[Mapbender-commits] r10350 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 21 02:36:05 PST 2019
Author: armin11
Date: 2019-11-21 02:36:04 -0800 (Thu, 21 Nov 2019)
New Revision: 10350
Added:
   trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php
Removed:
   trunk/mapbender/http/plugins/mod_metadataCarousel.php
Switch from flexslider to tiny-slider
Deleted: trunk/mapbender/http/plugins/mod_metadataCarousel.php
--- trunk/mapbender/http/plugins/mod_metadataCarousel.php	2019-11-21 10:32:30 UTC (rev 10349)
+++ trunk/mapbender/http/plugins/mod_metadataCarousel.php	2019-11-21 10:36:04 UTC (rev 10350)
@@ -1,288 +0,0 @@
-<?php
- * Package: mod_metadataCarousel
- * Description:
- * This modul generates a div with a dynamic slider to allow the selection
- * of single loadable metadata resources - wmc, ...
- * The module shoudl be invoked thru a button click. The button may be a mb_button.js module
- * see also mod_WMSpreferencesDiv or overview toogle
- * Files:
- *  - http/plugins/mod_metadataCarousel.php
- * SQL:
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-$e_id = 'metadataCarousel';
-//include all element vars from the given element
-include '../include/dyn_js.php';
-include '../include/dyn_php.php';
-//if we need some other elements fom the database - do the stuff
-//echo "var mod_gui_wms_visible = '".$vis."';";
-options.loadMessage = "<?php echo _mb('Load theme');?>";
-//load options from element vars - if not already be done before
-//element_vars we need
-// 1. script name of the searchInterface to use
-// 2. slidesPerSide - number of tiles to show together
-// 3. maxResults - number of objects to get from the searchInterface with one call (should be a factor of 2. )
-// 4. resource type - wmc/layer
-// 5. list of resource ids to filter {[1,2,3]}
-// 6. size of images, ...
-// 7. allowResize - like in loadwmc cause a function is borrowed from there
-options.resourceFilter = "[3,11,12]";
-options.resourceFilter = "[]";
-if (options.allowResize == "true") {
-    options.allowResize = true;
-} else {
-    options.allowResize = false;
-if (Number.isInteger(options.maxResults)) {
-} else {
-    options.maxResults = 12;
-if (Number.isInteger(options.slidesPerSide)) {
-} else {
-    options.slidesPerSide = 3;
-if (typeof options.searchUrl == 'undefined') {
-    options.searchUrl = "../php/mod_callMetadata.php?";
-} else {
-    //alert(options.searchUrl);
-var metadataCarousel = function() {
-    var that = this;
-    this.id = options.id; //id of the upper div tag from mapbender element
-    this.resourceFilter = JSON.parse(options.resourceFilter);
-    if (this.resourceFilter.length > 0){
-        this.resourceFilterString = "&resourceIds="+this.resourceFilter.join(',');
-    } else {
-        this.resourceFilterString = "";
-    this.initForm = function() {
-        //this.flexsliderContainer = $(document.createElement('div')).attr({'id': 'container'}).appendTo('#' + options.id);
-        this.flexsliderContainer = $('#metadataCarousel');
-	this.flexsliderContainer.addClass('flexslider');
-	this.slidesContainer = $(document.createElement('ul')).appendTo(this.flexsliderContainer);
-        this.slidesContainer.addClass('slides');
-        //this.slidesContainer.addClass('temporary');
-        //hide during initialization
-        $('#' + options.id).hide();
-        //first dummy entries ;-)
-        this.slidesContainer.append("<li><img src='../img/mapbender_logo.png' /><p class='flex-caption'>Mapbender 1</p></li><li><img class='' src='../img/mapbender_logo.png' /><p class='flex-caption'>Mapbender 2</p></li><li><img src='../img/mapbender_logo.png' /><p class='flex-caption'>Mapbender 3</p></li><li><img src='../img/mapbender_logo.png' /><p class='flex-caption'>Mapbender 4</p></li>");
-    var targetName = options.target;
-    //var showMoreButtonText = "Show more";
-    var maxResults = options.maxResults;
-    var currentPage = 0;
-    var maxPages = 1;
-    var numberOfResults = 0;
-    var searchUrl = options.searchUrl;
-    //var searchUrl = "../php/mod_callMetadataRemote.php?";
-    var slidesPerSide = options.slidesPerSide;
-    //first init form - hopefully that is done fast
-    that.initForm();
-    this.loadMore = function(){
-        //alert("actual_loaded_page: "+currentPage+" - max pages: "+maxPages); 1-10 (100)
-        //hide further loading button while loading more data
-        //$('.show_more_button').hide();
-        //load next page
-        $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&searchPages="+(parseInt(currentPage) + parseInt(1))+"&maxResults="+maxResults+that.resourceFilterString, async: false, success: function(result){
-        result.wmc.srv.forEach(that.addElementToSlider);
-        //increase global var currentPage
-        currentPage = parseInt(currentPage) + parseInt(1);
-        //unbind all old click events
-        $('.slide_div').unbind('click');
-        //reinitialize click event
-        $('.slide_div').click(function(){
-            var $this = $(this);
-            resourceId = $this.attr("resourceid");
-            resourceTitle = $this.attr("title");
-            alert(options.loadMessage + ": " + resourceTitle);
-            that.executeJavaScript({method:"loadWmc", parameters:{id:resourceId}});
-    //show loading button again
-    /*$('.show_more_button').show();
-    $('.show_more_button').attr("value", "1-"+parseInt(currentPage)*parseInt(maxResults)+" ("+numberOfResults+") - "+showMoreButtonText);
-    if (parseInt(currentPage)*parseInt(maxResults) >= parseInt(numberOfResults)) {
-        $('.show_more_button').attr("value", "1-"+numberOfResults+" ("+numberOfResults+")");
-        $('.show_more_button').unbind('click');
-    //var mainFlexSlider = $('#'+this.id);
-    var mainFlexSlider = $('.flexslider');
-    //alert("slidesPerSide: "+slidesPerSide);
-    mainFlexSlider.flexslider({
-        animation: "slide",
-        animationLoop: false,
-        itemWidth: 160,
-        itemMargin: 5,
-        maxItems: slidesPerSide,
-        pausePlay: false,
-        slideshow: false,
-        //isFirefox: true,
-        start: function(slider){
-                that.loadWmcById(resourceId);
-            $('.slide').unbind('click');
-        end: function(slider){
-            that.loadMore();
-    this.fillInitialMetadata = function() {
-        //initialize slider from first request to search interface
-        var initialResult = $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&maxResults="+maxResults+that.resourceFilterString, async: false, success: function(result){
-            if (result.valid)
-                return true;
-            else
-                return false;
-        var initialSearchJson = JSON.parse(initialResult.responseText);
-        //extract number of currrent page, rpp and max results
-        currentPage = initialSearchJson.wmc.md.p;
-        numberOfResults = initialSearchJson.wmc.md.nresults;
-        maxPages = Math.ceil(numberOfResults / maxResults);
-        //remove temporary main slider content
-        $("ul.slides").html("");
-        //alert("number of all wmc: "+JSON.parse(initialResult.responseText).wmc.md.nresults);
-        JSON.parse(initialResult.responseText).wmc.srv.forEach(that.addElementToSlider);
-        /*$('.show_more_button').attr("value", "1-"+parseInt(currentPage)*parseInt(maxResults)+" ("+numberOfResults+") - "+showMoreButtonText);
-    this.addElementToSlider = function(item) {
-	mainFlexSlider.data('flexslider').addSlide("<li class='slide'><div class='slide_div' resourceId='"+item.id+"' title='"+item.title+"'><img src='"+item.previewURL+"' resourceId='"+item.id+"' title='"+item.title+"'/><div><span class='flex-caption'>"+item.title+"</span></div><div><span class='flex-load-count'>"+item.loadCount+"</span></div></div></li>");
-    this.removeOldContainer = function(){
-       $('#container').remove();
-    this.loadWmcById = function(wmcId){
-       //alert(options.loadMessage + ": " + wmcId);
-       //Mapbender.modules.loadwmc.executeJavaScript({method:"loadWmc", parameters:{id:wmcId}});
-       that.executeJavaScript({method:"loadWmc", parameters:{id:wmcId}});
-    that.fillInitialMetadata();
-    that.removeOldContainer();
-    $('#' + options.id).show();
-//copied from javascripts/mod_loadwmc.js because it will not available, if loadwmc window has been closed somewhen!!!!
-	this.executeJavaScript = function (args) {
-		var req = new Mapbender.Ajax.Request({
-			url: "../php/mod_loadwmc_server.php",
-			method: args.method,
-			parameters: args.parameters,
-			callback: function (obj, result, message) {
-				if (!result) {
-					new Mapbender.Warning(message);
-					return;
-				try {
-					if (args.method === "deleteWmc" || args.method === "setWMCPublic"){
-						return;
-					//things that have been done to load wmc
-					if (obj.javascript && typeof(obj.javascript) == "object") {
-						for (var j = 0; j < obj.javascript.length; j++) {
-							//TODO: prohibit multiple maprequests when load wmc, cause on maprequests the wmc maybe stored to session :-(
-							//alert("Statement: " + obj.javascript[j]);
-							//eventAfterLoadWMS.trigger(); -- load the each wms again and saves the wmc to session for each wms - prohibit this behaviour!!!! - Done by global lock_maprequest in class_wmc.php line 1220+!!
-							//console.log("Statement: " + obj.javascript[j]);
-							eval(obj.javascript[j]);
-						if (options.allowResize == true) {
-						    if (Mapbender.modules.resizeMapsize) {
-						        //alert("Module resizeMapsize is available!");
-						        try {$('#resizeMapsize').trigger("click");} catch (e) {alert(e)};
-						} else {
-						    //alert("allowResize not defined");
-						if (args.method === "loadWmc" || args.method === 'loadWmcFromFile') {
-                                                    var kml = $('#mapframe1').data('kml');
-                                                    if(kml) {
-                                                        try {
-                                                            $.each(kml.kmlOrder, function(_, v) {
-        $('li[title="' + v + '"]').unbind().find('*').unbind();
-        $('li[title="' + v + '"]').remove();
-                                                            kml._kmls = JSON.parse(restoredWmcExtensionData.KMLS);
-                                                            kml.cache = {};
-                                                            kml.kmlOrder = JSON.parse(restoredWmcExtensionData.KMLORDER);
-                                                            kml.render();
-                                                            for(var k in kml._kmls) {
-        kml.element.trigger('kml:loaded', kml._kmls[k]);
-                                                        } catch(e) {
-                                                            // just ignore the exception for now
-							that.events.loaded.trigger({
-								extensionData: restoredWmcExtensionData
-					that.hide();
-					new Mapbender.Notice(args.message);
-				catch (e) {
-					new Mapbender.Exception(e.message);
-		req.send();
-//register object in mapbender!
-Mapbender.events.init.register(function() {
-    Mapbender.modules[options.id] = $.extend(new metadataCarousel(),Mapbender.modules[options.id]);
Added: trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php
--- trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php	                        (rev 0)
+++ trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php	2019-11-21 10:36:04 UTC (rev 10350)
@@ -0,0 +1,337 @@
+<?php
+ * Package: mod_metadataCarouselTinySlider
+ * package from
+ * https://github.com/ganlanyuan/tiny-slider
+ * Description:
+ * This modul generates a div with a dynamic slider to allow the selection
+ * of single loadable metadata resources - wmc, ...
+ * The module shoudl be invoked thru a button click. The button may be a mb_button.js module
+ * see also mod_WMSpreferencesDiv or overview toogle
+ * Files:
+ *  - http/plugins/mod_metadataCarouselTinySlider.php
+ * SQL:
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$e_id = 'metadataCarouselTinySlider';
+//include all element vars from the given element
+include '../include/dyn_js.php';
+include '../include/dyn_php.php';
+//if we need some other elements fom the database - do the stuff
+//echo "var mod_gui_wms_visible = '".$vis."';";
+options.loadMessage = "<?php echo _mb('Load theme');?>";
+//load options from element vars - if not already be done before
+//element_vars we need
+// 1. script name of the searchInterface to use
+// 2. slidesPerSide - number of tiles to show together
+// 3. maxResults - number of objects to get from the searchInterface with one call (should be a factor of 2. )
+// 4. resource type - wmc/layer
+// 5. list of resource ids to filter {[1,2,3]}
+// 6. size of images, ...
+// 7. allowResize - like in loadwmc cause a function is borrowed from there
+options.resourceFilter = "[3,11,12]";
+options.resourceFilter = "[]";
+if (options.allowResize == "true") {
+    options.allowResize = true;
+} else {
+    options.allowResize = false;
+if (Number.isInteger(options.maxResults)) {
+} else {
+    options.maxResults = 6;
+//debugging - TODO alter later on
+options.maxResults = 6;
+if (Number.isInteger(options.slidesPerSide)) {
+} else {
+    options.slidesPerSide = 3;
+if (typeof options.searchUrl == 'undefined') {
+    options.searchUrl = "../php/mod_callMetadata.php?";
+} else {
+    //alert(options.searchUrl);
+//for debugging purposes
+//options.searchUrl = "../php/mod_callMetadataRemote.php?";
+var metadataCarouselTinySlider = function() {
+    var that = this;
+    this.id = options.id; //id of the upper div tag from mapbender element
+    this.resourceFilter = JSON.parse(options.resourceFilter);
+    if (this.resourceFilter.length > 0){
+        this.resourceFilterString = "&resourceIds="+this.resourceFilter.join(',');
+    } else {
+        this.resourceFilterString = "";
+    this.initForm = function() {
+        this.tinySliderContainer = $('#metadataCarouselTinySlider');
+	this.tinySliderContainer.addClass('slider-container');
+    //example from tiny-slider
+    /*<ul class="controls" id="customize-controls" aria-label="Carousel Navigation" tabindex="0">
+        <li class="prev" data-controls="prev" aria-controls="customize" tabindex="-1">
+            <i class="fas fa-angle-left fa-5x"></i>
+        </li>
+        <li class="next" data-controls="next" aria-controls="customize" tabindex="-1">
+            <i class="fas fa-angle-right fa-5x"></i>
+        </li>
+    </ul>*/
+	this.controlsContainer = $(document.createElement('ul')).appendTo(this.tinySliderContainer);
+        this.controlsContainer.addClass('controls');
+	this.controlsContainer.attr('id', 'customize-controls');
+	this.controlsContainer.attr('aria-label', 'Carousel Navigation');
+	this.controlsContainer.attr('tabindex', '0');
+	this.prevContainer = $(document.createElement('li')).appendTo(this.controlsContainer);
+	this.prevContainer.addClass('prev');
+	this.prevContainer.attr('data-controls', 'prev');
+	this.prevContainer.attr('aria-controls', 'customize');
+	this.prevContainer.attr('tabindex', '-1');
+	this.prevTitleContainer = $(document.createElement('i')).appendTo(this.prevContainer);
+	this.prevTitleContainer.addClass('fas');
+	this.prevTitleContainer.addClass('fa-angle-right');
+	this.prevTitleContainer.addClass('fa-5x');
+	this.nextContainer = $(document.createElement('li')).appendTo(this.controlsContainer);
+	this.nextContainer.addClass('next');
+	this.nextContainer.attr('data-controls', 'next');
+	this.nextContainer.attr('aria-controls', 'customize');
+	this.nextContainer.attr('tabindex', '-1');
+	this.nextTitleContainer = $(document.createElement('i')).appendTo(this.nextContainer);
+	this.nextTitleContainer.addClass('fas');
+	this.nextTitleContainer.addClass('fa-angle-right');
+	this.nextTitleContainer.addClass('fa-5x');
+	this.sliderContainer = $(document.createElement('div')).appendTo(this.tinySliderContainer);
+	this.sliderContainer.addClass('my-slider');
+        //hide during initialization
+        //$('#' + options.id).hide();
+        //add 3 dummy slides to container identified by class dummy
+        this.sliderContainer.append('<div class="slider-item dummy"><div class="card"><img src="https://www.geoportal.rlp.de/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=2506" alt=""><h2>Titel 1</h2><p class="card_description">Loresm ipsum dolor sit amet consectetur adipisicing elit. Dignissimos, voluptas!</p></div></div><div class="slider-item dummy"><div class="card"><img src="https://www.geoportal.rlp.de/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=2506" alt=""><h2>Titel 2</h2><p class="card_description">Loresm ipsum dolor sit amet consectetur adipisicing elit. Dignissimos, voluptas!</p></div></div><div class="slider-item dummy"><div class="card"><img src="https://www.geoportal.rlp.de/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=2506" alt=""><h2>Titel 3</h2><p class="card_description">Loresm ipsum dolor sit amet consectetur adipisicing elit. Dignissimos, voluptas!</p></div></div>');
+    //end of function initForm
+    var targetName = options.target;
+    var maxResults = options.maxResults;
+    var currentPage = 0;
+    var maxPages = 1; //set default to 1 page
+    var numberOfResults = 0;
+    var searchUrl = options.searchUrl;
+    var slidesPerSide = options.slidesPerSide;
+    //first init form
+    that.initForm();
+    this.loadMore = function(){
+that.removeEvent();
+        //alert("actual_loaded_page: "+ currentPage +" - max pages: "+maxPages); //1-10 (100)
+        //hide further loading button while loading more data
+        //$('.show_more_button').hide();
+        //load next page
+        $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&searchPages="+(parseInt(currentPage) + parseInt(1))+"&maxResults="+maxResults+that.resourceFilterString, async: false, success: function(result){
+            result.wmc.srv.forEach(that.addElementToSlider);
+            //increase global var currentPage
+            currentPage = parseInt(currentPage) + parseInt(1);
+            //unbind all old click events
+            $('img.load_image').unbind('click');
+            //reinitialize click event
+            $('img.load_image').click(function(){
+                var $this = $(this);
+                resourceId = $this.attr("resourceid");
+                resourceTitle = $this.attr("resourceTitle");
+                alert(options.loadMessage + ": " + resourceTitle);
+                that.executeJavaScript({method:"loadWmc", parameters:{id:resourceId}});
+        //alert("current page - to goto afterwards!: "+currentPage);
+        that.mainSlider.goTo(parseInt(currentPage * slidesPerSide) + 1);
+        that.addEvent();
+    //invoke from plugins folder
+    //import {tns} from '../../extensions/tiny-slider-master/src/tiny-slider.js';
+    //this is done in mapbender database - reference to the js file in the extension folder
+    //initialize tiny-slider
+    this.mainSlider = $('.slider-container');
+    that.mainSlider = tns({
+        container: '.my-slider',
+        items: slidesPerSide,
+        slideBy: 'page',
+        autoplay: false,
+        mouseDrag: true,
+        loop: false,
+	controlsText: ['<svg class="direction" width="17" height="18" viewBox="0 0 18 18" fill="none"  xmlns="http://www.w3.org/2000/svg"><path d="M16.0142 11.6191L14.6042 13.0291L9.01416 7.43914L3.42416 13.0291L2.01416 11.6191L9.01416 4.61914L16.0142 11.6191Z" stroke="currentColor" stroke-width="2"/></svg>','<svg class="direction" width="17" height="18" viewBox="0 0 18 18" fill="none"  xmlns="http://www.w3.org/2000/svg"><path d="M16.0142 11.6191L14.6042 13.0291L9.01416 7.43914L3.42416 13.0291L2.01416 11.6191L9.01416 4.61914L16.0142 11.6191Z" stroke="currentColor" stroke-width="2"/></svg>'],
+    this.fillInitialMetadata = function() {
+        //initialize slider from first request to search interface
+        var initialResult = $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&maxResults="+maxResults+that.resourceFilterString, async: false, success: function(result){
+            if (result.valid)
+                return true;
+            else
+                return false;
+        var initialSearchJson = JSON.parse(initialResult.responseText);
+        //extract number of currrent page, rpp and max results
+        currentPage = initialSearchJson.wmc.md.p;
+        numberOfResults = initialSearchJson.wmc.md.nresults;
+        maxPages = Math.ceil(numberOfResults / maxResults);
+        //remove temporary main slider content
+        $("div.my-slider").html("");
+        JSON.parse(initialResult.responseText).wmc.srv.forEach(that.addElementToSlider);
+        //initialize load on click event for initial items
+            resourceId = $this.attr("resourceId");
+            that.loadWmcById(resourceId);
+    this.addElementToSlider = function(item) {
+        that.mainSlider.destroy();
+        $("div.my-slider").append('<div class="slider-item" resourceId="'+item.id+'" title="' + item.title + ' - ' + item.abstract + '"><div class="card"><span class="load-count">'+item.loadCount+'</span><img class="load_image" src="../img/osgeo_graphics/document-send-symbolic.symbolic.png" title="Load" resourceId="'+item.id+'" resourceTitle="'+item.title+'"><img src="'+item.previewURL+'" alt=""><h2>'+item.id+'</h2></div></div>');
+        $(".dummy").remove();
+        that.mainSlider = that.mainSlider.rebuild();
+        //add events again!
+        //that.addEvent();
+    this.loadWmcById = function(wmcId){
+       //alert(options.loadMessage + ": " + wmcId);
+       //Mapbender.modules.loadwmc.executeJavaScript({method:"loadWmc", parameters:{id:wmcId}});
+       that.executeJavaScript({method:"loadWmc", parameters:{id:wmcId}});
+    this.addEvent = function(){
+        //add event
+        this.customizedFunction = function (info, eventName) {
+            // direct access to info object
+            //console.log(info.event.type, info.container.id);
+            //if on last page ... - try to reload further data via ajax call
+	    if ((Math.ceil((that.mainSlider.getInfo().displayIndex / slidesPerSide)) == that.mainSlider.getInfo().pages)) {
+            // TODO - check if on last side of all database results && Math.ceil(parseInt(numberOfResults) / slidesPerSide))
+                //alert("On last page and some more elements are available!");
+                that.loadMore();
+        // bind function to event
+        that.mainSlider.events.on('indexChanged', that.customizedFunction);
+    this.removeEvent = function(){
+        that.mainSlider.events.off('indexChanged', that.customizedFunction);
+    that.fillInitialMetadata();
+    that.addEvent();
+//copied from javascripts/mod_loadwmc.js because it will not available, if loadwmc window has been closed somewhen!!!!
+	this.executeJavaScript = function (args) {
+		var req = new Mapbender.Ajax.Request({
+			url: "../php/mod_loadwmc_server.php",
+			method: args.method,
+			parameters: args.parameters,
+			callback: function (obj, result, message) {
+				if (!result) {
+					new Mapbender.Warning(message);
+					return;
+				try {
+					if (args.method === "deleteWmc" || args.method === "setWMCPublic"){
+						return;
+					//things that have been done to load wmc
+					if (obj.javascript && typeof(obj.javascript) == "object") {
+						for (var j = 0; j < obj.javascript.length; j++) {
+							//TODO: prohibit multiple maprequests when load wmc, cause on maprequests the wmc maybe stored to session :-(
+							//alert("Statement: " + obj.javascript[j]);
+							//eventAfterLoadWMS.trigger(); -- load the each wms again and saves the wmc to session for each wms - prohibit this behaviour!!!! - Done by global lock_maprequest in class_wmc.php line 1220+!!
+							//console.log("Statement: " + obj.javascript[j]);
+							eval(obj.javascript[j]);
+						if (options.allowResize == true) {
+						    if (Mapbender.modules.resizeMapsize) {
+						        //alert("Module resizeMapsize is available!");
+						        try {$('#resizeMapsize').trigger("click");} catch (e) {alert(e)};
+						} else {
+						    //alert("allowResize not defined");
+						if (args.method === "loadWmc" || args.method === 'loadWmcFromFile') {
+                                                    var kml = $('#mapframe1').data('kml');
+                                                    if(kml) {
+                                                        try {
+                                                            $.each(kml.kmlOrder, function(_, v) {
+        $('li[title="' + v + '"]').unbind().find('*').unbind();
+        $('li[title="' + v + '"]').remove();
+                                                            kml._kmls = JSON.parse(restoredWmcExtensionData.KMLS);
+                                                            kml.cache = {};
+                                                            kml.kmlOrder = JSON.parse(restoredWmcExtensionData.KMLORDER);
+                                                            kml.render();
+                                                            for(var k in kml._kmls) {
+        kml.element.trigger('kml:loaded', kml._kmls[k]);
+                                                        } catch(e) {
+                                                            // just ignore the exception for now
+							that.events.loaded.trigger({
+								extensionData: restoredWmcExtensionData
+					that.hide();
+					new Mapbender.Notice(args.message);
+				catch (e) {
+					new Mapbender.Exception(e.message);
+		req.send();
+//register object in mapbender!
+Mapbender.events.init.register(function() {
+    Mapbender.modules[options.id] = $.extend(new metadataCarouselTinySlider(),Mapbender.modules[options.id]);
More information about the Mapbender_commits mailing list
