[Mapbender-dev] Printing the Measurement
Christoph Baudson christoph.baudson at wheregroup.com
Fri Aug 15 09:54:15 EDT 2008
>> Samson, Marko schrieb:
>>> I just recognized, that the last clicked part of o stroke from a
>>> lenght measurement does not apear at the pdf file. (2.5rc5)
>>> The function addMeasuredItem from print_functions.php deletes the
>>> last part of the measure-array, if the measure-array isn't a closed
>>> polygon (first==last point):
>>> 219         if (isClosedPolygon($theFullArr)) {
>>> 220           $nr_of_points = count($theFullArr);
>>> 221             $isClosed = TRUE;
>>> 222         } else {
>>> 223           $nr_of_points = count($theFullArr) - 1;
>>> 224             $isClosed = FALSE;
>>> 225         }
>>> Is there a reason why? I just deleted the "-1" and everything works
>>> fine.
>> I guess this is a bug. Can you please file a ticket and commit the
>> corrected version?
> I committed the bug fix, see
> http://trac.osgeo.org/mapbender/ticket/276. Thanks for letting us know.
Ok, merging it into the trunk I saw you had committed it there, Marko.
Thanks. So now it's fixed in 2.5 and in trunk.
>> Thanks
>> Christoph
>>> Greetings,
>>> Marko Samson
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
