[Mapbender-dev] idea for a new module
Thomas Baschetti Thomas.Baschetti at gmx.de
Wed Oct 10 09:23:13 EDT 2007
i know, we all only use Firefox, but...
sometimes clients use IE or other browsers, which don't
have firebug. I think using a pop-up or any other
browser-independent solution should be better.
Bye
Thomas
Melchior Moos schrieb:
> Hi,
> maybe it is also possible to integrate FirePHP (http://www.firephp.org/)
> into that Module, but by now I hadn't a deeper look at it.
> Cheer,
> Melchior
> Christoph Baudson (WhereGroup) schrieb:
>> Maybe we wouldn't even need the pop-up; content from the log could be
>> displayed in Firebug, which would make the whole thing much easier.
>>> How about a module for debugging?
>>> For a start, it could just display the mapbender log (and the php
>>> error log), maybe in one of the new javascript pop-ups. The pop-up
>>> could work with AJAX and refresh its content periodically. It could
>>> work like the "tail" command. It could also filter the log file, f.e.
>>> only displaying the entries from the currently logged in user.
>>> I guess it would make debugging considerably easier, especially with
>>> remote clients with access or know-how limitations.
>>> It should not be hard to implement. Do you think this is a good idea?
>>> Any volunteers? :-)
>>> Christoph
More information about the Mapbender_dev mailing list
