[Mapbender-dev] SLD Editor- no connection to SLD
Roland Jehle r.jehle at ceit.at
Thu Oct 11 07:48:12 EDT 2007
Hi Michael,
My problem till now is when I open the SLD-Editor, change something, and save it the SLD is correctly saved in the DB but the "Vorschau mit SLD" don't show me these changes.
When I have a look at the getMAP-request of the "Vorschau mit SLD" there is the URL to the sld_function_handler.php which reads out my made changes correctly and they are written in "SLD anzeigen".
When I look at the source of this HTML window "SLD Anzeigen" the SLD-XML looks correct.
The getMap-Request simply ignores all declarations in the SLD and draws the "Bundesländer" layer like without any SLD.
After having solved this problem I can start to look how to connect the SLD to the Mapbender Layers requests (getMap-Requests).
Generally I want to say that from my point a view there are two main use cases for the SLD Editor:
A)      For an administrator to make changes in the layers and save them: e.g. to show through filter encoding only the parcels of 1 Person. For this chase the SLD Editor of Markus Krzyzanowski is good.
B)      For the users in the GUI to do very simple things like change colors and class size. Mapbuilder has integrated this already with Javascript in the newest release.
Cheers
Roland
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20071011/f3223482/attachment.html
More information about the Mapbender_dev mailing list
