[Mapbender-dev] Fwd: [Mapbender-users] problems at creating mapbender2.5 schema
Christoph Baudson christoph.baudson at wheregroup.com
Sat Apr 19 03:38:05 EDT 2008
On Fri, April 18, 2008 5:49 pm, Michael Schulz wrote:
> Hi Christoph,
> plpgsql is one language with that you can create functions.However
> this check creates a temporary "sql" function to determine whether
> plpgsql is installed. So you won't need plpgsql installed.
Thanks for your comment, and thanks for explaining. Brilliant, so we can
use this solution after all! We should put it in rc2.
As there are no dumb questions: Couldn't we use a temporary SQL function
for our gettext function and skip plpgsql? I guess not, but maybe someone
can explain. I'm not that much into databases.
Thanks,
Christoph
> Cheers, Michael
> 2008/4/18 Christoph Baudson <christoph.baudson at wheregroup.com>:
>> Michael Schulz schrieb:
>> > Hi,
>> > i've found this:
>> http://andreas.scherbaum.la/blog/archives/346-create-language-if-not-exist.html
>> > Haven't tried it though, but it looks good.
>> > Cheers, Michael
>>  Thanks for your suggestion Michael, however I fear that his solutions
>> is no
>> good, if I read the comments correctly...he used a function to check if
>> plpgsql is there. But plpgsql is required for functions.
>>  But another poster seems to have submitted a patch to PostgreSQL, let's
>> see
>> if we have this is in the next version.
>>  For now, I have removed the CREATE LANGUAGE bit, as it is listed in the
>> installation guide.
>>  Have a nice weekend,
>>  Christoph
>> > ---------- Forwarded message ----------
>> > From: Michael Schulz <mschulz at webgis.de>
>> > Date: 2008/4/17
>> > Subject: Re: [Mapbender-users] problems at creating mapbender2.5
>> schema
>> > To: Mapbender User List <mapbender_users at lists.osgeo.org>
>> > Hi Marc,
>> >  the mapbender database must have the plpgsql language installed,
>> >  because of the i18n functions. If your db has plpgsql already
>> >  installed, then you can comment this statement from the schema.sql.
>> >  We should have look for a "check if exists" way to do this, because a
>> >  lot of people will have plpgsql installed (e.g. from postgis).
>> >  Cheers, Michael
>> >  2008/4/17 Marec <marec at t-online.de>:
>> > > Hi list,
>> >  >  i actually downloaded  the new mapbender(2.5rc1) release.
>> >  >  Now i have a problem at creating the new Database schema.
>> >  >  If  i execute the "pgsql_schema.sql" i get following error
>> message:
>> >  >  ERROR:  language "plpgsql" already exists
>> >  >  Is the first statement a mandatory setting in the new release or
>> can i
>> >  > delete it??
>> >  >  Because I couldn't find the first statemets in older releases.
>> >  >  greetings Marc
>> >  >  _______________________________________________
>> >  >  Mapbender_users mailing list
>> >  >  Mapbender_users at lists.osgeo.org
>> >  >  http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> >  Michael Schulz
>> >  in medias res
>> >  Gesellschaft für Informationstechnologie mbH
>> >  In den Weihermatten 66
>> >  79108 Freiburg
>> >  Tel +49 (0)761 556959-5
>> >  Fax +49 (0)761 556959-6
>> >  http://www.webgis.de / http://www.zopecms.de
>>  W h e r e G r o u p GmbH & Co. KG
>>  Siemensstraße 8
>>  53121 Bonn
>>  Germany
>>  Christoph Baudson
>>  Anwendungsentwickler
>>  Fon: +49 (0)228 / 90 90 38 - 15
>>  Fax: +49 (0)228 / 90 90 38 - 11
>>  www.wheregroup.com
>>  Amtsgericht Bonn, HRA 6788
>>  Komplementärin:
>>  WhereGroup Verwaltungs GmbH
>>  vertreten durch:
>>  Arnulf Christl, Olaf Knopp, Peter Stamm
>>  Mapbender_dev mailing list
>>  Mapbender_dev at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Michael Schulz
> in medias res
> 79108 Freiburg
More information about the Mapbender_dev mailing list
