[Mapbender-dev] treefolder2
Melchior Moos Nimix at gmx.net
Tue Jan 30 08:08:20 EST 2007
Hi Marko,
Samson, Marko schrieb:
> Fast, faster, Melchior. ;-)
> Works great! But where is the nice little function-button for each layer (the litte grey button with the blue arrow)? Or did I something wrong?
I assume the button is invisible because you didn't set the element_var menulch or it is empty. The button is only visible when the menu is enabled.
regards,
melchior
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
More information about the Mapbender_dev mailing list
