[Mapbender-dev] Re: [Mapbender-users] owsproxy and legend
Michael Schulz mschulz at webgis.de
Fri Sep 7 11:11:31 EDT 2007
I switched to the dev-list, ok?
> > does the owsproxy module currently support the "rewriting" of the legendurls?
> No - at the moment the legend-url is not encrypted. But we just work at
> this enhancement. You are welcome, if you want to join the discussion
> about this topic.
Very good. While looking thru the code I realized that there will be
several things one has to take into account, but nevertheless i am
interested in following this discussion.
My quick hack so far is to select the wms_owsproxy also when selecting
the layer_styles in createObjFromDB() (a bit of a join hell, but ...),
if we have sth. in wms_owsproxy then the legendurl is taken and its
query-part is appended to the owsproxy-url and then assigned to the
objLayer.legendurl.
Cheers, Michael
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
