[Mapbender-dev] module for VSP's
Froko tolka at trash-mail.com
Wed Jan 16 19:12:46 EST 2008
I also want to transfer a variable for variable substitution to the
umn-mapfile.
But i don't know how to use mod_add_vendorspecific.php for it.
Can someone give me an example? Is it necessary to change other files or
settings, too?
regards
Daniel
Astrid Emde wrote:
> Stefan P. schrieb:
>> Hi,
>> is the module commited yet? I would appreciate to have a look at it.
>> regards
>> Stefan
>> Michael Schulz wrote:
>>> Hi Uli,
>>> thanks for the information. No hurry. Can you give a short overview
>>> how it works?
>>> I tried creating a module that adds vsp to the appropriate
>>> wms-services layer only. Therefore  i changed the include script for
>>> php variables to also create php-arrays. Then you can add, via gui
>>> element vars of that module, the layername where the vsp should be
>>> added, the url-vsp-key and the vsp-value. The key is also checked
>>> against $SESSION, so one could add the parameter and value to the
>>> mapbender call, and the module would take this value and turn it in an
>>> vsp (e.g. if you want to link other applications with mapbender).
>>> Cheers, Michael
>>> On 11/2/06, Ulrich Rothstein <uli.rothstein at ccgis.de> wrote:
>>>> Hi Michael,
>>>> that module exists but is not commited yet.
>>>> I'm back in the office at wednesday. If you need it earlier please
>>>> contact
>>>> Astrid.
>>>> regards
>>>> Uli
>>>> On Tue, October 31, 2006 4:01 pm, Michael Schulz wrote:
>>>>> Hi,
>>>>> i wanted to check whether there is an existing module to configure
>>>>> vendor specific parameters (vsp) for wms services through a mapbender
>>>>> admin-GUI?
>>>>> The background is, that when configuring access to wms services (for
>>>>> at the moment mostly umn mapserver wms) there is very often the need
>>>>> to have variable vsp, e.g. to transmit user information, that is used
>>>>> in the umn-mapfile for variable substitution.
>>>>> Anybody feeling a similar need?
>>>>> Cheers, Michael
> Hi devs, hi Stefan, hi Michael,
>   I checked in the modul mod_add_vendorspecific.php to add vendor
> specific parameters to the MapRequest.
> https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_add_vendorspecific.php?view=auto&rev=983
> Greetings
> Astrid Emde
>   Astrid Emde
>   CCGIS GbR
>   Siemensstraße 8
>   53121 Bonn
>   Germany
>       astrid.emde at ccgis.de
>           www.ccgis.de
>   Tel.:      ++49 (0) 228 90826 19
>   Fax.:      ++49 (0) 228 90826 11
>   Zentrale:  ++49 (0) 228 90826 0
> To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: dev-help at mapbender.osgeo.org
View this message in context: http://www.nabble.com/module-for-VSP%27s-tp7095563p14897649.html
Sent from the mapbender-dev mailing list archive at Nabble.com.
More information about the Mapbender_dev mailing list
