[Mapbender-dev] question?
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon Feb 12 02:49:54 EST 2007
Hola Jonny,
Johnny Albino Tarmeño Chavarría schrieb:
> Hi, first sorry for my english. I would like to know about the sources
> of this application:
> http://www.mainz.de/mainzextern/geografischeinformationen/index.htm
> <http://www.mainz.de/mainzextern/geografischeinformationen/index.htm>
> because when it unloads mapbender_2.4.1_rc1 I have not found the sources.
You won't find the sources of the mainz-gui (gui - graphical user
interface) in the mapbender_2.4.1_rc1. This guis is indicidually
designed for the city of mainz.
But with the gui templates which are part of the mapbender_2.4.1_rc1 you
can create your own gui.
The guis are stored in the mapbender database. Only the functionality
you will find as js and php sources.
> Also I cannot enter the application with the user: root and password:
> root, I can not create new users because I don?t know as
> mapbender.conf configurate's so that it leaves this option to me to
> create users.
Normally it is possible to log in as root. Something still is wrong with
you configuration. Have another look at the discription of Mapbender
installation:
http://www.mapbender.org/index.php/Installation_en
And check your configuration with the Script:
http://localhost/mapbender/http/tools/mapbender_setup.php
Greetings
Astrid Emde
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Siemensstraße 8
  D-53121 Bonn
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  http://www.wheregroup.com
ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben ihre Fusion als WhereGroup zum 1.1.2007 bekannt gegeben.
Daher ändern sich ab Januar 2007 die Email Adressen und Telefonnummern.
More information about the Mapbender_dev mailing list
