[Mapbender-dev] different session ID´s
Sascha Bahl sbahl.ml at gismobil.de
Thu Jan 31 08:38:33 EST 2008
Hello developers!
I ´ve a problem with the different session-ids in mapbender version
2.4.4. When mapbender makes a request for the main map the session-id is
another as the session-id when i make a printout. The reason is that:
the request for the printout cames from a php-script
(class_connector.php) which is execute by the webserver. The request for
the main map (map.js) cames from the browser with an another session-id
as the printout. Its logical!
For this reason i can not determine a real session because i have two
session-ids for one user. So, my wms reserved 2 licences.
Which is the best way to merge the session-ids, respectiveley to use
only one session-id in mapbender? I would like change the code at this
point.
Greetings
Sascha
More information about the Mapbender_dev mailing list
