[Mapbender-dev] proposal: new column in db
"Sven Böhme (WhereGroup)" sven.boehme at wheregroup.com
Wed Aug 8 03:49:57 EDT 2007
+1
Sven
Sebastian Schmitz schrieb:
> +1
> Sebastian
> Samson, Marko schrieb:
>> +1 to the new column
>> @testbaudson have a nice vacation
>> Marko
>>> -----Original Message-----
>>> From: mapbender_dev-bounces at lists.osgeo.org
>>> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of Uli
>>> Rothstein (WhereGroup)
>>> Sent: Wednesday, August 08, 2007 8:41 AM
>>> To: Mapbender Developer List
>>> Subject: Re: [Mapbender-dev] proposal: new column in db
>>> Hi,
>>> +1 for the new column e_title.
>>> best regards
>>> Uli
>>> Christoph Baudson (WhereGroup) schrieb:
>>>> When experimenting with internationalization I realized
>>> that there is
>>>> a general need to separate content from structure in Mapbender.
>>>> An example is the tooltip for each module, which originates from a
>>>> database entry "e_attributes" in table "gui_element". A
>>> typical entry
>>>> would look like this:
>>>> onclick='mod_addWMS()'  onmouseover='this.src =
>>>> this.src.replace(/_off/,"_over");'  onmouseout='this.src =
>>>> this.src.replace(/_over/, "_off");' title="Adding WMS"
>>>> It's not easy extracting the translation of the title from
>>> this field.
>>>> So I propose to add a new column "e_title" to gui_element,
>>> where the
>>>> tooltip may come from. By this way, it will be easy to
>>> translate the
>>>> title as it is isolated.
>>>> The title may also be used for the headers in the module "mod_tab".
>>>> Please vote on my proposal ASAP, so I can check in the
>>> relevant code
>>>> before my vacation starting Saturday.
>>>> Thanks
>>>> Baudson Christoph
>>>> http://www.wheregroup.com
>>>> _______________________________________________
>>>> Mapbender_dev mailing list
>>>> Mapbender_dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>> Ulrich Rothstein
>>> WhereGroup GmbH & Co. KG
>>> Siemensstraße 8
>>> 53121 Bonn
>>> Germany
>>> Fon: +49 (0)228 / 90 90 38 - 17
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> mailto:uli.rothstein at wheregroup.com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Arnulf Christl, Olaf Knopp, Peter Stamm
Dipl.-Geogr. Sven Böhme
- Anwendungsentwickler -
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 20
mailto:sven.boehme at wheregroup.com
Komplementärin:
vertreten durch:
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20070808/253be6f0/sven.boehme-0001.vcf
More information about the Mapbender_dev mailing list
