[Mapbender-dev] [Fwd: Re: [Context.RWG] 1.0 at the next TC?]
Arnulf Christl arnulf.christl at wheregroup.com
Mon Aug 18 17:53:24 EDT 2008
Hey,
I picked this up on the OGC lists. Maybe someone is interested in
implementing this, there might be some funding in the upcoming OGC WOS-6
testbed. I know we have also been doing some things in this respect so
maybe its not that big an effort.
Best regards,
Arnulf.
---------------------------- Original Message ----------------------------
Subject: Re: [Context.RWG] 1.0 at the next TC?
From:    "Cameron Shorter" <cameron.shorter at gmail.com>
Date:    Mon, August 18, 2008 23:07
To:      "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>
Cc:      context.rwg at lists.opengeospatial.org
Raj,
With Mapbuilder we had not completely upgraded to the 0.3.0 spec - we
still had some inconsistencies.
However I did quite an extensive review of the spec when I was trying to
work out what was required to upgrade to 0.3.0, and I was satisfied that
the spec has become quite mature and is close to ready to be moved to 1.0.
I'd suggest that before we move to 1.0, we should use the latest context
spec in a testbed and ensure that there are a few clients which support it.
I understand that it wouldn't take much to bring UDig to support the
latest version of Context, Mapbuilder almost supports it, (but we have
recently retired mapbuilder, recommending people use Openlayers
instead). Openlayers still needs some work to support all the Context
layers, but this is quite achievable in the timeframe of a testbed.
Kralidis,Tom [Burlington] wrote:
> Raj: I would support this.  Having an encoding to be able to point to
multiple OWS types would be useful in clients.  As well, the KML
integration makes it all that more appealing!  We might also want to
have examples using using OWS Context within a KML document (i.e. in
kml:ExtendedData).
> Having said this, I will test the examples at
http://www.ogcnetwork.net/schemas/owc/0.3.0
> What do others think?
> ..Tom
> -----Original Message-----
> From: context.rwg-bounces+tom.kralidis=ec.gc.ca at lists.opengeospatial.org
on behalf of Raj Singh
> Sent: Wed 13-Aug-08 20:12
> To: context.rwg at lists.opengeospatial.org
> Subject: [Context.RWG] 1.0 at the next TC?
> OWC 0.3.0 has been out there since early May at:
> http://www.ogcnetwork.net/schemas/owc/0.3.0/
> 1. Has anyone tested it?
> 2. If so, is it ready to move forward towards 1.0?
> Raj
> Context.rwg mailing list
> Context.rwg at lists.opengeospatial.org
> https://lists.opengeospatial.org/mailman/listinfo/context.rwg
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
Arnulf Christl
http://www.wheregroup.com
More information about the Mapbender_dev mailing list
