[Mapbender-dev] i18n - table translations
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon Aug 13 08:22:59 EDT 2007
Hi devs,
I agree
It would look like this:
CREATE TABLE public.translations
  locale varchar(8),
  msgid varchar(512),
  msgstr varchar(512),
  CONSTRAINT translations_pkey PRIMARY KEY (locale,msgid)
Maybe we can talk about it later in the irc chat.
See you then
Astrid
Peter Hopfgartner schrieb:
> Hi devs,
> a UNIQUE constraint on locale and msgid could indeed be reasonable.
> Peter
> Samson, Marko wrote:
>> Hi Devs,
>> Perhaps a PK like:
>> would be possible? I'm not so involved in i18n, but if 'locale' means
>> the used language and msgid the id of the message, there should be
>> always just one combination of locale and msgid, so that it could be
>> used for PK.
>> On the other hand its easier to use the trs_id for relations to other
>> tables.
>> Unattached of this, I agree to Bjoern, that a sequence value for
>> trs_id should not create double entries.
>> @Astrid: Do you think creating the update script will raise a problem
>> with sequence values for trs_id or do you mean double entries because
>> of not having a clear'n'unique pk, so that entries can have different
>> trs_id but same values for the rest of the columns?
>> Greetings,
>> Marko Samson
>>> -----Original Message-----
>>> From: mapbender_dev-bounces at lists.osgeo.org
>>> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of Heuser,
>>> Bjoern
>>> Sent: Monday, August 13, 2007 9:59 AM
>>> To: Mapbender Developer List
>>> Subject: AW: [Mapbender-dev] i18n - table translations
>>> Hi Astrid,
>>> I prefer using the trs_id column.
>>> Because this column is also the primary key and the values are
>>> generated by a sequence I would wonder if there are double entries.
>>> wkr
>>> Björn
>>> -----Ursprüngliche Nachricht-----
>>> Von: mapbender_dev-bounces at lists.osgeo.org
>>> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Astrid
>>> Emde (WhereGroup)
>>> Gesendet: Montag, 13. August 2007 09:40
>>> An: Mapbender_dev
>>> Betreff: [Mapbender-dev] i18n - table translations
>>> Hi devs, hi peter, hi christoph,
>>>  I have a question about the new table translation.
>>>  At the moment the table looks like this:
>>>   trs_id int4 NOT NULL DEFAULT
>>> nextval('translations_trs_id_seq'::regclass),
>>>   locale varchar(8),
>>>   msgid varchar(512),
>>>   CONSTRAINT translations_pkey PRIMARY KEY (trs_id) );
>>> Do we need the column trs_id ? Or can we skip it? It would we easier
>>> without the column, as we won't get problems with double entries in
>>> the trs_id column.
>>> What do you think?
>>> Best regards astrid
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 http://www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
