[Mapbender-commits] r10282 - in trunk/mapbender/http: javascripts plugins
svn_mapbender at osgeo.org
Fri Oct 11 02:08:03 PDT 2019
Author: armin11
Date: 2019-10-11 02:08:03 -0700 (Fri, 11 Oct 2019)
New Revision: 10282
Added:
trunk/mapbender/http/javascripts/mod_overviewToggle2019.js
trunk/mapbender/http/plugins/mb_scaleContainer.js
New option for geoportal2019 gui - add overview - thanx to karlo
Added: trunk/mapbender/http/javascripts/mod_overviewToggle2019.js
--- trunk/mapbender/http/javascripts/mod_overviewToggle2019.js (rev 0)
+++ trunk/mapbender/http/javascripts/mod_overviewToggle2019.js 2019-10-11 09:08:03 UTC (rev 10282)
@@ -0,0 +1,298 @@
+ * Package: overviewToggle
+ * Description:
+ * shows and hides the overview module with a jQuery animation
+ * Files:
+ * - http/javascripts/mod_overviewToggle2019.js
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>',
+ * > 'overviewToggle',5,1,'','','div','','class="overviewToggleClosed"',
+ * > -1,-1,NULL ,NULL ,NULL ,
+ * > 'position:absolute;right:0px;bottom:20px;background-color:#EEE;border-top:2px solid #DDD;border-left:2px solid #DDD;border-bottom:2px solid #DDD;display:none;',
+ * > '<svg width="17" height="18" viewBox="0 0 18 18" fill="none" xmlns="http://www.w3.org/2000/svg">
+<path d="M16.0142 11.6191L14.6042 13.0291L9.01416 7.43914L3.42416 13.0291L2.01416 11.6191L9.01416 4.61914L16.0142 11.6191Z" stroke="currentColor" stroke-width="2"/>
+</svg>',
+ * > 'div','../javascripts/mod_overviewToggle2019.js','','overview','','');
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES ('<app_id>', 'overviewToggle',
+ * > 'css', '.overviewToggleClosed svg {float: right;transform: rotate(-90deg);}.overviewToggleOpened svg {float: left;transform: rotate(90deg);margin-top: 42.5%;}.overviewToggleOpened, .overviewToggleClosed {color:#777;padding:5px;}.overviewToggleOpened:hover, .overviewToggleClosed:hover {color:#333;}
+ * > '' ,'text/css');
+ * > 'initialOpen', 'false',
+ * > 'default is false' ,'var');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<app_id>', 'overviewToggle', 'overviewToggle_position',
+ * > 'ur', 'define a position for the overviewToggle - ur and lr is possible or false' ,'var');
+ * > 'overviewToggle_position_offset_top', '0', 'define an offset for the div tag' ,'var');
+ * Help:
+ * http://www.mapbender.org/OverviewToggle
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+if (!options.initialOpen || options.initialOpen == 'false') {
+ options.initialOpen = false;
+var overview_visible = options.initialOpen;
+var ovSwitchTarget = options.target[0];
+var ovSwitchId = options.id;
+if (!options.overviewToggle_position_offset_top) {
+ var overviewToggle_position_offset_top = 0;
+}else{
+ var overviewToggle_position_offset_top = options.overviewToggle_position_offset_top;
+if (!options.overviewToggle_position) {
+ var overviewToggle_position = false;
+}else{
+ var overviewToggle_position = options.overviewToggle_position;
+if (!options.target[1]) {
+ var ovMapframeTarget = 'mapframe1';
+}else{
+ var ovMapframeTarget = options.target[1];
+ var $ov = $("#" + ovSwitchTarget);
+ var $this = $("#" + ovSwitchId);
+ var $ovToggleButton = $("#" + ovSwitchId + " > span");
+ var overviewInitialWidth = $ov.width();
+ var overviewInitialHeight = $ov.height();
+ var overviewInitialTop = parseInt($ov.css("top"), 10);
+ var overviewLeft = parseInt($ov.css("left"), 10);
+ var overviewInitialOuterWidth = $ov.outerWidth();
+ var $mf = $("#" + ovMapframeTarget);
+ var mapframeLeft = parseInt($mf.css("left"), 10);
+ var mapframeHeight = parseInt($mf.css("height"), 10);
+ var mapframeWidth = parseInt($mf.css("width"), 10);
+ var mapframeTop = parseInt($mf.css("top"), 10);
+if (overviewToggle_position == 'lr' || overviewToggle_position == 'ur'){
+ eventAfterMapRequest.register(function () {
+ mod_overviewToggleRefreshPosition();
+eventInit.register(function () {
+ mod_overviewToggle();
+function mod_overviewToggleRefreshPosition(){
+ if(mapframeWidth != parseInt($mf.css("width"), 10) && overviewToggle_position != false){
+ mapframeWidth = parseInt($mf.css("width"), 10);
+ mapframeHeight = parseInt($mf.css("height"), 10);
+ if (overviewToggle_position == 'lr'){
+ $ov.css({
+ display:"block",
+ top: (mapframeTop + mapframeHeight - overviewToggle_position_offset_top - overviewInitialHeight) + "px",
+ left: (mapframeLeft + mapframeWidth - overviewInitialWidth) + "px",
+ borderWidth: "0px",
+ borderStyle: "solid",
+ borderColor: "#176798"
+ }else if (overviewToggle_position == 'ur'){
+ $ov.css({
+ display:"block",
+ top: (mapframeTop + overviewToggle_position_offset_top) + "px",
+ if (overview_visible == false){
+ var leftovt = mapframeLeft + mapframeWidth - 35;
+ }else{
+ var leftovt = mapframeLeft + mapframeWidth - overviewInitialWidth;
+ $this.css({
+ display:"inline-block",
+ left: leftovt + "px",
+ top: (mapframeTop + mapframeHeight - 26 ) + "px",
+ zIndex: $ov.css("zIndex")
+ $this.css({
+ top: (mapframeTop + overviewToggle_position_offset_top - 26) + "px",
+function mod_overviewToggle(){
+ $ov.css({
+ display:"block",
+ $ov.css({
+ display:"block",
+ }else{
+ $ov.css({
+ display:"block",
+ top: (overviewInitialTop + 26) + "px",
+ if (!overview_visible || overview_visible == false) {
+ $ov.css({
+ display:"none",
+ left: overviewLeft + "px"
+ } else {
+ $("#" + ovSwitchId).css('width',overviewInitialWidth+'px');
+ var leftthis = mapframeLeft + mapframeWidth - 35;
+ }else{
+ var leftthis = mapframeLeft + mapframeWidth - overviewInitialWidth;
+ $this.css({
+ left: leftthis + "px",
+ }else{
+ $this.css({
+ }else{
+ $this.css({
+ display:"flex",
+ left: overviewLeft + "px",
+ top: overviewInitialTop + "px",
+ zIndex: $ov.css("zIndex")-1
+ $this.mouseover(function () {
+ this.style.cursor = "pointer";
+ }).mouseout(function () {
+ this.style.cursor = "default";
+ }).click(function(){
+ if(overview_visible){
+ // Hide
+ $ov.hide();
+ $ov.css({
+ display: "none",
+ width: "0px",
+ if (overviewToggle_position != 'false' && overviewToggle_position != false){
+ }else{
+ var leftovt = overviewLeft;
+ $this.css({
+ width: 17,
+ height:18,
+ left: leftovt
+ $this.removeClass("overviewToggleOpened").addClass("overviewToggleClosed");
+ overview_visible = false;
+ else{
+ // Show
+ }else{
+ $this.css({
+ width: overviewInitialWidth + 28,
+ height: overviewInitialHeight + 11,
+ left: leftovt
+ $ov.css({
+ display: "block",
+ width: overviewInitialWidth ,
+ height: overviewInitialHeight,
+ left:leftovt,
+ borderWidth: "1px",
+ borderColor: "#777"
+ $this.addClass("overviewToggleOpened").removeClass("overviewToggleClosed");
+ overview_visible = true;
+ options.initialOpen = true;
Modified: trunk/mapbender/http/plugins/mb_scaleContainer.js
--- trunk/mapbender/http/plugins/mb_scaleContainer.js 2019-10-02 11:44:04 UTC (rev 10281)
+++ trunk/mapbender/http/plugins/mb_scaleContainer.js 2019-10-11 09:08:03 UTC (rev 10282)
@@ -14,10 +14,10 @@
$toolbar.mapbender(new ToolbarApi(options));
-/*$(document).ready(function(){ $("#tree2Container").hide(); });*/
- $('.scaleDivClosed').click(function(){
- $('#scaleContainer').toggle('fast');
- $('#scaleContainer').hide();
+ $('#scaleDiv').click(function(){
+ $('#scaleContainer').toggle();
+ $('#scaleContainer').click(function(event){event.stopPropagation();});
+ $('#scaleDiv').toggleClass('scaleDivOpened');
More information about the Mapbender_commits
