[Mapbender-dev] separated map.js and map.php
Uli Rothstein (WhereGroup) uli.rothstein at wheregroup.com
Tue Jun 5 11:06:04 EDT 2007
Hi Michael,
sorry, I forgot about it...
done!
regards
Uli
Michael Schulz schrieb:
> Hi Uli,
> thanks. map.js is there (even with the sld changes ..., great), only
> it seems map.php is not updated in the sld branch. Could you update
> this one also?
> THX, Michael
> 2007/6/5, Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
>> Hi Michael,
>> the js parts from map.php are merged with the map.js and all files are
>> committed.
>> Please check the sld-branch, whether anything works fine for you.
>> best regrads
>> Uli
>> Ulrich Rothstein
>> WhereGroup GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 17
>> Fax: +49 (0)228 / 90 90 38 - 11
>> mailto:uli.rothstein at wheregroup.com
>> http://www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Ulrich Rothstein
Siemensstraße 8
53121 Bonn
Germany
Komplementärin:
vertreten durch:
More information about the Mapbender_dev mailing list
