[Mapbender-dev] [Mapbender] #154: i18n and MySQL: a db function has to be written
Mapbender info at osgeo.org
Thu Jan 10 05:45:50 EST 2008
 Reporter:  christoph  |       Owner:  mapbender_dev at lists.osgeo.org
     Type:  task       |      Status:  new
 Priority:  major      |   Milestone:  2.5 release
Component:  database   |     Version:
 Keywords:             |
 this is the equivalent in PostgreSQL:
  -- new function gettext for easy translations
  CREATE OR REPLACE FUNCTION gettext(locale_arg "text", string "text")
  RETURNS "varchar" AS
  $BODY$
  DECLARE
     msgstr varchar(512);
     trl RECORD;
  BEGIN
     -- RAISE NOTICE '>%<', locale_arg;
     SELECT INTO trl * FROM translations
     WHERE trim(from locale) = trim(from locale_arg) AND msgid = string;
     -- we return the original string, if no translation is found.
     -- this is consistent with gettext's behaviour
     IF NOT FOUND THEN
         RETURN string;
     ELSE
         RETURN trl.msgstr;
     END IF;
  END;
  $BODY$
   LANGUAGE 'plpgsql' VOLATILE;
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/154>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
