[Mapbender-dev] check browser on activated java or popup blocker
Manns, FB 62 manns at str.de
Fri Jan 11 04:07:01 EST 2008
Hi  dev list,
Because most of internet user's got a popup, or
java-script blocker and in case of that mapbender can not be
optimaly used,
i' ve createted 2 new features in our mapbender
to check this.
1.  for checking the browser on java-scripting:
   i've made  some modifications in mod_map1.php!!
   you can download it here
   http:///geoportal.remscheid.de/tools/mod_map1.zip
2.  for checking the browser on activated popup-blocker
     copy this 2 files into Mapbender folder
     http/html
       http://geoportal.remscheid.de/tools/check_popup.zip
           insert this sql into a gui
	INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, 	e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','check_popup',2,1,'check the
	Browser on activated popup Blocker','iframe','../html/check_popup.html','',1000,1000,1,1,NULL ,'visibility:hidden;','','iframe','','','','','');
    this module open up a popup window after loading a gui......
you can test this features in your own mapbender versions,
and if you want to make some modifications in this modules
or add something that i've forgotten to do
you're welcome :-).
greetings from Remscheid
Marc Manns
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20080111/8bdca6ae/attachment.html
More information about the Mapbender_dev mailing list
