[Mapbender-dev] Transparent PNG's in IE
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Sep 18 04:28:19 EDT 2007
Hi Markus,
apparently you are not using Mapbender 2.4.2...which version are you using?
Cheers, Christoph
Weißmann, Markus schrieb:
> Hello Christoph,
> i replaced the two files. The file called "mod_treefolder2.php" already
> exists in my filesystem, so i could replace it, but "map.js" was not
> there, so i created it new. But there was no effect.
> Markus
>  >Hi Markus,
>  >Take a look at this
>  >_http://trac.osgeo.org/mapbender/ticket/94_
>  >You would have to replace two files. Please report back if this solves
>  >your problem or if it is something different.
>  >Thank you
>  >Christoph Baudson schrieb:
>  >> I'm not sure if it is the same problem, but I've experienced something
>  >> similar in the past: Mapbender uses it's own luminance attributes
> for the
>  >> map images since version 2.4.2 (as you can set the luminance via
>  >> treeGDE2). But they corrupted existing image luminance, so we had to
> fix
>  >> it. AFAIR we had to change the files mod_treefolder2.php and map.js, so
>  >> the latest versions from SVN might be worth a try.
>  >> I will take a deeper look at it on Monday and let the list know.
>  >> Christoph
>  >> On Fri, September 14, 2007 11:43 am, "Weißmann, Markus" wrote:
>  >>> Hello,
>  >>> does anybody find a solution to this topic? I want to get following
>  >>> solution in IE, which i get in Mapbender under FF:
>  >>>  <_http://www.bilder-hochladen.net/files/40qd-1-jpg-nb.html_>
>  >>> With GIF i can not go on. If i set on GIF, the areas appear opaque
> (the
>  >>> same in FF). So it only remains PNG. There was an article already in
>  >>> last year:
> <_http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558_.
>  >>> html>
> _http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.h_
>  >>> tml
>  >>> At least i could build the expample (
>  >>> <_http://www.twinhelix.com/css/iepngfix/demo/_>
>  >>> _http://www.twinhelix.com/css/iepngfix/demo/_) onto my server. But
> i could
>  >>> not teach it to Mapbender.
>  >>> With kind regards
>  >>> Deutsch:
>  >>> Hallo,
>  >>> hat jemand zu diesem Thema schon eine Lösung gefunden? Ich möchte
>  >>> folgendes Ergebnis, welches ich in Mapbender unter FF hervorbringen
>  >>> konnte, auch im IE bekommen:
>  >>> Mit GIF komme ich da nicht weiter. Stelle ich auf GIF, erscheinen die
>  >>> Flächen deckend (auch im FF). Also beibt nur PNG. Es gab dazu schon im
>  >>> letzten Jahr einen Beitrag:
>  >>> html>
>  >>> tml
>  >>> Ich habe immerhin das Beispiel (
>  >>> _http://www.twinhelix.com/css/iepngfix/demo/_) auf meinem Server
>  >>> nachvollziehen können. Aber ich konnte es Mapbender nicht beibringen.
>  >>> Mit freundlichem Gruß
>  >>> Markus Weißmann
>  >>> _______________________________________________
>  >>> Mapbender_dev mailing list
>  >>> Mapbender_dev at lists.osgeo.org
>  >>> _http://lists.osgeo.org/mailman/listinfo/mapbender_dev_
>  >WhereGroup GmbH & Co. KG
>  >Siemensstraße 8
>  >53121 Bonn
>  >Germany
>  >Fon: +49 (0)228 / 90 90 38 - 17
>  >Fax: +49 (0)228 / 90 90 38 - 11
>  ><_mailto:info at wheregroup.com_>
>  >_http://www.wheregroup.com_
>  >Amtsgericht Bonn, HRA 6788
>  >Komplementärin:
>  >WhereGroup Verwaltungs GmbH
>  >vertreten durch:
>  >Arnulf Christl, Olaf Knopp, Peter Stamm
>  >Baudson Christoph
Siemensstraße 8
53121 Bonn
Germany
Komplementärin:
vertreten durch:
Baudson Christoph
More information about the Mapbender_dev mailing list
