[Mapbender-dev] separated map.js and map.php
Michael Schulz mschulz at webgis.de
Tue Jun 5 11:16:37 EDT 2007
great. Everything is working. So the sld_branch is up-to-date and functional.
@Sebastian: could you also verify, that the "console" error is fixed
with this version?
Thanks, Michael
2007/6/5, Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
> Hi Michael,
> sorry, I forgot about it...
> done!
> regards
> Uli
> Michael Schulz schrieb:
> > Hi Uli,
> > thanks. map.js is there (even with the sld changes ..., great), only
> > it seems map.php is not updated in the sld branch. Could you update
> > this one also?
> > THX, Michael
> >> Hi Michael,
> >> the js parts from map.php are merged with the map.js and all files are
> >> committed.
> >> Please check the sld-branch, whether anything works fine for you.
> >> best regrads
> >> Uli
> >> Ulrich Rothstein
> >> WhereGroup GmbH & Co. KG
> >> Siemensstraße 8
> >> 53121 Bonn
> >> Germany
> >> Fon: +49 (0)228 / 90 90 38 - 17
> >> Fax: +49 (0)228 / 90 90 38 - 11
> >> mailto:uli.rothstein at wheregroup.com
> >> http://www.wheregroup.com
> >> Amtsgericht Bonn, HRA 6788
> >> Komplementärin:
> >> WhereGroup Verwaltungs GmbH
> >> vertreten durch:
> >> Arnulf Christl, Olaf Knopp, Peter Stamm
> >> _______________________________________________
> >> Mapbender_dev mailing list
> >> Mapbender_dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Ulrich Rothstein
> Siemensstraße 8
> 53121 Bonn
> Germany
> Komplementärin:
> vertreten durch:
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
