[Mapbender-dev] short_open_tag
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Mon Sep 17 11:17:17 EDT 2007
The module "mod_displayWMC" cannot display XML documents properly if
"short_open_tag" is "on" in php.ini, as the "<?xml" is interpreted as PHP.
So I added a check whether "allow_short_tag" is "off" to the
mapbender_setup script, see attachment.
Baudson Christoph
http://www.wheregroup.com
An embedded message was scrubbed...
Subject: [Mapbender-commits] r1670 - trunk/mapbender/http/tools
Date: Mon, 17 Sep 2007 11:13:44 -0400 (EDT)
Url: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20070917/0fcde5ee/tools-0001.mht
More information about the Mapbender_dev
