slides li img', slider).click(function(){
that.loadWmcById(resourceId);
+ $('.slide').unbind('click');
end: function(slider){
that.loadMore();
@@ -185,6 +186,7 @@
$("ul.slides").html("");
//alert("number of all wmc: "+JSON.parse(initialResult.responseText).wmc.md.nresults);
JSON.parse(initialResult.responseText).wmc.srv.forEach(that.addElementToSlider);
/*$('.show_more_button').attr("value", "1-"+parseInt(currentPage)*parseInt(maxResults)+" ("+numberOfResults+") - "+showMoreButtonText);
if (parseInt(currentPage)*parseInt(maxResults) >= parseInt(numberOfResults)) {
$('.show_more_button').attr("value", "1-"+numberOfResults+" ("+numberOfResults+")");
@@ -193,7 +195,7 @@
this.addElementToSlider = function(item) {
- mainFlexSlider.data('flexslider').addSlide("<li class='slide'><div class='slide_div'><img src='"+item.previewURL+"' resourceId='"+item.id+"' title='"+item.title+"'/><div><span class='flex-caption'>"+item.title+"</span></div><div><span class='flex-load-count'>"+item.loadCount+"</span></div></div></li>");
+ mainFlexSlider.data('flexslider').addSlide("<li class='slide'><div class='slide_div' resourceId='"+item.id+"' title='"+item.title+"'><img src='"+item.previewURL+"' resourceId='"+item.id+"' title='"+item.title+"'/><div><span class='flex-caption'>"+item.title+"</span></div><div><span class='flex-load-count'>"+item.loadCount+"</span></div></div></li>");
this.removeOldContainer = function(){
More information about the Mapbender_commits
