[Mapbender-dev] Packer (code conventions)
Paul Spencer pspencer at dmsolutions.ca
Tue Feb 6 06:05:11 EST 2007
There is also jslint from Douglas Crockford ... it doesn't compress/
minify but it does check your code for syntactic cleanness, which
helps the compressors do the right thing.
I am slowly running this on my code with some embarrassing
results :)  On the other hand, I've been able to pack my individual
js files together and compress them reasonably well since I delinted
them
Cheers
Paul
On 6-Feb-07, at 2:50 AM, Christoph Baudson (WhereGroup) wrote:
> Hi Paul, hi list,
> thanks for the hint, Paul; Indeed, jsmin is an alternative worth
> considering.
> Take a look at this description
> http://www.crockford.com/javascript/jsmin.html
> The compression rates are not as high as with Dean Edwards' packer,
> but the code remains (to some degree) human-readable. And the
> semicolon after function definitions would not be mandatory.
> Any opinions?
> Christoph
> Paul Spencer schrieb:
>> Christoph,
>> jsmin is an alternative to packer.
>> Cheers
>> Paul
>> On 5-Feb-07, at 6:44 AM, Christoph Baudson (WhereGroup) wrote:
>>> Hello,
>>> today I have tested the packer by Dean Edwards (http://
>>> dean.edwards.name/packer/usage/) by compressing the class point.js
>>> * I had to add a semicolon after every function statement to make
>>> it work.
>>> * The file size was reduced from 3.3Kb to 1.8Kb. For larger files
>>> the compression rate will be higher, for example jQuery is 55Kb
>>> uncompressed and 19Kb compressed.
>>> At a first glance I don't any other packer like Dean Edwards'.
>>> And to it seems like it's in wide use (searching for "dean
>>> edwards" AND "packer" results in 18000 google matches)
>>> The semicolon after functions is necessary if we want to use this
>>> packer. So do we want to use this packer? As a developer who
>>> works on a more theoretical level I'm not as much in touch with
>>> customer demands as others. But I sense that saving half the
>>> bandwidth weighs more than the addition of an (obscure) semicolon.
>>> I would love to hear some more opinions on this.
>>> Christoph
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>> |Chief Technology Officer                                         |
>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the Mapbender_dev mailing list
