[Mapbender-dev] class_gml2.php
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Thu Jul 12 09:27:56 EDT 2007
Hi Christoph,
I would very much like to see your addition, please send me the file.
Thanks a lot,
Christoph
Christoph Ratke schrieb:
> Hi list,
> I was testing the Gazetteer WFS module. When searching objects with
> inner polygons (with 'geometry ilands') I did not get the outer polygon
> but an inner one as gazetteer result. Maybe that was intended but it was
> not correct for me.
> I sligthly modified the class class/class_gml2.php and now all inner and
> the outer polygons are shown. All I did was adding two lines,
> (incrementing a geometry counter, $cnt_geom) in function
> parse_xml($data).
> I don't know if there is a need for but I could comment that further or
> send the class_gml2 if you like.
> Best,
> Christoph Ratke
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Baudson Christoph
More information about the Mapbender_dev mailing list
