[Mapbender-dev] Set Scale in format EPSG:4326
Uli Rothstein (WhereGroup) uli.rothstein at wheregroup.com
Thu Jun 14 02:17:46 EDT 2007
there is no possibility to calculate the scale in 4326 with js in mapbender yet.
Set the scalehints (minscale/maxscale) to zero (in the gui-wms configuration)
and let the mapservice deal with the scalehints instead of mapbender...
regards
Uli
Johnny Albino Tarmeño Chavarría schrieb:
> Hi, I have a problem with the scales in format epsg:4326, at the time of
> loading the map add in the list a value that does not correspond to the
> respective zoom lens. I wait for its quick answer.
> Thnak you.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
