[Mapbender-commits] r10345 - trunk/mapbender/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 20 09:11:24 PST 2019
Author: armin11
Date: 2019-11-20 09:11:24 -0800 (Wed, 20 Nov 2019)
New Revision: 10345
   trunk/mapbender/http/html/mod_treefolderPlain2019.php
Fix to show symbol for problematic wms in treegde in new gui2019 - thanx to karlo
Modified: trunk/mapbender/http/html/mod_treefolderPlain2019.php
--- trunk/mapbender/http/html/mod_treefolderPlain2019.php	2019-11-20 17:10:31 UTC (rev 10344)
+++ trunk/mapbender/http/html/mod_treefolderPlain2019.php	2019-11-20 17:11:24 UTC (rev 10345)
@@ -1,1159 +0,0 @@
-<?php
-# $Id: mod_treefolder2.php 2975 2008-09-18 12:58:42Z nimix $
-# http://www.mapbender.org/index.php/Mod_treefolder2.php
-# Copyright (C) 2007 Melchior Moos
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-include '../include/dyn_js.php';
-function openwindow (Adresse, width, height) {
-	Fenster1 = window.open(Adresse, '<?php echo _mb("Information");?>', "width="+width+",height="+height+",left=100,top=100,scrollbars=yes,resizable=yes");
-	Fenster1.focus();
-<?php
-	echo "mod_treeGDE_map = '".$e_target[0]."';";
-// <script language="JavaScript">
-var msgObj = {};
-msgObj.tooltipHandleWms = '<?php echo _mb("(De)activate this service");?>';
-msgObj.tooltipLayerVisible = '<?php echo _mb("Toggles the visibility of this service");?>';
-msgObj.tooltipLayerQuerylayer = '<?php echo _mb("Toggles the queryability of this service");?>';
-msgObj.tooltipLayerContextMenu = '<?php echo _mb("Opens the layer context menu");?>';
-msgObj.tooltipWmsContextMenu = '<?php echo _mb("Opens the WMS context menu");?>';
-msgObj.tooltipRemoveWms = '<?php echo _mb("Removes the selected WMS");?>';
-msgObj.tooltipMoveSelectionUp = '<?php echo _mb("Moves the selection up");?>';
-msgObj.tooltipMoveSelectionDown = '<?php echo _mb("Moves the selection down");?>';
-msgObj.tooltipMetadata = '<?php echo _mb("Show metadata");?>';
-msgObj.tooltipFeaturetypeCoupling = '<?php echo _mb("Coupled featuretypes");?>';
-if (typeof(localizetree) === 'undefined')localizetree = 'false';
-function localizeTree () {
-	var treefolderTitleArray = [];
-	var map = Mapbender.modules[mod_treeGDE_map];
-	if (map === null) {
-		return;
-	for(var i = 0; i < map.wms.length; i++) {
-		var currentWms = map.wms[i];
-		treefolderTitleArray.push({
-			title : currentWms.objLayer.length > 0 ?
-				currentWms.objLayer[0].gui_layer_title :
-				currentWms.wms_title,
-			layer : []
-		for (var j = 0; j < currentWms.objLayer.length; j++) {
-			var currentLayer = currentWms.objLayer[j];
-			treefolderTitleArray[treefolderTitleArray.length-1].layer.push({
-				title : currentLayer.gui_layer_title
-	var req = new Mapbender.Ajax.Request({
-		url: "../php/mod_treefolder2_l10n.php",
-		method: "translateServiceData",
-		parameters: {
-			data: treefolderTitleArray
-		callback: function (obj, success, message) {
-			var translatedTitleArray = obj;
-			for (var i = 0; i < translatedTitleArray.length; i++) {
-				currentWms.wms_currentTitle = translatedTitleArray[i].title;
-				for(var j = 0; j < currentWms.objLayer.length; j++) {
-					if (translatedTitleArray[i].layer.length > j) {
-						currentLayer.layer_currentTitle = translatedTitleArray[i].layer[j].title;
-			reloadTree();
-	req.send();
-eventInit.register(function () {
-	localizeTree();
-if (localizetree == 'true') {
-	eventLocalize.register(function () {
-		localizeTree();
-var jst_container = "document.getElementById('treeContainer')";
-var jst_image_folder = imagedir;
-var jst_display_root = false;
-var defaultTarget = 'examplemain';
-var lock=false;
-var lock_update=false;
-var lock_check=false;
-var lock_maprequest = false; //global var to prohibit multiple saving states as wmc to session when loading wmc
-var selectedMap=-1;
-var selectedWMS=-1;
-var selectedLayer=-1;
-var initialized=false;
-var errors = 0;
-var state=Array();
-var treeState = "";
-<?php
-//load structure
-$sql = "SELECT * FROM gui_treegde WHERE fkey_gui_id = $1 AND NOT lft = 1 ORDER BY lft;";
-$v = array(Mapbender::session()->get("mb_user_gui"));
-$t = array("s");
-$res = db_prep_query($sql, $v, $t);
-//init tree converting arrays
-$nr = array(); 			//array for nested sets numbers
-$str = array();			//array for js array elements
-$categories = array();	//array for wms folders
-$path = array();		//stack for actual path elements
-$rights = array();		//stack for rights of open elements
-//build javascript data array for jsTree
-while($row = db_fetch_array($res)){
-	//push javascript array elements to a single array with lefts and rights
-	$left = "['folder_".$row['id']."', ['".$row['my_layer_title']."', 'javascript:_foo()'],[";
-	$right = "]],";
-	array_push($nr, $row['lft']);
-	array_push($str, $left);
-	array_push($nr, $row['rgt']);
-	array_push($str, $right);
-	//finish all nodes that have no further childs
-	while(count($rights) > 0 && $rights[count($rights)-1]<$row['lft']){
-		array_pop($rights);
-		array_pop($path);
-	//set path for each wms that is referenced in this folder
-	array_push($rights, $row['rgt']);
-	array_push($path, "folder_".$row['id']);
-	if($row['wms_id']!=""){
-		foreach(explode(",",$row['wms_id']) as $wms){
-			array_push($categories, "'wms_".$wms."':\"root_id|".implode("|", $path)."\"");
-//if we have a configured structure output it
-if(count($str)>0){
-	//order js array elements
-	array_multisort($nr, $str);
-	//output javascript vars
-	$arrNodesStr = "[['root_id', ['Layer','javascript:_foo()'],[".implode("",$str)."]]];";
-	$arrNodesStr = str_replace(array("[]", ",]"),array("","]"),$arrNodesStr);
-	echo "var arrNodesStr = \"".$arrNodesStr."\";\n";
-	echo "var categories = {".implode(",", $categories)."};\n";
-else{
-//if there is no structure take default
-var arrNodesStr = "[['root_id', ['Layer','javascript:_foo()']]];";
-var categories = {};
-<?php
-var arrNodes = eval(arrNodesStr);
-function _foo(){selectedMap=-1;selectedWMS=-1;selectedLayer=-1}
-// some defaults
-if (typeof(reverse) === 'undefined')reverse = 'false';
-if (typeof(switchwms) === 'undefined')switchwms = 'true';
-if (typeof(ficheckbox) === 'undefined')ficheckbox = 'false';
-if (typeof(metadatalink) === 'undefined')metadatalink = 'false';
-if (typeof(wmsbuttons) === 'undefined')wmsbuttons = 'false';
-if (typeof(showstatus) === 'undefined')showstatus = 'false';
-if (typeof(alerterror) === 'undefined')alerterror = 'false';
-if (typeof(openfolder) === 'undefined')openfolder = 'false';
-if (typeof(handlesublayer) === 'undefined')handlesublayer = 'false';
-if (typeof(enlargetreewidth) === 'undefined') enlargetreewidth = 'false';
-if (typeof(enlargetreewidthopacity) === 'undefined') enlargetreewidthopacity = 'false';
-if (typeof(menu) === 'undefined')menu = '';
-if (typeof(redirectToMetadataUrl) !== 'undefined' && redirectToMetadataUrl == "false") {
-	redirectToMetadataUrl = false;
-else {
-	redirectToMetadataUrl = true;
-if (typeof(datalink) === 'undefined')datalink = 'false';
-if (typeof(featuretypeCoupling) === 'undefined')featuretypeCoupling = 'false';
-if (typeof(metadataWidth) === 'undefined')metadataWidth = '500';
-if (typeof(metadataHeight) === 'undefined')metadataHeight = '500';
-if (typeof(activatedimension) === 'undefined')activatedimension = 'false';
-var defaultMetadataUrl = '../php/mod_showMetadata.php?resource=layer&layout=tabs&';
-if (redirectToMetadataUrl) {
-	defaultMetadataUrl += 'redirectToMetadataUrl=1';
-else {
-	defaultMetadataUrl += 'redirectToMetadataUrl=0';
-//menu elements
-var menu_move_up = ['menu_move_up', ['<?php echo _mb("Move up");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'up.svg']];
-var menu_move_down = ['menu_move_down', ['<?php echo _mb("Move down");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'down.svg']];
-var menu_delete = ['menu_delete', ['<?php echo _mb("Remove");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'trash.svg']];
-var menu_opacity_down = ['menu_opacity_down', ['<?php echo _mb("Opacity down");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'up.svg']];
-var menu_opacity_up = ['menu_opacity_up', ['<?php echo _mb("Opacity up");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'down.svg']];
-var menu_metalink = ['menu_metalink', ['<?php echo _mb("Information");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.svg']];
-var menu_zoom = ['menu_zoom', ['<?php echo _mb("Zoom");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
-var menu_hide = ['menu_hide', ['<?php echo _mb("Hide menu");?> ', 'javascript:hideMenu()',,'clear_white.svg']];
-var menu_style = ['menu_style', ['<?php echo _mb("Change style");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openStyleDialog(ids[0],ids[1],ids[2])',,'styling.svg']];
-var menu_legend = ['menu_legend', ['<?php echo _mb("Legende öffnen");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openLegendHtml(ids[0],ids[1],ids[2])',,'legend_tree.png']];
-//var menu_wms_switch = ['menu_zoom', ['<?php echo _mb("Zoom");?> ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.png']];
-//var menu_layer_switch = ['menu_zoom', ['Zjjj ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.png']];
-//var menu_info_switch = ['menu_zoom', ['Zmn ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.png']];
-//parent.eventMapRequestFailed.register(function(t){imgerror(t)});
-eventAfterLoadWMS.register(reloadTree);
-eventInit.register(registerInitMapCheck);
-Mapbender.events.init.register(function () {
-	$("#" + mod_treeGDE_map).mapbender().events.afterMoveWms.register(reloadTree);
-eventInit.register(loadTree);
-if(showstatus=='true'||alerterror=='true'){
-	//eventAfterMapRequest.register(init_mapcheck);
-	//init_mapcheck();
-eventAfterMapRequest.register(updateScale);
-eventAfterMapRequest.register(updateCheckState);
-function registerInitMapCheck() {
-	if(showstatus=='true'||alerterror=='true'){
-		//console.log("Registrierung init_mapcheck an eventAfterMapRequest");
-		eventAfterMapRequest.register(init_mapcheck);
-if (enlargetreewidth) {
-    eventAfterInit.register(function(){
-        var initialWidth = parseInt($('#treeGDE').css("width"));
-        $('#treeGDE').bind("mouseenter", function(){
-            $(this).css({
-                'width': initialWidth + enlargetreewidth,
-		if (enlargetreewidthopacity) {
-			$(this).css({
-				'-moz-opacity': '1',
-				'opacity': '1',
-				'filter': 'alpha(opacity=100)'
-            $(this).mousewheel();
-        $('#treeGDE').bind("mouseleave", function(){
-            $(this).css({
-                'width': initialWidth,
-			$(this).css({
-				'opacity': '1',
-if(wmsbuttons != "true")
-	jst_highlight = false;
-function select(i,ii,iii){
-	//ignore if selected
-	if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
-	if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1){
-		selectedMap=i;
-		selectedWMS=ii;
-		selectedLayer=iii;
-		return;
-	//scalehints
-	var scale = parseInt(mb_getScale(mod_treeGDE_map));
-	if(scale < parseInt(mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) && parseInt(mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) != 0){
-		if(selectedLayer==0)
-		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '#999999');
-		else
-		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+ mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '#999999');
-	else if(scale > parseInt( mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) && parseInt( mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) != 0){
-		else
-	else{
-		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '');
-		else
-		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+ mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '');
-	selectedMap=i;
-	selectedWMS=ii;
-function updateScale(){
-	if(!initialized)return;
-	myMapObj = getMapObjByName(mod_treeGDE_map);
-	if(myMapObj){
-		var scale = parseInt( myMapObj.getScale());
-		for(var ii=0; ii< myMapObj.wms.length; ii++){
-			for(var iii=1; iii< myMapObj.wms[ii].objLayer.length; iii++){
-				if(scale < parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_minscale) && parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_minscale) != 0){
-						if(iii==0)
-					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id, '#999999');
-						else
-					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id+"|"+ myMapObj.wms[ii].objLayer[iii].layer_id, '#999999');
-				else if(scale > parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
-						if(iii==0)
-						else
-					else{
-						if(iii==0)
-					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id, '');
-						else
-					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id+"|"+ myMapObj.wms[ii].objLayer[iii].layer_id, '');
-function updateCheckState(){
-	if(!initialized||lock_check)return;
-	lock_check=true;
-	var map = getMapObjByName(mod_treeGDE_map);
-	for(var i=0; i< mb_mapObj.length; i++){
-		var scale = parseInt( map.getScale());
-		if( mb_mapObj[i].elementName == mod_treeGDE_map){
-			for(var ii=0; ii< mb_mapObj[i].wms.length; ii++){
-				for(var iii=1; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
-					if(! mb_mapObj[i].wms[ii].objLayer[iii].has_childs){
-						path = arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ii].wms_id+"|"+ mb_mapObj[i].wms[ii].objLayer[iii].layer_id;
-						checkNode(path, 0,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible==='1'||mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible===1, false);
-						if(ficheckbox == 'true')
-							checkNode(path, 1,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer=='1', false);
-	lock_check=false;
-function operaLoad(){
-	initArray();
-	renderTree();
-	setTimeout('initWmsCheckboxen();updateScale();',100);
-function loadTree(){
-	if(wmsbuttons=='true'){
-		var div = document.createElement("div");
-		div.innerHTML = '<a href="javascript:move_up()"><img title="'+msgObj.tooltipMoveSelectionUp+'" src="'+imagedir+'/up.svg" alt="move up" style="position:relative;top:0px;left:0px;"/></a><a href="javascript:move_down()"><img title="'+msgObj.tooltipMoveSelectionDown+'" src="'+imagedir+'/down.svg" alt="move down" style="position:relative;top:0px;left:-3px"/></a><a href="javascript:remove_wms()"><img title="'+msgObj.tooltipRemoveWms+'" src="'+imagedir+'/delete_wms.png" alt="remove wms" style="position:relative;top:0px;left:-6px"/></a>';
-		document.getElementById("treeGDE").appendChild(div);
-	div.id = "treeContainer"
-	if(window.opera){
-		setTimeout('operaLoad()',200);
-		return;
-	initArray();
-	renderTree();
-	initWmsCheckboxen();
-	updateScale();
-function reloadTree(){
-	if(!initialized) return;
-	selectedMap=-1;
-	selectedWMS=-1;
-	selectedLayer=-1;
-	initialized=false;
-	arrNodes = eval(arrNodesStr)
-	initArray();
-	renderTree();
-	if(window.opera)
-	else{
-		updateScale();
-	Mapbender.events.treeReloaded.trigger();
-function imgerror(wms, path, imgObj){
-	var map= getMapObjIndexByName(mod_treeGDE_map);
-	//t.onerror=null;
-	//t.onabort=null;
-	if(state[wms]!=-1 && alerterror=='true'){
-		state[wms]=-1;
-		var errorMsg = '<?php echo _mb("Failed to load WMS");?> ' + mb_mapObj[map].wms[wms].objLayer[0].layer_currentTitle;
-		$('<div id="imgErrorDialog">' + errorMsg + ':<iframe style="width:90%;height:90%;" src="' + imgObj.attr("src") + '"></iframe></div>').dialog();
-		checkNode(path, 0, false);
-		/*if(confirm('<?php echo _mb("Failed to load WMS");?> ' +
-			mb_mapObj[map].wms[wms].objLayer[0].layer_currentTitle +
-			'\n<?php echo _mb("Do you want to try to load it in a new window?");?>')) {
-			window.open(imgObj.attr("src"),"");
-	state[wms]=-1;
-	errors++;
-	if(showstatus=='true')
-		setNodeImage(arrNodes[0][0]+"|wms_"+ mb_mapObj[map].wms[wms].wms_id, "error_folder.png");
-function checkComplete(wms, map, img, first){
-	var ind= getMapObjIndexByName(mod_treeGDE_map);
-	if (mb_mapObj[ind].wms[wms].mapURL == false ||
-		!mb_mapObj[ind].getDomElement().ownerDocument.getElementById(map) ||
-		mb_mapObj[ind].getDomElement().ownerDocument.getElementById(map).complete) {
-		if(state[wms]!=-1){
-			for(var i=1;i< mb_mapObj[ind].wms[wms].objLayer.length;i++){
-				if(mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible===1||mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==="1"){
-					state[wms]=1;
-						setNodeImage(img);
-						//Removes the previous Maprequest image from dom
-						var prevlastRequestDiv = $("#"+mod_treeGDE_map+"_maps > div:last").prev().attr("id");
-						var prevWmsgid=prevlastRequestDiv+"_map_"+wms;
-						var $prevWmsgid=$("#"+prevWmsgid);
-						$prevWmsgid.remove();
-					break;
-	else{
-		if(first){
-			state[wms]=0;
-			$("#" + map).error(function () {
-				imgerror(wms, img, $(this));
-			//$(map).onabort=imgerror;
-				setNodeImage(img, "clock.svg");
-			setTimeout('checkComplete('+wms+', "'+map+'", "'+img+'");',100);
-// mb_registerWmsLoadErrorFunctions("window.frames['treeGDE'].imgerror();");
-function init_mapcheck(){
-	errors = 0;
-	var ind =  getMapObjIndexByName(mod_treeGDE_map);
-	if(! mb_mapObj[ind]||!initialized){
-		setTimeout("init_mapcheck();",100);
-		return;
-	for(var wms=0;wms< mb_mapObj[ind].wms.length;wms++){
-		var lastRequestDiv = $("#"+mod_treeGDE_map+"_maps > div:last" ).attr("id");
-		var wmsimgid=lastRequestDiv+"_map_"+wms;
-		if( mb_mapObj[ind].getDomElement().ownerDocument.getElementById(wmsimgid)){
-			checkComplete(wms, wmsimgid, arrNodes[0][0]+'|wms_'+ mb_mapObj[ind].wms[wms].wms_id, true);
-function local_handleSelectedLayer(mapObj,wms_id,layername,type,status){
-	if(lock_update||lock_check)return;
-	var ind =  getMapObjIndexByName(mapObj);
-	for(var i=0; i< mb_mapObj[ind].wms.length; i++){
-		if( mb_mapObj[ind].wms[i].wms_id == wms_id){
-			mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
-			break;
-function zoomToLayer(j,k,l){
-	if(!j&&!k&&!l){
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-	var my= mb_mapObj[j].wms[k].objLayer[l].layer_epsg;
-	for (var i=0; i < my.length;i++) {
-		if(my[i]["epsg"]== mb_mapObj[j].epsg){
-			mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
-			var arrayExt =  mb_mapObj[j].extent.toString().split(",");
-			mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
-			//mb_repaint(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
-			break;
-function openLegendHtml(j,k,l){
-	if(!j && !k&& !l){
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-	var my= mb_mapObj[j].wms[k].objLayer[l];
-	var legendWindow = window.open("../metadata/"+my.layer_name+".html", '<?php echo _mb("Legend");?>', "width=800,height=800,left=100,top=100,scrollbars=yes,resizable=no");
-	legendWindow.focus();
-function openStyleDialog(j,k,l){
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-	var dialogHtml = "<select id='styleSelect'>";
-	for (var i=0;i < my.layer_style.length;i++) {
-		dialogHtml += "<option value='" + my.layer_style[i].name + "'";
-		if(my.layer_style[i].name == my.gui_layer_style) {
-			dialogHtml += " selected";
-		dialogHtml += ">" + my.layer_style[i].title + "</option>";
-	dialogHtml += "</select>";
-	if(my.layer_style.length > 1) {
-		$("<div id='changeStyleDialog' title='<?php echo _mb('Change layer style');?>'><?php echo _mb('Please select a style');?>: </div>").dialog(
-				bgiframe: true,
-				autoOpen: true,
-				modal: false,
-				buttons: {
-					"<?php echo _mb('Close');?>": function(){
-						$(this).dialog('close').remove();
-		$(dialogHtml).appendTo("#changeStyleDialog");
-		$("#styleSelect").change(function() {
-			my.gui_layer_style = this.options[this.selectedIndex].value;
-			Mapbender.modules[mod_treeGDE_map].setMapRequest();
-	else {
-		alert("<?php echo _mb('There is no different style available for this layer.');?>");
-//---begin------------- opacity --------------------
-var opacityIncrement = 20;
-function opacity_up(j, k, l) {
-	handleOpacity(j, k, opacityIncrement);
-function opacity_down(j, k, l) {
-	handleOpacity(j, k, -opacityIncrement);
-function handleOpacity(mapObj_id, wms_id, increment) {
-	var opacity =  mb_mapObj[mapObj_id].wms[wms_id].gui_wms_mapopacity*100 + increment;
-	mb_mapObj[mapObj_id].wms[wms_id].setOpacity(opacity);
-	reloadTree();
-//---end------------- opacity --------------------
-function move_up(j,k,l){
-	if(isNaN(j)&&isNaN(k)&&isNaN(l)){
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-	if(j==-1||k==-1||l==-1){
-		alert("<?php echo _mb('You have to select the WMS you want to move up!');?> ")
-		return;
-	var lid= mb_mapObj[j].wms[k].objLayer[l].layer_id;
-	if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
-		alert("<?php echo _mb('Illegal move operation');?>");
-		return;
-	treeState = getState();
-	 mb_mapObj[j].zoom(true, 1.0);
-	 mb_execloadWmsSubFunctions();
-	//find layer and select
-	for(k=0;k< mb_mapObj[j].wms.length;k++){
-		for(l=0;l< mb_mapObj[j].wms[k].objLayer.length;l++){
-			if( mb_mapObj[j].wms[k].objLayer[l].layer_id==lid){
-				select(j,k,l);
-				if(l!=0)
-					selectNode(String(lid));
-				else
-					selectNode("wms_"+String( mb_mapObj[j].wms[k].wms_id));
-function move_down(j,k,l){
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-		alert("<?php echo _mb('You have to select the WMS you want to move down!');?>")
-		return;
-	if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
-		return;
-				select(j,k,l);
-				if(l!=0)
-				else
-function remove_wms(j,k,l){
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-		alert("<?php echo _mb('You have to select the WMS you want to delete!');?>")
-		return;
-	if(l!=0){
-		alert("<?php echo _mb('It is not possible to delete a single layer, please select a WMS!');?>")
-		return;
-	var visibleWMS=0;
-	for(var i=0;i< mb_mapObj[j].wms.length;i++)
-		if( mb_mapObj[j].wms[i].gui_wms_visible==='1'|| mb_mapObj[j].wms[i].gui_wms_visible===1)
-			visibleWMS++;
-	if(visibleWMS<=1){
-		alert ("<?php echo _mb('Last WMS can not be removed.');?>");
-		return;
-	if(confirm('<?php echo _mb("Are you sure you want to remove");?>' + ' "'+ mb_mapObj[j].wms[k].objLayer[l].layer_currentTitle+'"?')){
-  		 mb_mapObjremoveWMS(j,k);
-		 lock_maprequest = true; //done to prohibit save wmc for each wms
-		 lock_maprequest = false;
-function updateParent(path){
-	if(lock_check)return;
-	var reset_lock=!lock_update;
-	lock_update=true;
-	var state=getChildrenCheckState(path, 0);
-	//enableCheckbox(path, (state!=-1)); //3rd state
-	checkNode(path, 0, (state==1));
-	if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
-		setTimeout('setNodeImage("'+path+'", "eye_off.svg");', 100);
-	else{
-		setTimeout('setNodeImage("'+path+'", "verticaldots.svg");', 100);
-	if(reset_lock){
-		lock_update=false;
-	handleSelectedWMS(path, true);
-function handleSelectedWMS(path){
-	if(lock_update)return;
-	var t = path.split("|");
-	var wms_id = t[t.length-1].substr(4);
-	var reset_lock=!lock_check;
-	var wms =  getWMSIndexById(mod_treeGDE_map,wms_id);
-	var layername =  mb_mapObj[ind].wms[wms].objLayer[0].layer_name;
-	var bChk = IsChecked(path, 0);
-	// in this case, only the root layer visibility/querylayer
-	// needs to be adjusted, without cascading the changes to
-	// its children
-	if (arguments.length === 2 && arguments[1]) {
-		var l = mb_mapObj[ind].wms[wms].getLayerByLayerName(layername);
-		l.gui_layer_visible = bChk ? 1 : 0;
-		l.gui_layer_querylayer = bChk ? 1 : 0;
-		mb_restateLayers(mod_treeGDE_map,wms_id);
-		if (!lock_maprequest) {
-			setSingleMapRequest(mod_treeGDE_map,wms_id);
-		return;
-	mb_mapObj[ind].wms[wms].handleLayer(layername,"visible",bChk?"1":"0");
-	mb_mapObj[ind].wms[wms].handleLayer(layername,"querylayer",bChk?"1":"0");
-	lock_check=true;
-	checkChildren(path, 0, bChk);
-	if(ficheckbox)checkChildren(path, 1, bChk);
-	if(bChk==false && showstatus=='true'){
-	else{
-	if(reset_lock)
-		lock_check=false;
-function handleSelection(path, box){
-	lock_check=true;
-	var bChk = IsChecked(path, box);
-//	enableCheckbox(path, 0, true);
-	checkChildren(path, box, bChk);
-	if(reset_lock){
-		//find wms id from path
-		for(var i=1;t[i].indexOf("wms_")!=0;i++){}
-		var wms_id = t[i].substr(4);
-		//set maprequest
-		if(box==0)
-		lock_check=false;
-function setDimensionUserValue(j,k,l,dimensionIndex,userValue) {
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-	var my = mb_mapObj[j].wms[k].objLayer[l];
-	var myWms = mb_mapObj[j].wms[k];
-	//delete all userValues from other layers of this wms
-	for (var k=0;k< myWms.objLayer.length;k++) {
-		for (var i=0;i< myWms.objLayer[k].layer_dimension.length;i++) {
-			myWms.objLayer[k].layer_dimension[i].userValue = "";
-	my.layer_dimension[dimensionIndex].userValue = userValue;
-	//openfolder = true;
-	reloadTree();
-//function for buggy servers which do not support real iso8601 patterns for UTC :-(
-function makeDateTimeBetter(dateTimeIso) {
-	return dateTimeIso.replace('+00:00','Z');
-function snapToDiscreteValue(userValue,extent) {
-	//call it via sync ajax call :-(
-	transformUrl = '../php/mod_transformTimeDimension.php?operation=snapToGrid&userValue='+encodeURIComponent(userValue);
-	var response = $.ajax({
-		url: transformUrl,
-		type: "POST",
-        	async: false,
-		data: {
-			'extent':extent,
-    		success: function (data) {
-			return data;
-		error: function() {
-			alert("An error occured!");
-	}).responseText;
-	var jsonValue = JSON.parse(response);
-	return jsonValue.data[0].value;
-function openDimensionSelectHtml(j,k,l,dimensionIndex) {
-		j=selectedMap;
-		k=selectedWMS;
-		l=selectedLayer;
-	$("#selectDimensionDialog").remove();
-	//extract/calculate discrete values for time!
-	var userValue = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].userValue; //not already defined in mapobj!!
-	var extent = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].extent;
-	var dimdefault = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].default;
-	var dialogHtml = "<div id='timeline'></div>";
-	$("<div id='selectDimensionDialog' title='<?php echo _mb('Select layer dimension');?>'><?php echo _mb('Please select a value for TIME. One single element can be dragged on timeline after selection. Scale may be altered by scrolling.');?>: </div>").dialog(
-			bgiframe: true,
-			autoOpen: true,
-			modal: false,
-			width: 400,
-			closeOnEscape: false,
-			open: function(event, ui) { $( "div[aria-labelledby='ui-dialog-title-selectDimensionDialog']" ).children().children(".ui-dialog-titlebar-close").hide()}, //hide closing x - but only for element with special id!!!
-			buttons: {
-					$('selectDimensionDialog').remove();
-					//delete container, items, timeline
-	$(dialogHtml).appendTo("#selectDimensionDialog");
-	//fill timeline into div
-	if (userValue !== undefined && userValue !== false && userValue !== "" && userValue !== "undefined") {
-		userValue = makeDateTimeBetter(userValue);
-		transformUrl = '../php/mod_transformTimeDimension.php?userValue='+encodeURIComponent(userValue)+'&default='+encodeURIComponent(dimdefault);
-	} else {
-		transformUrl = '../php/mod_transformTimeDimension.php?default='+encodeURIComponent(dimdefault);
-	  $.ajax({
-		type: "POST",
-		data: {
-			'extent': extent,
-      			// hide the "loading..." message
-     			//document.getElementById('loading').style.display = 'none';
-      			// DOM element where the Timeline will be attached
-     			var container = document.getElementById('timeline');
-      			// Create a DataSet (allows two way data-binding)
-      			var items = new vis.DataSet(data.data);
-      			// Configuration for the Timeline
-      			var options = data.options;
-			//check if onclick or onmove should be enabled
-			if (data.options.editable.updateTime !== 'undefined' && data.options.editable.updateTime == true) {
-				options.onMove = function (item,callback) {
-					//calculate new value for item start based on snapping to period from extent
-					item.start = new Date(snapToDiscreteValue(item.start.toISOString(),extent));
-					item.content = item.start.toISOString();
-					myWms.gui_wms_dimension_time = makeDateTimeBetter(item.start.toISOString());
-					setDimensionUserValue(j,k,l,dimensionIndex,myWms.gui_wms_dimension_time);
-					Mapbender.modules[mod_treeGDE_map].setSingleMapRequest(mod_treeGDE_map,mb_mapObj[j].wms[k].wms_id);
-					callback(item);
-			} else {
-				options.editable = false;
-      			// Create a Timeline
-      			var timeline = new vis.Timeline(container, items, options);
-			//if (data.options.editable.updateTime == 'undefined' || data.options.editable.updateTime == false) {
-				timeline.on('select', function (properties) {
-					if (properties.event.type == "tap") {
-						myWms.gui_wms_dimension_time = makeDateTimeBetter(timeline.itemsData._data[timeline.getSelection()].content);
-    		error: function (err) {
-      			//console.log('Error', err);
-      			if (err.status === 0) {
-        			alert('Failed to load json for configuration of timeline from server.\nPlease contact your portal administrator!');
-      			else {
-        			alert('Failed to load json from server.');
-function initArray(){
-	var parentObj = "";
-	var controls="";
-	if( mb_mapObj.length > 0){
-					if( mb_mapObj[i].wms[ii].gui_wms_visible === '1' ||  mb_mapObj[i].wms[ii].gui_wms_visible === 1){
-						for(var iii=0; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
-							var temp =  mb_mapObj[i].wms[ii].objLayer[iii];
-							if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
-								if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
-									continue;
-								parentNode = arrNodes[0][0];
-								if(eval("categories.wms_"+ mb_mapObj[i].wms[ii].wms_id) !== undefined)
-									parentNode = eval("categories.wms_"+ mb_mapObj[i].wms[ii].wms_id);
-								else
-									eval("categories['wms_"+ mb_mapObj[i].wms[ii].wms_id+"'] = parentNode");
-								var c_menu="[";
-								if(reverse=="true"){
-									if(menu.indexOf("wms_down")!=-1 && ii!= mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
-									if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_down,";
-								else{
-									if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
-									if(menu.indexOf("wms_down")!=-1 && ii!= mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
-								if(menu.indexOf("remove")!=-1)c_menu+="menu_delete,";
-//								if(menu.indexOf("wms_switch")!=-1)c_menu+="menu_wms_switch,";
-								if(menu.indexOf("opacity_up")!=-1 && parseFloat( mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)c_menu+="menu_opacity_up,";
-								if(menu.indexOf("opacity_down")!=-1 && parseFloat( mb_mapObj[i].wms[ii].gui_wms_mapopacity) > 0)c_menu+="menu_opacity_down,";
-								if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
-								c_menu+="]";
-								controls='';
-								if(switchwms=='true')controls='<INPUT type="checkbox" title="' + msgObj.tooltipHandleWms + '"  onclick="handleSelectedWMS(\''+parentNode+'|wms_'+ mb_mapObj[i].wms[ii].wms_id+'\');" />';
-								if(metadatalink == 'true'){
-									controls+='<a class="metadata_link" href="'+defaultMetadataUrl + '&id='+temp.layer_uid+'"'+' target=\'_blank\' onclick="metadata_window = window.open(this.href,\'Metadata\',\'Width=700, Height=550,scrollbars=yes,menubar=yes,toolbar=yes\'); metadata_window.focus(); return false;"><img alt="'+msgObj.tooltipMetadata+'" title="'+msgObj.tooltipMetadata+'" src="'+imagedir+'/info.svg" /></a>';
-								addNode(parentNode,["wms_"+ mb_mapObj[i].wms[ii].wms_id,[temp.layer_currentTitle,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\",'+metadataWidth+','+metadataHeight+');'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_currentTitle,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
-								parentObj = parentNode+"|wms_"+ mb_mapObj[i].wms[ii].wms_id;
-							if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"|| mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
-								var parentLayer = "";
-								var j = iii;
-								while( mb_mapObj[i].wms[ii].objLayer[j].layer_parent!="0"){
-									//find parent
-									for(var jj=0; jj <  mb_mapObj[i].wms[ii].objLayer.length; jj++){
-										if( mb_mapObj[i].wms[ii].objLayer[jj].layer_pos==parseInt( mb_mapObj[i].wms[ii].objLayer[j].layer_parent)){
-											j=jj;
-											break;
-									parentLayer = "|" +  mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
-								if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
-									var c_menu="[";
-										if(menu.indexOf("layer_down")!=-1 && iii!= mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
-										if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_down,";
-									else{
-										if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
-										if(menu.indexOf("layer_down")!=-1 && iii!= mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
-									if(menu.indexOf("metainfo")!=-1)c_menu+="menu_metalink,";
-									if(menu.indexOf("zoom")!=-1 && temp.layer_epsg.length>0)c_menu+="menu_zoom,";
-//									if(menu.indexOf("layer_switch")!=-1)c_menu+="menu_layer_switch,";
-//									if(menu.indexOf("info_switch")!=-1)c_menu+="menu_info_switch,";
-									if(menu.indexOf("hide")!=-1)c_menu+="menu_hide,";
-									if(menu.indexOf("change_style")!=-1)c_menu+="menu_style,";
-									if(menu.indexOf("legend")!=-1)c_menu+="menu_legend";
-									c_menu+="]";
-									controls = [];
-									controls.push('<input type="checkbox"  title="' + msgObj.tooltipLayerVisible + '" ');
-									if(temp.layer_name=="")
-										controls.push('style="display:none;" ');
-									if(temp.gui_layer_visible==='1' ||temp.gui_layer_visible===1){
-										controls.push('checked ');
-									if(temp.gui_layer_selectable!='1')
-										controls.push('disabled ');
-									controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
-									if(ficheckbox == 'false')
-										controls.push("local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
-									controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);");
-									controls.push("updateParent('"+parentObj+parentLayer+"');\" />");
-									if(ficheckbox == 'true'){
-										controls.push('<input type="checkbox" title="' + msgObj.tooltipLayerQuerylayer + '" ');
-										if(temp.gui_layer_querylayer=='1')
-										if(temp.gui_layer_queryable!='1')
-										controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
-										controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
-									if(wmsbuttons == 'true'&&metadatalink == 'true'){
-										controls.push('<a href="'+defaultMetadataUrl + '&id='+temp.layer_uid+'"'+' target=\'_blank\' onclick="metadata_window = window.open(this.href,\'Metadata\',\'Width=700, Height=550,scrollbars=yes,menubar=yes,toolbar=yes\');metadata_window.focus(); return false;"><img alt="'+msgObj.tooltipMetadata+'" title="'+msgObj.tooltipMetadata+'" src="'+imagedir+'/info.svg" /></a>');
-									if(datalink == 'true' && mb_mapObj[i].wms[ii].objLayer[iii].layer_dataurl != ''){
-										controls.push('<a href="'+mb_mapObj[i].wms[ii].objLayer[iii].layer_dataurl+'"'+' target=\'_blank\' onclick="download_window = window.open(this.href,\'Download Data\',\'Width=450, Height=350,scrollbars=yes,menubar=yes,toolbar=yes\'); download_window.focus(); return false;"><img class="treegde2019" width="18" height="18" alt="'+msgObj.tooltipDownload+'" title="'+msgObj.tooltipDownload+'" src="'+imagedir+'/download.svg" /></a>');
-//if (typeof mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling == 'undefined') {
-//alert(mb_mapObj[i].wms[ii].objLayer[iii].layer_title+': '+JSON.stringify(mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling));
-									if(featuretypeCoupling == 'true' && mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling != ''){
-//alert(mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling);
-										//controls.push('<a href="'+mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling+'"'+' target=\'_blank\' onclick="featuretype_window = window.open(this.href,\'Featuretype Data\',\'Width=450, Height=350,scrollbars=yes,menubar=yes,toolbar=yes\'); featuretype_window.focus(); return false;"><img width="18" height="18" alt="'+msgObj.tooltipFeaturetypeCoupling+'" title="'+msgObj.tooltipFeaturetypeCoupling+'" src="'+imagedir+'/../gnome/accessories-dictionary.png" /></a>');
-										controls.push('<img width="18" height="18" coupling="'+btoa(mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling)+'" onclick="alert(atob(this.getAttribute(\'coupling\')))" alt="'+msgObj.tooltipFeaturetypeCoupling+'" title="'+msgObj.tooltipFeaturetypeCoupling+'" src="'+imagedir+'/../osgeo_graphics/geosilk/application_view_columns.png" />');
-										//controls.push('<img width="18" height="18" onclick="alert('+mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling+');" alt="'+msgObj.tooltipFeaturetypeCoupling+'" title="'+msgObj.tooltipFeaturetypeCoupling+'" src="'+imagedir+'/../osgeo_graphics/geosilk/application_view_columns.png" />');
-									//dimension buttons
-									if (activatedimension == 'true') {
-										timeDimensionAvailable = false;
-										timeDimensionIndex = false;
-										elevationDimensionAvailable = false;
-										elevationDimensionIndex = false;
-										//check for existence of time and/or elevation name attribute in dimension
-										for (dimensionIndex = 0; dimensionIndex < mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension.length; ++dimensionIndex) {
-											switch (mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].name) {
-												case "time":
-													timeDimensionAvailable = true;
-													timeDimensionIndex = dimensionIndex;
-													timeUserValue = mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].userValue;
-													break;
-												case "elevation":
-													elevationDimensionAvailable = true;
-													elevationDimensionIndex = dimensionIndex;
-													elevationUserValue = mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].userValue;
-													break;
-										if (timeDimensionAvailable === true) {
-											text = JSON.stringify(mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[timeDimensionIndex]);
-											controls.push('<img onclick="openDimensionSelectHtml('+i+','+ii+','+iii+','+timeDimensionIndex+');" width="16" height="16" alt="'+msgObj.tooltipTimeDimension+'" title="Zeitpunkt wählen" style="cursor:pointer;margin:8px 5px -5px 0px" src="'+imagedir+'/clock.svg" />');
-											if (timeUserValue !== undefined && timeUserValue !== false && timeUserValue !== "" && timeUserValue !== "undefined") {
-											controls.push('<b>'+timeUserValue+'</b>');
-											//set gui_wms_dimension_time to value of layer - only one layer of a wms should have the userValue defined - if more have this, the last one will overwrite all earlier!
-											mb_mapObj[i].wms[ii].gui_wms_dimension_time = timeUserValue;
-									var groupedImageStyle ='';
-									if (temp.has_childs == true){
-										groupedImageStyle ='verticaldots.svg';
-									else{
-									addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_currentTitle,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\",'+metadataWidth+','+metadataHeight+');'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?groupedImageStyle:null),temp.layer_currentTitle,eval(c_menu),controls.join(""),[i,ii,iii]]],false,false,reverse=="true");
-	initialized=true;
-//https://stackoverflow.com/questions/4253367/how-to-escape-a-json-string-containing-newline-characters-using-javascript
-// implement JSON stringify serialization
-JSON.stringify = JSON.stringify || function (obj) {
-    var t = typeof (obj);
-    if (t != "object" || obj === null) {
-        // simple data type
-        if (t == "string") obj = '"'+obj+'"';
-        return String(obj);
-    else {
-        // recurse array or object
-        var n, v, json = [], arr = (obj && obj.constructor == Array);
-        for (n in obj) {
-            v = obj[n]; t = typeof(v);
-            if (t == "string") v = '"'+v+'"';
-            else if (t == "object" && v !== null) v = JSON.stringify(v);
-            json.push((arr ? "" : '"' + n + '":') + String(v));
-        var rawString = (arr ? "[" : "{") + String(json) + (arr ? "]" : "}");
-       return rawString;
-function escape (key, val) {
-    if (typeof(val)!="string") return val;
-    var replaced = encodeURIComponent(val);
-    return replaced;
-JSON.stringifyEscaped = function(obj){
-    return JSON.stringify(obj,escape);
-function initWmsCheckboxen(){
-	var hidden=0;
-								updateParent(arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ii].wms_id);
-					else if(ii<= parseInt(openfolder, 10)+hidden)
-						hidden++;
-				closeAll();
-				var openFolderIndex = parseInt(openfolder, 10) + hidden;
-				if(treeState!='') {
-					setState(treeState);
-				else if(openfolder!=='false' && openFolderIndex < mb_mapObj[i].wms.length && openFolderIndex >= 0) {
-					setState(arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ openFolderIndex].wms_id);
More information about the Mapbender_commits mailing list
