AW: [Mapbender-dev] i18n - table translations
Heuser, Bjoern Bjoern.Heuser at sag.de
Mon Aug 13 03:59:02 EDT 2007
Hi Astrid,
I prefer using the trs_id column.
Because this column is also the primary key and the values are generated by a sequence I would wonder if there are double entries.
wkr
Björn
-----Ursprüngliche Nachricht-----
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde (WhereGroup)
Gesendet: Montag, 13. August 2007 09:40
An: Mapbender_dev
Betreff: [Mapbender-dev] i18n - table translations
Hi devs, hi peter, hi christoph,
 I have a question about the new table translation.
 At the moment the table looks like this:
CREATE TABLE public.translations
  trs_id int4 NOT NULL DEFAULT nextval('translations_trs_id_seq'::regclass),
  locale varchar(8),
  msgid varchar(512),
  msgstr varchar(512),
  CONSTRAINT translations_pkey PRIMARY KEY (trs_id)
Do we need the column trs_id ? Or can we skip it? It would we easier
without the column, as we won't get problems with double entries in the
trs_id column.
What do you think?
Best regards astrid
Mapbender_dev mailing list
Mapbender_dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
