[Mapbender-dev] [Fwd: FW: [SAC] Subversion vhost migration underway]
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Mar 6 03:08:41 EST 2007
D'oh!
Thanks for the correction, Frank.
https://svn.osgeo.org/mapbender
I changed the wiki page and my local settings; there's nothing more I
can do, Arnulf (or can I?) As far as I know I have no access to SVN
administration itself.
Christoph
Arnulf Christl schrieb:
> Frank Warmerdam wrote:
>> Christoph Baudson (WhereGroup) wrote:
>>> the old svn URL is no longer working; try the new one
>>> https://mapbender.osgeo.org/mapbender
>> Christoph,
>> Aii - no!
>> It should be https://svn.osgeo.org/mapbender
> Hey Christoph,
> please let us know when you have committed the changes so that we can go
> back to normal operation. I guess this makes you take on the Operation
> Administrator role. Congratulations and thank you.
> Best regards,
> Arnulf.
>> In fact, what you have quoted will work due to the wildcard dns thingy
>> being re-enabled temporarily but it will break immediately after that.
>> Paraphrasing from my announcement to gdal-dev:
>> Howard has made the changes to Mapbender's subversion and for somewhat
>> esoteric
>> reasons, the old subversion url no longer works.  So a small change
>> should
>> be made in your root mapbender directory if you want an existing tree
>> to continue
>> to work.
>> Do:
>> svn info
>> And look for the URL line.  Something like:
>> URL: https://svn.osgeo.org/svn/mapbender/trunk/mapbender
>> If this line has https: then do the following in the same directory:
>> svn switch --relocate https://svn.osgeo.org/svn/mapbender \
>> If the URL line is using http: then do this:
>> svn switch --relocate http://svn.osgeo.org/svn/mapbender \
>>     http://svn.osgeo.org/mapbender
>> By the way, I'd strongly discourage using http: for anyone doing commits.
>> Please only use http: for anonymous checkouts, and use https for any
>> tree where you plan to make changes back to the master.
>> PS. if you have something like https://mapbender.osgeo.org/mapbender then
>> also switch that.  eg.
>> svn switch --relocate https://mapbender.osgeo.org/mapbender \
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_dev mailing list
