[Mapbender-dev] Error in mysql_schema.sql MB 2.5 rc2
Christoph Baudson christoph.baudson at wheregroup.com
Wed Apr 23 03:54:39 EDT 2008
Christoph Baudson schrieb:
> Tilo Wütherich schrieb:
>> Hi Devs,
>> there is a comma missing at the end of line 171 in mysql_schema.sql.
>> Greetings,
>> Tilo
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Thanks Tilo,
I *wished* a comma was the only error in that dump. I believe it's not
quite up to date.
> The version history states that MySQL is not supported in the current
> rc, however this information might have been missing when you
> downloaded the file.
> Christoph
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
