AW: [Mapbender-dev] PKs for all tables?
Ulrich Rothstein uli.rothstein at wheregroup.com
Mon Feb 5 03:15:42 EST 2007
Hi Marko,
thanks for your contribution!
I've put the statements in the wiki:
http://www.mapbender.org/index.php/Next_release
@Astrid: is it possible to integrate them into rc2? Or should we wait for
the rc2-follower?
best regards
Uli
On Wed, January 31, 2007 2:41 pm, Samson, Marko wrote:
> ALTER TABLE ONLY wfs_featuretype_namespace ADD CONSTRAINT
> pk_featuretype_namespace PRIMARY KEY
> (fkey_wfs_id,fkey_featuretype_id,namespace);
> ALTER TABLE ONLY mb_monitor ADD CONSTRAINT pk_mb_monitor PRIMARY KEY
> (upload_id, fkey_wms_id);
> ALTER TABLE ONLY mb_log ADD CONSTRAINT pk_mb_log PRIMARY KEY  (id);
> layer epsg had to be to cleaned.  rc1 table backup after cleaning at
> zip-file.....
> I had to delete one WMS, but I forgot the name. Something like eusoil or
> something like that (layer_id was 13667?)
> ALTER TABLE ONLY layer_epsg ADD CONSTRAINT pk_layer_epsg PRIMARY KEY
> (fkey_layer_id,epsg);
> layer style has to be cleaned, but I think the pk should be like this. but
> I'm not sure!:
> ALTER TABLE ONLY layer_style ADD CONSTRAINT pk_layer_style PRIMARY KEY
> (fkey_layer_id,name);
> Gruß,
> Marko
> Marko Samson
> Landesbetrieb Wald und Holz NRW
> GIS-Anwendungsentwicklung
> Referat I-5
> Albrecht-Thaer-Straße 34
> 48147 Münster
> Achtung, neue Telefonnummer!
> Tel.: 0251/91797 - 169
> Mail: marko.samson at wald-und-holz.nrw.de
>> -----Ursprüngliche Nachricht-----
>> Von: mapbender_dev-bounces at lists.osgeo.org
>> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
>> Uli Rothstein (WhereGroup)
>> Gesendet: Mittwoch, 31. Januar 2007 08:23
>> An: Mapbender Developer List
>> Betreff: Re: [Mapbender-dev] PKs for all tables?
>> Hi Marko,
>> >> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Uli
>> >> Gesendet: Dienstag, 30. Januar 2007 10:11
>> >> Betreff: Re: [Mapbender-dev] Test of RC1 / some thoughts
>> >> dear list-members,
>> >> Marc Jansen schrieb:
>> >>> Hey Marko, hey List,
>> >>>> 2. Test of upgrading a 2.4 version
>> >>>>     - everything seems to work fine, too. (The first time
>> >> I did the
>> >>>> upgrade, I had all entries of gui_layers twice. Don't
>> know, what I
>> >>>> did wrong. Whatever, the second time everything worked
>> >> pretty nice. )
>> >>>> Idea:
>> >>>>  I saw, that you set "default_with_oids = true" in the new pgsql
>> >>>> schema, but wouldn't there be a chance for grouped
>> >> primary-keys for
>> >>>> all the pk-less tables, for example the table gui_layer with a
>> >>>> grouped-pk of fkey_gui_id and fkey_layer_id to prevent
>> >> double entries.
>> >>>> (same idea for all other tables without PK like
>> >>>> gui_layer,gui_wfs,gui_wms,...)
>> >>> I second that, if there are no other relevant issues. I
>> can not see
>> >>> any
>> >>> -- do you? A grouped PK should be the right way to handle
>> >> theses tables.
>> >>>>  Or is there a reason, why there are no PKs at some
>> tables? In my
>> >>>> opinion, there is no logic of having two entries, for
>> example with
>> >>>> the same fkey_gui_id and fkey_layer_id in table gui_layer.
>> >>> Yipp, speaking from a database view of things, one does not
>> >> need two
>> >>> entries with the same values in the field you named. Am I missing
>> >>> something?
>> >> I don't now. There may be some technical reasons to
>> publish a layer
>> >> twice, because nonexisting transparency of services for
>> example. So
>> >> you have more flexibility for the arrangement of layers. (But I've
>> >> never seen such constructions in reality...)
>> > But this now can be managed very easy with the new
>> treefolder to move the different layers up or down to handle
>> that problem(additional to the wms_preferences modul). Or
>> have I misunderstood what you meant?
>> You're right. But we have some more GeoDataExplorer, for
>> example the configurable one... Howerver, if we don't need to
>> publish layer twice, we should have a unique fkey_wms_id -
>> fkey_layer_id combination.
>> > But there are several tables without pks. I think, for a
>> stable datastructure it is advantageous to have pks at every table.
>> That's definitively true. Is someone able to list the missing
>> pks and to create the corresponding sql-statements, if all
>> dev-members agree?
>> Thanks for your hints Marko and best regards Uli
>> > _______________________________________________
>> > Mapbender_dev mailing list
>> > Mapbender_dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>         Ulrich Rothstein
>>     WhereGroup GmbH & Co.KG
>>         Siemensstraße 8
>>          53121 Bonn
>>            GERMANY
>>           uli at osgeo.org
>>         www.wheregroup.com
>>         www.mapbender.org
>> Zentrale:  ++49 (0) 228 909038 0
>> Durchwahl: ++49 (0) 228 909038 17
>> Fax:       ++49 (0) 228 909038 11
>> ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben
>> ihre Fusion als WhereGroup zum 1.1.2007 bekannt gegeben.
>> Daher ändern sich ab Januar 2007 die Email Adressen und
>> Telefonnummern.
        Ulrich Rothstein
          WhereGroup
        Siemensstraße 8
         53121 Bonn
           GERMANY
        www.wheregroup.com
        www.mapbender.org
More information about the Mapbender_dev mailing list
