[Mapbender-dev] [Mapbender] #142: Mapbender setup to check error logging
Mapbender info at osgeo.org
Fri Nov 23 06:38:06 EST 2007
 Reporter:  christoph     |       Owner:  mapbender_dev at lists.osgeo.org
     Type:  enhancement   |      Status:  new
 Priority:  major         |   Milestone:  2.5 release
Component:  installation  |     Version:  2.4.3
 Keywords:                |
 In order for error logging to work, you need to give the user access to
 the folder "log". There may be some caveats, so it might be a good idea to
 add it to the setup checker.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/142>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
