[SAC] Mapbender test platform
John Graham johng at telascience.org
Sun Nov 5 23:57:05 EST 2006
Arnulf
I have rebuilt the .215 blade with postgres mysql ... Its running Fedora
Core 4 and its been updated with Yum
Linux xblade10-2 2.6.17-1.2142_FC4 #1 Tue Jul 11 22:41:14 EDT 2006 i686
athlon i386 GNU/Linux
I have installed Mapbender https://198.202.74.215/mapbender/www/ but I
could use some help configuring ;)
https://198.202.74.215/phpPgAdmin/
https://198.202.74.215/phpMyAdmin/
The only other project I have running on it is Sahana
http://sahana.telascience.org/
The system is connected to the telascience LDAP so your shell logins
will work....
John
Daniel Morissette wrote:
> Arnulf Christl wrote:
>>  The installation needs PHP5, it should be possible to configure all
>> PHP settings on that machine. A PostgreSQL/PostGIS database is
>> required for operation (additionally a MySQL instance would be
>> helpful to get all debugging done at one place). Obviously it should
>> be possible to up- and download files to that server. Code and
>> resources will only eat up minimal disk space.
>> All this feels like it would best be hosted on a virtual machine that
>> can be hacked and configured independent of the other OSGeo
>> infrastructure. Ideally it would be possible to duplicate this
>> virtual machine and have a life demo server that always hosts the
>> current version. The operating system platform is fairly irrelevant,
>> any Linunix will do, preferably Ubuntu, Debian or FreeBSD (no SuSE).
> This seems like a natural fit for a FGS installation. FGS comes with
> its own Apache, PHP and Postgres/Postgis instance and can be installed
> inside a user account without interfering with the system libs at all.
> You can also run multiple FGS instances on the same server without any
> conflict. The only thing missing from your list is MySQL (FGS has
> MySQL client built in but doesn't provide its own server). I'm also
> not sure if FGS comes with SSL enabled in Apache or not but that can
> be addressed I'm sure.
> Unfortunately I do not have time to help set that up now, but I just
> wanted to point out that FGS might be an option to consider if we want
> virtual environments (not full virtual machines) for the OSGeo demo
> server(s).
> Daniel
More information about the Mapbender_dev mailing list
