[Mapbender-dev] [Mapbender] #82: Problems with dynamicOverview and setBackground
Mapbender info at osgeo.org
Fri Aug 10 03:52:12 EDT 2007
 Reporter:  rwoita           |       Owner:  mapbender_dev at lists.osgeo.org
     Type:  defect           |      Status:  new
 Priority:  major            |   Milestone:
Component:  administration   |     Version:  2.4.2
 Keywords:  dynamicOverview  |
 my configuration :
 WMS Service configured only for dynamicOverview (set
 sel_default:on/visbility:hidden in wms_conf)
 in combination with module 'setBackground' this WMS is listed with all the
 other Background Services in the pull-down menu (this is not what I
 wanted), and if once selected it's always and till the end of time on top.
 the solution should be not to handle the 'Overview-WMS' as a background-
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/82>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
