[Mapbender-dev] Re: [Mapbender] #129: mixed up wfs_conf_ids
Michael Schulz mschulz at webgis.de
Fri Oct 26 10:10:45 EDT 2007
Hey Christoph,
are these patches / bugfixes also worked into e.g. the 2.4.3 tag in
svn or in the official 2.4.3 download package?
Cheers, Michael
2007/10/26, Mapbender <info at osgeo.org>:
>   Reporter:  christoph  |       Owner:  mapbender_dev at lists.osgeo.org
>       Type:  defect     |      Status:  closed
>   Priority:  critical   |   Milestone:  2.5 release
>  Component:  wfs        |     Version:  2.4.3
> Resolution:  fixed      |    Keywords:
> Comment (by christoph):
>  1) To download the patch, follow the link "patch_129.txt", '''DO NOT
>  RIGHT-CLICK AND DOWNLOAD'''! This will download the HTML site you see when
>  you follow the link. Download at the bottom of that page, "Download in
>  other formats: Original Format"
>  2) To apply the patch, use Eclipse and follow these instructions
>  http://www.mapbender.org/index.php/Release_guide#applying_a_patch
>  If you know how to apply the patch via command line, let me know because I
>  have never done that and I'm curious.
> Ticket URL: <http://trac.osgeo.org/mapbender/ticket/129#comment:3>
> Mapbender <http://www.mapbender.org/>
> Mapbender
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
