[Mapbender-dev] I18n (Internationalization)
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Apr 15 06:03:08 EDT 2008
Christoph Baudson schrieb:
> I have just made some final adjustments to the i18n in Mapbender 2.5.
> Please let me know if you don't agree with me on this topic.
> 1) you can now choose to turn i18n off and use Mapbender 2.5 without
> having to install gettext.
> 2) you can set a default language (if i18n is turned on)
> I propose to turn i18n off by default in order to allow a soft
> upgrade, meaning that you have to turn it on explicitly. If it is
> turned off, only english is available.
> To achieve this, I had to replace the calls to the gettext function
> _() by a Mapbender wrapper, called _mb(). This function checks if I18N
> is available. If not, it simply returns the input value, much like our
> database function "gettext".
Hello Christoph,
I agree with the solution that you described. Sounds very good.
astrid
More information about the Mapbender_dev mailing list
