[Mapbender-commits] r10287 - in trunk/mapbender: http/classes http/php resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 18 03:31:58 PDT 2019
Author: armin11
Date: 2019-10-18 03:31:58 -0700 (Fri, 18 Oct 2019)
New Revision: 10287
   trunk/mapbender/http/classes/class_metadata.php
   trunk/mapbender/http/php/mod_callMetadata.php
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
New option to search for application metadata
Modified: trunk/mapbender/http/classes/class_metadata.php
--- trunk/mapbender/http/classes/class_metadata.php	2019-10-17 06:41:44 UTC (rev 10286)
+++ trunk/mapbender/http/classes/class_metadata.php	2019-10-18 10:31:58 UTC (rev 10287)
@@ -136,6 +136,7 @@
 		$this->resourceClassifications[0]['relation_wfs'] = 'wfs_featuretype_md_topic_category';
 		$this->resourceClassifications[0]['relation_wmc'] = 'wmc_md_topic_category';
 		$this->resourceClassifications[0]['relation_dataset'] = 'mb_metadata_md_topic_category';
+$this->resourceClassifications[0]['relation_application'] = 'mb_metadata_md_topic_category';
 //TODO: define this in mapbender
 		$this->resourceClassifications[1]['title'] = "INSPIRE"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
@@ -149,6 +150,7 @@
 		$this->resourceClassifications[1]['relation_wfs'] = 'wfs_featuretype_inspire_category';
 		$this->resourceClassifications[1]['relation_wmc'] = 'wmc_inspire_category';
 		$this->resourceClassifications[1]['relation_dataset'] = 'mb_metadata_inspire_category';
+$this->resourceClassifications[1]['relation_application'] = 'mb_metadata_inspire_category';
 		switch($this->languageCode){
 			case "de":
@@ -174,6 +176,7 @@
 		$this->resourceClassifications[2]['relation_wfs'] = 'wfs_featuretype_custom_category';
 		$this->resourceClassifications[2]['relation_wmc'] = 'wmc_custom_category';
 		$this->resourceClassifications[2]['relation_dataset'] = 'mb_metadata_custom_category';
+$this->resourceClassifications[2]['relation_application'] = 'mb_metadata_custom_category';
 		switch ($this->languageCode) {
 			case "de":
@@ -195,6 +198,8 @@
 		$this->resourceCategories[2]['name'] = 'WMC';
 		$this->resourceCategories[3]['name'] = 'DAD';
 		$this->resourceCategories[4]['name'] = 'DATASET';
+$this->resourceCategories[4]['name'] = 'APPLICATION';
         		case 'de':
                 	$this->resourceCategories[0]['name2show'] = 'Kartenebenen';
@@ -202,6 +207,7 @@
 			$this->resourceCategories[2]['name2show'] = 'Kartenzusammenstellungen';
 			$this->resourceCategories[3]['name2show'] = 'KML/Newsfeeds';
 			$this->resourceCategories[4]['name2show'] = 'Datensätze';
+$this->resourceCategories[5]['name2show'] = 'Anwendungen';
 			$this->keywordTitle = 'Schlagwortliste';
        			break;
         		case 'en':
@@ -210,6 +216,7 @@
 			$this->resourceCategories[2]['name2show'] = 'Combined Maps';
 			$this->resourceCategories[4]['name2show'] = 'Datasets';
+$this->resourceCategories[5]['name2show'] = 'Applications';
 			$this->keywordTitle = 'Keywordlist';
         		break;
         		case 'fr':
@@ -218,6 +225,7 @@
 			$this->resourceCategories[2]['name2show'] = 'Cartes composées';
        			break;
      			default:
@@ -226,6 +234,7 @@
 		//not needed til now - maybe usefull for georss output
@@ -249,6 +258,11 @@
 				$this->datasetDoc = new DOMDocument('1.0');
 				$this->generateDatasetMetadata($this->datasetDoc);
+if (isset($this->searchResources) & strtolower($this->searchResources) === "application") {
+	$this->applicationDoc = new DOMDocument('1.0');
+	$this->generateApplicationMetadata($this->applicationDoc);
 		if ($this->outputFormat === "json") {
@@ -364,6 +378,33 @@
 				$this->resourceClasses = array(0,1,2);
+			if (isset($this->searchResources) & strtolower($this->searchResources) === "application") {
+				$this->databaseIdColumnName = 'metadata_id'; //not metadata_id as in original table!
+				$this->databaseTableName = 'mb_metadata';
+				$this->searchView = 'search_application_view';
+				$this->whereStrCatExtension = " AND custom_category.custom_category_hidden = 0";
+				switch ($this->orderBy) {
+					case "rank":
+						$this->orderBy = " ORDER BY load_count DESC";
+						break;
+					case "id":
+						$this->orderBy = " ORDER BY metadata_id ASC";
+						break;
+					case "title":
+						$this->orderBy = " ORDER BY title DESC";
+						break;
+					case "date":
+						$this->orderBy = " ORDER BY dataset_timestamp DESC ";
+						break;
+					default:
+						//$this->orderBy = " ORDER BY load_count DESC";
+				$this->resourceClasses = array(0,1,2);
 	$this->e = new mb_notice("orderBy new: ".$this->orderBy);
@@ -774,6 +815,71 @@
+	private function generateApplicationMetadataJSON($res, $n) {
+		//initialize object
+		$this->applicationJSON = new stdClass;
+		$this->applicationJSON->application = (object) array(
+				'md' => (object) array(
+					'nresults' => $n,
+					'p' => $this->searchPages,
+					'rpp' => $this->maxResults
+				'srv' => array()
+		//read out records
+		$serverCount = 0;
+		$applicationMatrix = db_fetch_all($res);
+		//sort result for accessing the right services
+		$applicationMatrix = $this->flipDiagonally($applicationMatrix);
+		//TODO check if order by db or order by php is faster!
+		#array_multisort($wfsMatrix['wfs_id'], SORT_ASC,$wfsMatrix['featuretype_id'], SORT_ASC,$wfsMatrix['wfs_conf_id'], SORT_ASC); //have some problems - the database version is more stable
+		#print_r($wfsMatrix);
+		//read out first server entry - maybe this a little bit timeconsuming TODO
+		for($i=0; $i<count($applicationMatrix);$i++){
+			$this->applicationJSON->application->srv[$i]->id = $applicationMatrix[$i]['dataset_id'];
+			$this->applicationJSON->application->srv[$i]->title = $applicationMatrix[$i]['title'];
+			$this->applicationJSON->application->srv[$i]->uuid = $applicationMatrix[$i]['fileidentifier'];
+			$this->applicationJSON->application->srv[$i]->abstract = $applicationMatrix[$i]['dataset_abstract'];
+			$this->applicationJSON->application->srv[$i]->date = date("Y-m-d",strtotime($applicationMatrix[$i]['dataset_timestamp']));
+			$this->applicationJSON->application->srv[$i]->loadCount = $applicationMatrix[$i]['load_count'];
+			$this->applicationJSON->application->srv[$i]->respOrg = $applicationMatrix[$i]['mb_group_name'];
+			$this->applicationJSON->application->srv[$i]->logoUrl = $applicationMatrix[$i]['mb_group_logo_path'];
+			list($hasConstraints, $symbolLink) = $this->hasConstraints("dataset", $applicationMatrix[$i]['dataset_id']);
+			$this->applicationJSON->application->srv[$i]->hasConstraints = $hasConstraints;
+			$this->applicationJSON->application->srv[$i]->isopen = $applicationMatrix[$i]['isopen'];
+			$this->applicationJSON->application->srv[$i]->symbolLink = $symbolLink;
+			//TODO: other url - to metadata uuid!
+			$this->applicationJSON->application->srv[$i]->mdLink = $this->protocol."://".$this->hostName."/mapbender/php/mod_iso19139ToHtml.php?url=".urlencode($this->protocol."://".$this->hostName."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=").$applicationMatrix[$i]['fileidentifier'];
+			//TODO: preview?
+			//TODO: preview and access url should be generated by class_administration.php
+			$admin = new administration();
+			$notNullElements = array('fkey_gui_id', 'fkey_mapviewer_id', 'fkey_wmc_serial_id');
+                        foreach($notNullElements as $notNullElement) {
+			    if ($applicationMatrix[$i][$notNullElement] == '' || $applicationMatrix[$i][$notNullElement] == null) {
+				$applicationMatrix[$i][$notNullElement] = false;
+$accessUrl = $admin->getMapviewerInvokeUrl($applicationMatrix[$i]['fkey_mapviewer_id'], $applicationMatrix[$i]['fkey_gui_id'], $applicationMatrix[$i]['fkey_wmc_serial_id']);
+$previewUrl = $admin->getMetadataPreviewUrl($applicationMatrix[$i]['metadata_id']);
+$this->applicationJSON->application->srv[$i]->accessURL = $accessUrl;
+			$this->applicationJSON->application->srv[$i]->previewURL = $previewUrl;
+			$spatialSource = "";
+			$stateOrProvince = $applicationMatrix[$i]['mb_group_stateorprovince'];
+			if ($stateOrProvince == "NULL" || $stateOrProvince == "") {
+				$spatialSource = $applicationMatrix[$i]['mb_group_country'];
+			} else {
+				$spatialSource = $applicationMatrix[$i]['mb_group_stateorprovince'];
+			$this->applicationJSON->application->srv[$i]->iso3166 = $spatialSource;
+			$this->applicationJSON->application->srv[$i]->bbox = array($applicationMatrix[$i]['bbox']); //TODO: read out bbox from wmc $applicationMatrix[$i][''];
+			$this->applicationJSON->application->srv[$i]->timeBegin = date("Y-m-d",strtotime($applicationMatrix[$i]['timebegin']));
+			$this->applicationJSON->application->srv[$i]->timeEnd = date("Y-m-d",strtotime($applicationMatrix[$i]['timeend']));
 	private function generateWMSMetadataJSON($res, $n) {
 		//initialize object
 		$this->wmsJSON = new stdClass;
@@ -998,6 +1104,7 @@
 			if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
+				header('Content-Type: application/json');
 				echo $this->wmsJSON;
 			if ($this->resultTarget == 'internal') {
@@ -1004,6 +1111,7 @@
 				$this->internalResult = $this->wmsJSON;
 			if ($this->resultTarget == 'categories') {
+header('Content-Type: application/json');
 				echo $this->catJSON;
 			if ($this->resultTarget == 'webclient') {
@@ -1029,6 +1137,7 @@
 				//if (defined("CORS_WHITELIST") && CORS_WHITELIST != "") {
 				//	header('Access-Control-Allow-Origin: '.CORS_WHITELIST);
 				echo  $this->json->encode($this->allJSON);
 				//echo "test";
@@ -1064,9 +1173,11 @@
 			if ($this->resultTarget == 'web'or $this->resultTarget == 'debug') {
 				echo $this->wfsJSON;
@@ -1095,6 +1206,7 @@
 				//echo "test";
@@ -1125,9 +1237,11 @@
 				echo $this->wmcJSON;
@@ -1185,9 +1299,11 @@
 				echo $this->datasetJSON;
@@ -1213,6 +1329,7 @@
 				//echo "test";
@@ -1223,6 +1340,65 @@
 		$e = new mb_notice("Wrote the MD_Dataset-File");
+	private function generateApplicationMetadata($xmlDoc) {
+		$starttime = $this->microtime_float();
+		list($sql, $v, $t, $n) = $this->generateSearchSQL();
+		//call database search in limits
+		$res = db_prep_query($sql, $v, $t);
+		if ($this->outputFormat == 'json'){
+			//generate json
+			$this->generateApplicationMetadataJSON($res,$n);
+			$usedTime = $this->microtime_float() - $starttime;
+			//put in the time to generate the data
+			$this->applicationJSON->application->md->genTime = $usedTime;
+			$this->applicationJSON = $this->json->encode($this->applicationJSON);
+			if ($this->resultTarget == 'file') {
+				$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json";
+				$admin->putToStorage($filename, $this->applicationJSON, TMP_SEARCH_RESULT_STORAGE, TMP_SEARCH_RESULT_MAX_AGE);
+			if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
+				echo $this->applicationJSON;
+			if ($this->resultTarget == 'categories') {
+				echo $this->catJSON;
+			if ($this->resultTarget == 'webclient') {
+				$this->allJSON = new stdClass;
+				$this->allJSON->categories = $this->json->decode($this->catJSON);
+				$this->allJSON->keywords =  $this->json->decode($this->keyJSON);
+				//load filter from file getFromStorage
+				$filename = $this->tempFolder."/".$this->searchId."_filter.json";
+				$fileExists = $admin->getFromStorage($filename,TMP_SEARCH_RESULT_STORAGE);
+				if ($fileExists == false) {
+					//$e = new mb_exception("class_metadata.php: No filter json exists!");
+				} else {
+					$filterJSON = $fileExists;
+					$filterJSON = $this->json->decode($filterJSON);
+					$this->allJSON->filter = $filterJSON;
+				$this->allJSON->application = $this->json->decode($this->applicationJSON);
+				//$e = new mb_exception("originFromHeader: ".$this->originFromHeader);
+				if ($this->originFromHeader != false) {
+					header('Access-Control-Allow-Origin: '.$this->originFromHeader);
+				//if (defined("CORS_WHITELIST") && CORS_WHITELIST != "") {
+				//	header('Access-Control-Allow-Origin: '.CORS_WHITELIST);
+				echo  $this->json->encode($this->allJSON);
+				//echo "test";
+		$usedTime2 = $this->microtime_float() - $starttime;
+		//echo "<br>used time: ".$usedTime."<br>";
+		$e = new mb_notice("Time to generate Application-Metadata: ".$usedTime2);
+		$e = new mb_notice("Wrote the MD_Application-File");
 	private function replaceChars_all($text){
 		$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß");
 		$repWith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
@@ -1268,7 +1444,7 @@
 		//check for postgis version
 		//sql for get version string
 		//get version number
-		if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc" or strtolower($this->searchResources) === "dataset" or strtolower($this->searchResources) === "wfs" ) & $this->searchBbox != NULL) {
+		if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc" or strtolower($this->searchResources) === "dataset" or strtolower($this->searchResources) === "wfs" ) or strtolower($this->searchResources) === "application" & $this->searchBbox != NULL) {
 			//decide which type of search should be done
 			//check for postgis version cause postgis versions < 1.4 have problems when doing disjoint and inside
@@ -1410,7 +1586,7 @@
 		//filter for data actuality (only for datasets)
-		if (strtolower($this->searchResources) === "dataset") {
+		if (strtolower($this->searchResources) === "dataset" || strtolower($this->searchResources) === "application") {
  			if ($this->timeBegin != NULL && $this->timeEnd != NULL){
 				$time ="((to_timestamp('".$this->timeBegin."','YYYY-MM-DD'),to_timestamp('".$this->timeEnd."','YYYY-MM-DD')) OVERLAPS (timebegin,timeend))";
 				array_push($whereCondArray, $time);
@@ -1484,7 +1660,11 @@
 	private function writeCategories($whereStr, $v, $t) {
 		//generate count sql
 		//generate count of all entries
-		$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." ";
+		if ($this->searchResources != 'application') {
+		    $sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." ";
+		} else{
+		    $sqlN = "SELECT count(metadata_id) from ".$this->searchView." ";
 		if ($whereStr != '') {
 			$sqlN .= $whereStr;
@@ -2128,6 +2308,13 @@
 			$sql .= "  md_termsofuse ON  (mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id) LEFT OUTER JOIN termsofuse ON";
 			$sql .= " (md_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id) where mb_metadata.metadata_id = $1";
+		if ($type == "application") {
+			$sql = "SELECT constraints as accessconstraints, fees, termsofuse.name,";
+			$sql .= " termsofuse.termsofuse_id ,termsofuse.symbollink, termsofuse.description,termsofuse.descriptionlink from mb_metadata LEFT OUTER JOIN";
+			$sql .= "  md_termsofuse ON  (mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id) LEFT OUTER JOIN termsofuse ON";
+			$sql .= " (md_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id) where mb_metadata.metadata_id = $1";
 		$v = array();
 		$t = array();
 		array_push($t, "i");
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2019-10-17 06:41:44 UTC (rev 10286)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2019-10-18 10:31:58 UTC (rev 10287)
@@ -384,9 +384,9 @@
  	} else {
 		$testArray = explode(',',$testMatch);
 		for($i=0; $i<count($testArray);$i++){
-			if (!($testArray[$i] == 'wms' or $testArray[$i] == 'wfs' or $testArray[$i] == 'wmc' or $testArray[$i] == 'dataset')) {
+			if (!($testArray[$i] == 'wms' or $testArray[$i] == 'wfs' or $testArray[$i] == 'wmc' or $testArray[$i] == 'dataset' or $testArray[$i] == 'application')) {
 			//echo 'searchResources: <b>'.$testMatch.'</b>at least one of them does not exists!<br/>';
-			echo 'Parameter <b>searchResources</b>at least one of them does not exists! (wms,wfs,wmc,dataset)<br/>';
+			echo 'Parameter <b>searchResources</b>at least one of them does not exists! (wms,wfs,wmc,dataset,application)<br/>';
 			die();
@@ -691,6 +691,7 @@
 		$resourceCategories['wmc'] = 'Kartenzusammenstellungen';
 		$resourceCategories['dataset'] = 'Datensätze';
 		$resourceCategories['georss'] = 'KML/Newsfeeds';
+		$resourceCategories['application'] = 'Anwendungen';
 		$orderByTitle['header'] = 'Sortierung nach:';
 		$orderByTitle['id'] = 'Identifizierungsnummer';
@@ -721,6 +722,7 @@
 		$resourceCategories['wmc'] = 'Combined Maps';
 		$resourceCategories['dataset'] = 'Datasets';
+		$resourceCategories['application'] = 'Applications';
 		$orderByTitle['header'] = 'Sort by:';
 		$orderByTitle['id'] = 'identification number';
@@ -749,7 +751,8 @@
 		$resourceCategories['wfs'] = 'Services de recherche et de téléchargement';
 		$resourceCategories['wmc'] = 'Cartes composées';
-		$resourceCategories['georss'] = 'KML/Newsfeeds';
+		$resourceCategories['georss'] = 'KML/Newsfeeds';
 		$orderByTitle['header'] = 'classé selon:';
 		$orderByTitle['id'] = 'numéro d\'identification';
@@ -779,6 +782,7 @@
 		$orderByTitle['id'] = 'ID';
@@ -1133,7 +1137,7 @@
 		#echo "class initiated<br>";
 	else {
-		echo "Result for web can only requested for one type of resource (wms, wfs, wmc, georss)!";
+		echo "Result for web can only requested for one type of resource (wms, wfs, wmc, georss, application)!";
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql	2019-10-17 06:41:44 UTC (rev 10286)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql	2019-10-18 10:31:58 UTC (rev 10287)
@@ -152,3 +152,517 @@
       REFERENCES gui (gui_id) MATCH SIMPLE
       ON UPDATE CASCADE;
 --todo sql body element e_width=null ... e_styles: overflow:scroll; ....
+-- new for search for applications - materialized view:
+-- needs postgres 9.3+!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
+-- View: search_dataset_view
+DROP  MATERIALIZED VIEW search_application_view;
+CREATE MATERIALIZED VIEW search_application_view AS
+ SELECT DISTINCT ON (datasets.metadata_id) datasets.user_id,
+    datasets.dataset_id,
+    datasets.metadata_id,
+    datasets.dataset_srs,
+    datasets.title,
+    datasets.dataset_abstract,
+    datasets.accessconstraints,
+    datasets.isopen,
+    datasets.termsofuse,
+    datasets.searchtext,
+    datasets.dataset_timestamp,
+    datasets.department,
+    datasets.mb_group_name,
+    datasets.mb_group_title,
+    datasets.mb_group_country,
+    datasets.load_count,
+    datasets.mb_group_stateorprovince,
+    datasets.md_inspire_cats,
+    datasets.md_custom_cats,
+    datasets.md_topic_cats,
+    datasets.the_geom,
+    datasets.bbox,
+    datasets.preview_url,
+    datasets.fileidentifier,
+    datasets.coupled_resources,
+    datasets.mb_group_logo_path,
+    datasets.timebegin,
+    datasets.timeend,
+--new for application metadata
+    datasets.link,
+    datasets.fkey_gui_id,
+    datasets.fkey_wmc_serial_id,
+    datasets.fkey_mapviewer_id
+   FROM ( SELECT dataset_dep.fkey_mb_user_id AS user_id,
+            dataset_dep.dataset_id,
+            dataset_dep.dataset_id AS metadata_id,
+            dataset_dep.srs AS dataset_srs,
+            dataset_dep.title,
+            dataset_dep.abstract AS dataset_abstract,
+            dataset_dep.accessconstraints,
+            dataset_dep.isopen,
+            dataset_dep.termsofuse,
+            f_collect_searchtext_dataset(dataset_dep.dataset_id) AS searchtext,
+            dataset_dep.dataset_timestamp,
+            dataset_dep.department,
+            dataset_dep.mb_group_name,
+            dataset_dep.mb_group_title,
+            dataset_dep.mb_group_country,
+                CASE
+                    WHEN dataset_dep.load_count IS NULL THEN 0::bigint
+                    ELSE dataset_dep.load_count
+                END AS load_count,
+            dataset_dep.mb_group_stateorprovince,
+            f_collect_inspire_cat_dataset(dataset_dep.dataset_id) AS md_inspire_cats,
+            f_collect_custom_cat_dataset(dataset_dep.dataset_id) AS md_custom_cats,
+            f_collect_topic_cat_dataset(dataset_dep.dataset_id) AS md_topic_cats,
+            dataset_dep.bbox AS the_geom,
+            (((((st_xmin(dataset_dep.bbox::box3d)::text || ','::text) || st_ymin(dataset_dep.bbox::box3d)::text) || ','::text) || st_xmax(dataset_dep.bbox::box3d)::text) || ','::text) || st_ymax(dataset_dep.bbox::box3d)::text AS bbox,
+            dataset_dep.preview_url,
+            dataset_dep.fileidentifier,
+            f_get_coupled_resources(dataset_dep.dataset_id) AS coupled_resources,
+            dataset_dep.mb_group_logo_path,
+            dataset_dep.timebegin::date AS timebegin,
+dataset_dep.link AS link,
+dataset_dep.fkey_gui_id AS fkey_gui_id,
+dataset_dep.fkey_wmc_serial_id AS fkey_wmc_serial_id,
+dataset_dep.fkey_mapviewer_id AS fkey_mapviewer_id,
+                CASE
+                    WHEN dataset_dep.update_frequency::text = 'continual'::text THEN now()::date
+                    WHEN dataset_dep.update_frequency::text = 'daily'::text THEN now()::date
+                    WHEN dataset_dep.update_frequency::text = 'weekly'::text THEN (now() - '7 days'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'fortnightly'::text THEN (now() - '14 days'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'monthly'::text THEN (now() - '1 mon'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'quarterly'::text THEN (now() - '3 mons'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'biannually'::text THEN (now() - '6 mons'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'annually'::text THEN (now() - '1 year'::interval)::date
+                    ELSE dataset_dep.timeend::date
+                END AS timeend
+           FROM ( SELECT mb_metadata.the_geom AS bbox,
+                    mb_metadata.ref_system AS srs,
+                    mb_metadata.metadata_id AS dataset_id,
+                    mb_metadata.title,
+                    mb_metadata.abstract,
+                    mb_metadata.lastchanged AS dataset_timestamp,
+                    mb_metadata.tmp_reference_1 AS timebegin,
+                    mb_metadata.tmp_reference_2 AS timeend,
+                    mb_metadata.uuid AS fileidentifier,
+                    mb_metadata.preview_image AS preview_url,
+                    mb_metadata.load_count,
+                    mb_metadata.fkey_mb_user_id,
+                    mb_metadata.constraints AS accessconstraints,
+                    mb_metadata.update_frequency,
+                    f_getmd_tou(mb_metadata.metadata_id) AS termsofuse,
+                    f_tou_isopen(f_getmd_tou(mb_metadata.metadata_id)) AS isopen,
+                    mb_metadata.mb_group_id AS department,
+                    mb_metadata.mb_group_name,
+                    mb_metadata.mb_group_title,
+                    mb_metadata.mb_group_country,
+                    mb_metadata.mb_group_stateorprovince,
+                    mb_metadata.mb_group_logo_path,
+mb_metadata.link,
+mb_metadata.fkey_gui_id,
+mb_metadata.fkey_wmc_serial_id,
+mb_metadata.fkey_mapviewer_id
+                   FROM ( SELECT mb_metadata_1.metadata_id,
+                            mb_metadata_1.uuid,
+                            mb_metadata_1.origin,
+                            mb_metadata_1.includeincaps,
+                            mb_metadata_1.fkey_mb_group_id,
+                            mb_metadata_1.schema,
+                            mb_metadata_1.createdate,
+                            mb_metadata_1.changedate,
+                            mb_metadata_1.lastchanged,
+                            mb_metadata_1.link,
+                            mb_metadata_1.linktype,
+                            mb_metadata_1.md_format,
+                            mb_metadata_1.title,
+                            mb_metadata_1.abstract,
+                            mb_metadata_1.searchtext,
+                            mb_metadata_1.status,
+                            mb_metadata_1.type,
+                            mb_metadata_1.harvestresult,
+                            mb_metadata_1.harvestexception,
+                            mb_metadata_1.export2csw,
+                            mb_metadata_1.tmp_reference_1,
+                            mb_metadata_1.tmp_reference_2,
+                            mb_metadata_1.spatial_res_type,
+                            mb_metadata_1.spatial_res_value,
+                            mb_metadata_1.ref_system,
+                            mb_metadata_1.format,
+                            mb_metadata_1.inspire_charset,
+                            mb_metadata_1.inspire_top_consistence,
+                            mb_metadata_1.fkey_mb_user_id,
+                            mb_metadata_1.responsible_party,
+                            mb_metadata_1.individual_name,
+                            mb_metadata_1.visibility,
+                            mb_metadata_1.locked,
+                            mb_metadata_1.copyof,
+                            mb_metadata_1.constraints,
+                            mb_metadata_1.fees,
+                            mb_metadata_1.classification,
+                            mb_metadata_1.browse_graphic,
+                            mb_metadata_1.inspire_conformance,
+                            mb_metadata_1.preview_image,
+                            mb_metadata_1.the_geom,
+                            mb_metadata_1.lineage,
+                            mb_metadata_1.datasetid,
+                            mb_metadata_1.randomid,
+                            mb_metadata_1.update_frequency,
+                            mb_metadata_1.datasetid_codespace,
+                            mb_metadata_1.bounding_geom,
+                            mb_metadata_1.inspire_whole_area,
+                            mb_metadata_1.inspire_actual_coverage,
+                            mb_metadata_1.datalinks,
+                            mb_metadata_1.inspire_download,
+                            mb_metadata_1.transfer_size,
+                            mb_metadata_1.md_license_source_note,
+                            mb_metadata_1.responsible_party_name,
+                            mb_metadata_1.responsible_party_email,
+                            mb_metadata_1.searchable,
+                            mb_metadata_1.load_count,
+mb_metadata_1.fkey_gui_id,
+mb_metadata_1.fkey_wmc_serial_id,
+mb_metadata_1.fkey_mapviewer_id,
+                            user_dep.fkey_mb_group_id,
+                            user_dep.mb_group_id,
+                            user_dep.mb_group_name,
+                            user_dep.mb_group_title,
+                            user_dep.mb_group_country,
+                            user_dep.mb_group_stateorprovince,
+                            user_dep.mb_group_logo_path,
+                            user_dep.fkey_mb_user_id_from_users
+                           FROM ( SELECT mb_metadata_2.metadata_id,
+                                    mb_metadata_2.uuid,
+                                    mb_metadata_2.origin,
+                                    mb_metadata_2.includeincaps,
+                                    mb_metadata_2.fkey_mb_group_id,
+                                    mb_metadata_2.schema,
+                                    mb_metadata_2.createdate,
+                                    mb_metadata_2.changedate,
+                                    mb_metadata_2.lastchanged,
+                                    mb_metadata_2.link,
+                                    mb_metadata_2.linktype,
+                                    mb_metadata_2.md_format,
+                                    mb_metadata_2.title,
+                                    mb_metadata_2.abstract,
+                                    mb_metadata_2.searchtext,
+                                    mb_metadata_2.status,
+                                    mb_metadata_2.type,
+                                    mb_metadata_2.harvestresult,
+                                    mb_metadata_2.harvestexception,
+                                    mb_metadata_2.export2csw,
+                                    mb_metadata_2.tmp_reference_1,
+                                    mb_metadata_2.tmp_reference_2,
+                                    mb_metadata_2.spatial_res_type,
+                                    mb_metadata_2.spatial_res_value,
+                                    mb_metadata_2.ref_system,
+                                    mb_metadata_2.format,
+                                    mb_metadata_2.inspire_charset,
+                                    mb_metadata_2.inspire_top_consistence,
+                                    mb_metadata_2.fkey_mb_user_id,
+                                    mb_metadata_2.responsible_party,
+                                    mb_metadata_2.individual_name,
+                                    mb_metadata_2.visibility,
+                                    mb_metadata_2.locked,
+                                    mb_metadata_2.copyof,
+                                    mb_metadata_2.constraints,
+                                    mb_metadata_2.fees,
+                                    mb_metadata_2.classification,
+                                    mb_metadata_2.browse_graphic,
+                                    mb_metadata_2.inspire_conformance,
+                                    mb_metadata_2.preview_image,
+                                    mb_metadata_2.the_geom,
+                                    mb_metadata_2.lineage,
+                                    mb_metadata_2.datasetid,
+                                    mb_metadata_2.randomid,
+                                    mb_metadata_2.update_frequency,
+                                    mb_metadata_2.datasetid_codespace,
+                                    mb_metadata_2.bounding_geom,
+                                    mb_metadata_2.inspire_whole_area,
+                                    mb_metadata_2.inspire_actual_coverage,
+                                    mb_metadata_2.datalinks,
+                                    mb_metadata_2.inspire_download,
+                                    mb_metadata_2.transfer_size,
+                                    mb_metadata_2.md_license_source_note,
+                                    mb_metadata_2.responsible_party_name,
+                                    mb_metadata_2.responsible_party_email,
+                                    mb_metadata_2.searchable,
+mb_metadata_2.fkey_gui_id,
+mb_metadata_2.fkey_wmc_serial_id,
+mb_metadata_2.fkey_mapviewer_id,
+                                    metadata_load_count.load_count
+                                   FROM mb_metadata mb_metadata_2
+                                     LEFT JOIN metadata_load_count ON mb_metadata_2.metadata_id = metadata_load_count.fkey_metadata_id) mb_metadata_1,
+                            ( SELECT groups_for_publishing.fkey_mb_group_id,
+                                    groups_for_publishing.mb_group_id,
+                                    groups_for_publishing.mb_group_name,
+                                    groups_for_publishing.mb_group_title,
+                                    groups_for_publishing.mb_group_country,
+                                    groups_for_publishing.mb_group_stateorprovince,
+                                    groups_for_publishing.mb_group_logo_path,
+                                    0 AS fkey_mb_user_id_from_users
+                                   FROM groups_for_publishing) user_dep
+                          WHERE mb_metadata_1.fkey_mb_group_id = user_dep.mb_group_id AND mb_metadata_1.the_geom IS NOT NULL AND mb_metadata_1.searchable IS TRUE AND mb_metadata_1.type = 'application'
+                        UNION ALL
+                         SELECT mb_metadata_1.metadata_id,
+                            ( SELECT publishing_registrating_authorities.fkey_mb_group_id,
+                                    publishing_registrating_authorities.mb_group_id,
+                                    publishing_registrating_authorities.mb_group_name,
+                                    publishing_registrating_authorities.mb_group_title,
+                                    publishing_registrating_authorities.mb_group_country,
+                                    publishing_registrating_authorities.mb_group_stateorprovince,
+                                    publishing_registrating_authorities.mb_group_logo_path,
+                                    users_for_publishing.fkey_mb_user_id AS fkey_mb_user_id_from_users
+                                   FROM groups_for_publishing publishing_registrating_authorities,
+                                  WHERE users_for_publishing.primary_group_id = publishing_registrating_authorities.fkey_mb_group_id) user_dep
+                          WHERE (mb_metadata_1.fkey_mb_group_id IS NULL OR mb_metadata_1.fkey_mb_group_id = 0) AND mb_metadata_1.fkey_mb_user_id = user_dep.fkey_mb_user_id_from_users AND mb_metadata_1.the_geom IS NOT NULL AND mb_metadata_1.searchable IS TRUE AND mb_metadata_1.type = 'application') mb_metadata(metadata_id, uuid, origin, includeincaps, fkey_mb_group_id, schema, createdate, changedate, lastchanged, link, linktype, md_format, title, abstract, searchtext, status, type, harvestresult, harvestexception, export2csw, tmp_reference_1, tmp_reference_2, spatial_res_type, spatial_res_value, ref_system, format, inspire_charset, inspire_top_consistence, fkey_mb_user_id, responsible_party, individual_name, visibility, locked, copyof, constraints, fees, classification, browse_graphic, inspire_conformance, preview_image, the_geom, lineage, datasetid, randomid, update_frequency, datasetid_codespace, bounding_geom, inspire_whole_area, inspire_actual_coverage, datalinks, inspire_downloa
 d, transfer_size, md_license_source_note, responsible_party_name, responsible_party_email, searchable, load_count, fkey_gui_id, fkey_wmc_serial_id, fkey_mapviewer_id, fkey_mb_group_id_1, mb_group_id, mb_group_name, mb_group_title, mb_group_country, mb_group_stateorprovince, mb_group_logo_path, fkey_mb_user_id_from_users)) dataset_dep
+          ORDER BY dataset_dep.dataset_id) datasets;
+ALTER TABLE search_application_view
+  OWNER TO postgres;
+GRANT ALL ON TABLE search_application_view TO postgres;
+GRANT ALL ON TABLE search_application_view TO mapbenderdbuser;
+-- create indices:
+--UPDATE search_application_view SET load_count=0 WHERE load_count is NULL;
+-- Index: gist_wst_application_the_geom
+-- DROP INDEX gist_wst_application_the_geom;
+CREATE INDEX gist_wst_application_the_geom
+  ON search_application_view
+  USING gist
+  (the_geom);
+-- Index: idx_wst_application_searchtext
+-- DROP INDEX idx_wst_application_searchtext;
+CREATE INDEX idx_wst_application_searchtext
+  USING btree
+  (searchtext);
+-- Index: idx_wst_application_department
+-- DROP INDEX idx_wst_application_department;
+CREATE INDEX idx_wst_application_department
+  USING btree
+  (department);
+-- Index: idx_wst_application_md_topic_cats
+-- DROP INDEX idx_wst_application_md_topic_cats;
+CREATE INDEX idx_wst_application_md_topic_cats
+  USING btree
+  (md_topic_cats);
+-- Index: idx_wst_application_dataset_id
+-- DROP INDEX idx_wst_application_metadata_id;
+CREATE INDEX idx_wst_application_metadata_id
+  USING btree
+  (metadata_id);
+CREATE INDEX idx_wst_application_dataset_id
+  USING btree
+  (dataset_id);
+-- Index: idx_wst_application_md_inspire_cats
+-- DROP INDEX idx_wst_application_md_inspire_cats;
+CREATE INDEX idx_wst_application_md_inspire_cats
+  USING btree
+  (md_inspire_cats);
+-- Index: idx_wst_application_md_custom_cats
+-- DROP INDEX idx_wst_application_md_custom_cats;
+CREATE INDEX idx_wst_application_md_custom_cats
+  USING btree
+  (md_custom_cats);
+-- Index: idx_wst_application_timebegin
+-- DROP INDEX idx_wst_application_timebegin;
+CREATE INDEX idx_wst_application_timebegin
+  USING btree
+  (timebegin);
+-- Index: idx_wst_application_timeend
+-- DROP INDEX idx_wst_application_timeend;
+CREATE INDEX idx_wst_application_timeend
+  USING btree
+  (timeend);
+CREATE INDEX idx_wst_application_timestamp
+  USING btree
+  (dataset_timestamp);
More information about the Mapbender_commits mailing list
