[Mapbender-dev] Code Conventions (first summary)
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Fri Feb 2 10:05:34 EST 2007
> It would be kind, if you could start describing that topic in the wiki.
> I'm writing my diploma-thesis at the moment - so I actually do not have
> the time to add something to the wiki. I'll have more time after
> february, 28th
No problem, I will come up with something in the meantime. I would be
happy if you could take a look at it when you have some more time on
your hands. Good luck for your thesis!
> As I understand it: In JavaScript (nearly) everything is an object, even
> functions. So
> function foo() { alert('bar'); }
> ...is simply a shortcut for:
> window.foo = function() { alert('bar'); };
> ...where in the second example you cannot leave out the terminating
> semicolon. Please correct me if I'm wrong on this.
I assume you're right. But I still don't get why you don't need to
terminate an if-block by a semicolon but a function block.
>> I guess we have come to no conclusion here. I suggest we keep this in
>> mind and discuss it later (I will add a paragraph to the wiki site).
>> If there are any objections please let us know.
> I sometimes see code successfully being packed although it does not
> follow these instructions. Perhaps it's best to try and see. If the
> packed Javscript  does not work we have at least some common things to
> check.
Good point. Maybe I can test it next week with the geometry library.
I'll keep you posted.
Thanks for you input, Marc.
Christoph
More information about the Mapbender_dev mailing list
