[Mapbender-dev] mark deprecated functions
Thomas Baschetti Thomas.Baschetti at gmx.de
Mon Apr 21 10:10:06 EDT 2008
> As a developer, I'm indifferent about it (I'm not a user). But I see
> your point.
I think even developers should know which functions are deprecated ;-)
or these will never go away.
Not a problem for you as you have all in your head...
> There are a lot of files to check, and I wouldn't want to go through all
> of them.
no need for you to do it all, let us (me?) be you code-monkeys
> But if you work on a file that contains a deprecated function,
> just go ahead and add the notice to it.
only if we agree on it, it would be useless if it's only done halfway.
Ciao
Thomas
GMX startet ShortView.de. Hier findest Du Leute mit Deinen Interessen!
Jetzt dabei sein: http://www.shortview.de/?mc=sv_ext_mf@gmx
More information about the Mapbender_dev mailing list
