[Mapbender-dev] Mapbender on sourceforge
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Feb 13 11:01:44 EST 2007
Thank you, Frank. I suggest you notify mapbender_dev once the setup of
trac is completed, then we can get the Mapbender trac running in one go;
I guess we can wait a week or two.
Christoph
Frank Warmerdam schrieb:
> Christoph Baudson (WhereGroup) wrote:
>> More questions:
>> How is the status of a bug tracker at OsGeo?
> Christoph,
> I'm prepared to work with anyone from the Mapbender team on preparing a
> "Trac" instance for Mapbender at OSGeo now.  There will be at least one
> more change with how urls are setup for Trac services in the next week or
> two so I would suggest we just get the setup going now, but not actually
> put it into use till that change is completed.
> Trac instances for OSGeo, MapGuide and FDO are workingly fairly smoothly
> now.
> If the Mapbender PSC would like to select someone to work with me on it, I
> can get going.
> Best regards,
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
http://www.wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Baudson Christoph
More information about the Mapbender_dev mailing list
