[Mapbender-dev] Wiki: Please review
Hr. Johannes Loose loose at lwf.uni-muenchen.de
Thu Dec 4 13:49:24 EST 2008
Hello Devs!
I'm am trying to install a secure webgis environment since a while. The main steps are
documented now and I'd like to share them with the community. Note that I'm neither a
programmer, nor a security expert.
I have uploaded a draft (So long German only, sorry) in the mapbender wiki, knowing, that lot
of the information is documented in some other place in the same wiki. The howto is
designed for advanced users, not as a step-by-step instruction. You can find it here :
http://www.mapbender.org/SecureInstall
If you find it useful, you might correct some points or tell me what to make better. If you find
some errors or wrong statements, please let me know and correct them. Feel free to contact
me directly, too. I would like to know if the way I did it is 'quite secure' or if there are obvious
holes.
In case there is no benefit for other users, well just press 'delete'
Yours
Johannes
More information about the Mapbender_dev mailing list
