[Mapbender-dev] module for VSP's
Michael Schulz mschulz at webgis.de
Thu Nov 2 09:11:51 EST 2006
Hi Uli,
thanks for the information. No hurry. Can you give a short overview
how it works?
I tried creating a module that adds vsp to the appropriate
wms-services layer only. Therefore  i changed the include script for
php variables to also create php-arrays. Then you can add, via gui
element vars of that module, the layername where the vsp should be
added, the url-vsp-key and the vsp-value. The key is also checked
against $SESSION, so one could add the parameter and value to the
mapbender call, and the module would take this value and turn it in an
vsp (e.g. if you want to link other applications with mapbender).
Cheers, Michael
On 11/2/06, Ulrich Rothstein <uli.rothstein at ccgis.de> wrote:
> Hi Michael,
> that module exists but is not commited yet.
> I'm back in the office at wednesday. If you need it earlier please contact
> Astrid.
> regards
> Uli
> On Tue, October 31, 2006 4:01 pm, Michael Schulz wrote:
> > Hi,
> > i wanted to check whether there is an existing module to configure
> > vendor specific parameters (vsp) for wms services through a mapbender
> > admin-GUI?
> > The background is, that when configuring access to wms services (for
> > at the moment mostly umn mapserver wms) there is very often the need
> > to have variable vsp, e.g. to transmit user information, that is used
> > in the umn-mapfile for variable substitution.
> > Anybody feeling a similar need?
> > Cheers, Michael
> > Michael Schulz
> > in medias res
> > Gesellschaft für Informationstechnologie mbH
> > In den Weihermatten 66
> > 79108 Freiburg
> > Tel  +49 (0)761 556959-5
> > Fax +49 (0)761 556959-6
> > http://www.webgis.de / http://www.zopecms.de
> > To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> > For additional commands, e-mail: dev-help at mapbender.osgeo.org
>         Ulrich Rothstein
>           CCGIS GbR
>         Siemensstraße 8
>          53121 Bonn
>            GERMANY
>         www.ccgis.de
>     www.mapbender.org
> Zentrale:  ++49 (0) 228 90826  0
> Durchwahl: ++49 (0) 228 90826 17
> Fax:       ++49 (0) 228 90826 11
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev mailing list
