[Mapbender-dev] new version available - Mapbender 2.4.2 rc1
Michael Schulz mschulz at webgis.de
Wed Jun 6 05:24:17 EDT 2007
Hi Marko,
it occured on startup. I have done exactly the same, copied to
gui_digitize from gui2, changed to auto. I get this with FF 2.0.0.4
Blimey! I haven't changed anything, now no error occurrs. Strange.
Ähm, I'll come back after trying to find out what's happened.
Michael
2007/6/6, Samson, Marko <Marko.Samson at wald-und-holz.nrw.de>:
> Hi Michael,
> concerning to resize_mapsize:
> does the javascript error occur at startup or while you digitize something or whatever? I installed rc1 and copied resize_mapsize from gui2 to gui_digitize and changed it to auto. But I don't get an error at firefox/firebug.
> What have you done to get this error?
> My Sys:
> mb2.4.2._rc1 (new_installation)
> php 5.2.2
> Firefox 2.0.0.4 & IE6.0.29
> Gruß,
> Marko Samson
> Marko Samson
> Landesbetrieb Wald und Holz NRW
> GIS-Anwendungsentwicklung
> Referat I-5
> Albrecht-Thaer-Straße 34
> 48147 Münster
> Tel.: 0251/91797 - 169
> Mail: marko.samson at wald-und-holz.nrw.de
> > -----Original Message-----
> > From: mapbender_dev-bounces at lists.osgeo.org
> > [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
> > Michael Schulz
> > Sent: Tuesday, June 05, 2007 6:29 PM
> > To: Mapbender Developer List
> > Subject: Re: [Mapbender-dev] new version available -
> > Mapbender 2.4.2 rc1
> > Hi,
> > i have just setup the following test:
> > - mapbender 2.4.2 rc 1, new installation
> > - php 5.1.2
> > - postgres 8.1.4 / postgis 1.1.5
> > - utf-8
> > so far (first few tests ...):
> > - installation without problems
> > - i get a javascript error when adding the resizeMapsize
> > module (with auto option) to the gui "gui_digitize". I have
> > observed this error also in older svn checkouts, but wasn't
> > sure if it was due to special changes on my side. Can someone
> > confirm this? The error:
> > map.php, line 56: highlight has no properties:
> > for(var
> > i=0;i<mb_MapRequestSubFunctions.length;i++){eval(mb_MapRequest
> > SubFunctions[i]);}}
> > - one tiny remark: never used meetingPoint before, so I
> > tested that in gui "gui": the generated link has a bbox set,
> > but since the setbbox module is not enabled by default in
> > this gui, it has no effect (reproduced on the demo). Maybe
> > this dependency should also be documented on the module wiki
> > page (http://www.mapbender.org/index.php/MeetingPoint).
> > ok, more testing in the coming days.
> > BTW. Do you have a special plan on what should especially be tested?
> > Cheers, Michael
> > Michael Schulz
> > in medias res
> > Gesellschaft für Informationstechnologie mbH
> > In den Weihermatten 66
> > 79108 Freiburg
> > Tel  +49 (0)761 556959-5
> > Fax +49 (0)761 556959-6
> > http://www.webgis.de / http://www.zopecms.de
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev mailing list
