[Mapbender-dev] WMC: limitation number of Layers/WMSor mb_mapObj[ind].toJSONString() while saving?
Samson, Marko Marko.Samson at wald-und-holz.nrw.de
Wed Feb 20 08:22:15 EST 2008
> -----Original Message-----
> From: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
> Christoph Baudson
> Sent: Wednesday, February 20, 2008 11:19 AM
> To: Mapbender Developer List
> Subject: Re: [Mapbender-dev] WMC: limitation number of
> Samson, Marko schrieb:
> > Hi Devs,
> > is there a limitation by number of WMS or layers respectively the
> > lenght of the "mapObject":mb_mapObj[ind].toJSONString() part in
> > mod_savewmc.php?
> > I have a GUI/application with 21 WMS with perhaps 3 Layers
> each. When
> > I save a WMC, the head of the XML looks normal, but after the
> > Extensions part, the Layerlist is missing and it looks like this:
> > <Name>Mapbender
> WMC</Name><Title>test</Title><KeywordList><Keyword>Mapbender</Keyword>
> > <K
> eyword>WMC</Keyword></KeywordList><Extension/></General><LayerList/></
> > eyword>Vi
> > ewContext>
> > After reducing the number to 3 wms, the xml document looks
> alright to
> > me. Seems to be a limitation or problem of
> > "mapObject":mb_mapObj[ind].toJSONString() at
> mod_savewmc.php line 82?!
> Thanks for your interesting remark.
> I think was wondering the same some time ago, and I remember
> faintly it has something to do with the server side, the
> decoding of the JSON string of the mapObj.
> Either the problem (as I remember it) was not .toJSONString()
> in JavaScript, but the Services_JSON class in PHP, or more
> likely it was something weird regarding stripslashes etc.
> that I considered unresolvable at that time (with the time
> frame I had then). It depends on the magic_quotes_gpc setting
> in php.ini (which is "on" by default), and it might be that
> the script works if it is "off". It would be nice if it
> worked either way, so maybe we just have to add stripslashes
> at the server side to make it work for the default setting.
> What is your settings for magig_quotes_gpc?
It was "on" and is now "off", but without a change. mmh
> If you could check again this would be brilliant. I hope this
> helps at least a little bit.
> Thanks,
>  Christoph
> > BTW: I ofen get this message when loading a 'normal'
> wmc-xmlfile with
> > MB2.4.4:
> > syntax error mb_listWMCs.php (line 26)
> > window.opener.mb_registerMapObj(old_mapObj[i].frameName,
> > old_mapObj[i].element...
> > 25 if (old_mapObj[i].frameName != 'overview') {
> > 26 window.opener.mb_registerMapObj(old_mapObj[i].frameName,
> > old_mapObj[i].elementName, null, , );
> > 27
> window.opener.document.getElementById(old_mapObj[i].frameName).style.w
> > id
> > th = ;
> > 28
> window.opener.document.getElementById(old_mapObj[i].frameName).style.h
> > ei
> > ght = ;
> > 29 }
> > Is this a known problem? Whats wrong? When I save a wmc at
> gui1 with
> > germany and mb_users wms and load it, everything works fine
> (except of
> > the overview).
> > Greetings,
> > Marko
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
