[Mapbender-dev] primary key for mb_user_name?
Uli Rothstein uli.rothstein at ccgis.de
Mon Aug 7 04:04:39 EDT 2006
do we realy need a unique user name?
This is a basic decision and there are some pros and cons:
* the application works with the user_id if the user is authenticated by name
and password
* the maxLogin disables an account by username
Certainly there are much more arguments.
Let's start a discussion....
Regards
Uli
Astrid Emde schrieb:
> Christoph Baudson schrieb:
>> Astrid,
>>> Only for the login, we ask for the mb_user_name. After we checked the
>>> authentication we go on with the mb_user_id.
>> Although the registration procedure checks, if this username is taken,
>> it might occur that a database entry comes from another source but the
>> registration form on the web, f.e. a command line entry or a different
>> module (someone adds his own registration module for instance).
>> Because the user name needs to be unique, it should be reflected in
>> the database too, so adding a UNIQUE constraint should suffice.
> Hi christoph,
> now I unterstand your point and agree to the primary key on the column
> mb_user_name.
> Astrid
> To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: dev-help at mapbender.osgeo.org
        Ulrich Rothstein
          CCGIS GbR
        Siemensstraße 8
         53121 Bonn
           GERMANY
        www.ccgis.de
    www.mapbender.org
Zentrale:  ++49 (0) 228 90826  0
Durchwahl: ++49 (0) 228 90826 17
Fax:       ++49 (0) 228 90826 11
More information about the Mapbender_dev mailing list
