[Mapbender-dev] Reminder: Code Conventions
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Mon Jan 22 04:29:35 EST 2007
Hello,
thanks for your arguments, Marc. The points you made are all sensible. I
would be interested in other members opinions on comments, especially in
JS.
Before we make a decision there should be some more time to discuss
these matters. I suggest to postpone voting on the conventions for two
weeks (Feb 5).
Please take a look at
http://www.mapbender.org/index.php/Code_conventions and let us know what
you think.
Cheers, Christoph
>> At the moment this kind of documentation is maintained in the Wiki.
>> Each module should have a link in the header that leads to a wiki page
>> where each function/class is explained similar to the way you described.
> Thats a good approach, yet I think the possibility to have an automated
> code docu (as PEAR has for instance, see
> http://pear.php.net/package/Date/docs/latest/) would be nice, too.
>> This keeps the file sizes small, which is especially important for
>> js-files.
> Yes filesize does matter, but once cahched by the browser it would not
> do harm anymore...
>> So I think it's not advisable to have too much comments in js-code.
> I disagree: usefull comments can - in my opinion - never be to much...
> especially when using some sort of compression (see below).
>> In an ideal world the js-code would have comments in the SVN, and they
>> could be removed once Mapbender is running to increase the performance.
> Commenting in SVN is - again my opinion - no substitution to coding
> comments.
>> But I don't know of a way how to do this. Anyone?
>> (Btw, do you know how jQuery compresses the file? I see there are two
>> versions available, the compressed one being significantly smaller.
>> This might be interesting as well.)
> Yipp: jquery uses Dean Edwards excelent tool packer:
> http://dean.edwards.name/packer/
> It removes all comments, new lines and the rest of the code is optimized
> as an eval statement (eval is not always evil...)
> You can pack manually, or automated via different tools:
> PHP 5: http://joliclic.free.fr/php/javascript-packer/en/
> There should be other APIs for the automated use of this... I just can't
> find them right now
> This would also mean that all javascript code has to follow some
> conventions. Nothing special: always use the semicolon, do not use
> shorthand comparisons: see http://dean.edwards.name/packer/usage/, and
> http://dean.edwards.name/packer/usage/sample.html.
> Most common errors are statements like these:
> function foo() {
>  return 'bar';
> }; //never forget this semicolon
> AND
> function bar() {
>  if (myVariable == 'foo')
>    return myVariable;
>  else
>    return 'baz';
> (never forget to use the braces {} within if ... else)
>> So, if the js-code has its documentation in the wiki, I doubt it would
>> be a good idea to have the php comments in the code, it would confuse
>> people. I'm not against the phpdoc-style documentation, I only fear
>> that we have already marched in another direction and going back would
>> be too time consumptive. But I would like to hear some other opinions
>> on this!
> As long as we all use the same method, I see no problems with using any
> sort of documenting our work. But may I once again strengthen my wish
> for having lots of docu (formatted as the community wants it) *within th
> code*. I - personally - like having relevant information about code in
> the source file I'm viewing... that would by no means result in
> commenting only within the file (the wiki may be used as well).
> Using a nice editor (Eclipse for instance) and documenting your PHP code
> with PHPdoc results in lots of rewards by the editor : tool-tips with
> method-arguments, auto suggestion, etc.
> BTW: I really like the way we are now disussing within this list:
> hopefully we will keep up with this...
> -- Marc
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
