[Mapbender-dev] Working with jQuery in Mapbenders mainframe... a testscript and a suggestion
Marc Jansen jansen.marc at gmx.de
Tue Nov 13 08:55:28 EST 2007
Hi Christoph,
try this:
    // a test setting
    window.setTimeout(function() {
        alert('working in parent');
        $('#parentdiv', parent).each(function() {
            alert(this);
        }).append('<div>I have been created not using the context
parameter (I should be in the parent)</div>');
        $('<div>second approach (parent)</div>').appendTo(
$('#parentdiv', parent) );
        alert('working in child');
        $('#iframediv').each( function() {
            alert(this);
parameter (I should be in the child)</div>');
        $('<div>second approach (child)</div>').appendTo( $('#iframediv') );
     }, 3000 );
Please note that appendTo can take a jquery object as well.
post any code that is not working as desired / expected so we can fix it.
-- Marc
Christoph Baudson (WhereGroup) schrieb:
> Hi Marc,
> thanks for your test scripts.
> I have an additional question: As the magic of jQuery lies in
> chaining, I wonder if expressions like these could be done with the
> frame environment:
> $("<div>").addClass(currentWfsConf.g_label_id).text(currentWfsConf.g_label).appendTo("#wfsForm");
> (Disclaimer: this is untestedcompletely  and I hope it's not all bad
> jQuery code)
> Can you create new tags in the frame, like $("<div>", parent)?
> Can you use the appendTo with a context parameter?
> I failed, but I may not yet have seen the light.
> Thanks for your contribution,
> Christoph
> Marc Jansen schrieb:
>> Hi devs,
>> as discussed on monday there are certain things to be considered
>> when you want to use jQuery. Please rebuild this testcript(s):
>> File 1 (the parent | mainframe in Mapbender):
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
>>  "http://www.w3.org/TR/html4/strict.dtd">
>> <html>
>>  <head>
>>    <title>Test</title>
>>    <script src="./tree21/jquery-1.2.1.pack.js"
>> type="text/javascript"></script>
>>  </head>
>>  <body>
>>    <iframe src="test2.php">
>>    </iframe>
>>    <div id="parentdiv">I shall disappear first</div>
>>  </body>
>> </html>
>> File 2 (the child | any frame embeded in Mapbenders mainframe):
>> <html>
>>  <head>
>>    <title>Test</title>
>>    <script type="text/javascript">
>>     * Map over parent's jquery to this frame's "$"/"jQuery".
>>     * Keep the second parameter to work in other contexts.
>>     * @todo check thoroughly.
>>     * @author Marc Jansen <jansen at terrestris.de>
>>    if (typeof $ == 'undefined' && typeof parent.$ != 'undefined' &&
>> typeof jQuery == 'undefined' && typeof parent.jQuery != 'undefined') {
>>        jQuery = function(param, context) {
>>            return parent.jQuery(param, context || window.document);
>>        $ = jQuery;
>>    // a test setting
>>            alert(this);
>>        }).hide();
>>            alert(this);
>>        }).hide();
>>        alert('has everything disappeared?');
>>     }, 3000 );
>>    </script>
>>    </head>
>>  <body>
>>    <div id="iframediv">I shall disappear later</div>
>>  </body>
>> </html>
>> Try to rebuild the two files and you'll understand what is happening
>> here. Needs to be checked in detail!
>> I suggest to test this further and to use this:
>>        $ = jQuery;
>> Bye,
>> -- Marc
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
