[Mapbender-dev] Module maintainers
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Thu Feb 22 11:01:10 EST 2007
Marko,
I just checked the recent changes of the Mapbender Wiki; thanks for
adding yourself as Module maintainer to resizeMapsize, and thanks for
updating the documentation.
Christoph
Christoph Baudson (WhereGroup) schrieb:
> Hello developers,
> today I have edited the Mapbender Wiki:
> 1) I introduced  a new category "Roles" (see
> http://www.mapbender.org/index.php/Category:Roles)
> Adding roles enables us to specify tasks and assign them. If a task is
> handed from one person to another, the role is clearly described in the
> wiki. To sum it up, roles describe tasks and allow delegation.
> 2) The first new role I added is the "Module maintainer" (see
> http://www.mapbender.org/index.php/Module_maintainer). I would be
> grateful if you could read the description of the task and add yourself
> as a maintainer for the modules you feel responsible for (the page has a
> list of all orphaned modules).
> Thanks for your time,
> Baudson Christoph
> http://www.wheregroup.com
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Baudson Christoph
More information about the Mapbender_dev mailing list
